Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
Summer
Drives: 2010 2SS/RS IOM w/ Black Stripes Join Date: May 2009
Exhaust Silencers
So my exhaust is too loud to pass inspection and someone mentioned to me that I should get silencers. Anyone ever use these and know if they actually work?
CAI intake w/ ADM air scoop, Rotofab W/W Reservoir, Hurst Shifter, Skip-Shift Eliminator
AAC lighting, Kooks headers w/ high flow cats and Borla ATAK cat-back Restoring or need parts for a Chevy. Look no further than Don's East Coast Restorations |
![]() Drives: 2010 2SS/RS Join Date: Jan 2010
whhhhhaaaaaaattttt?!?!?!?! silencers??? damn, what kinda inspection is this?
![]() Drives: 2010 camaro ss Join Date: Sep 2011
They are resonators
SECC
Did this person mean mufflers maybe? If your trying to pass the inspection in Germany without them, good luck. What I would have given to have had a Camaro when I was in Germany. I was at Friedburg, not to far from you. Make sure to take it to the Ring if you haven't yet.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
#5 | |
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '10 SIM SS/A6 - '12 SIM Equinox LT Join Date: Jul 2009
Germany is real strict with vehicle inspections... I did two tours there and both times when I shipped my car, they caught something wrong, to include, under carriage dirt
![]() I had a Honda Civic with the folgers can and all and it failed...luckly the exhaust I had you could order silencers for then and thats what I did. I know you got the ATAK, .... maybe you might want to get some quieter mufflers... as for silencers that will fit that system, I wish I had an answer for ya. Oh and have a good ol German bier for me and a brat w/ kraut ![]()
2010 SIM Camaro 1SS/A6
![]() Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone" ![]() |
#7 |
Summer
no doubt snoop! I thought about getting corsa mufflers but my supplier fell through so I went to other alternatives. I think I might just try and find a muffler with a silencer in it that can just bolt onto the pipe.
#8 |
I.AM.
Drives: 2010 2SS/RS/M6 Join Date: Oct 2008
Check out these....you can just insert them into your tailpipes and remove them after your inspected. Not sure how quiet it needs to be, but they just may do the trick.
http://www.carchemistry.com/shop/ind...duct_list&c=76
NY5thgen.com
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: two 5ths and a 1st Join Date: Dec 2009
Will @ Red Jacket could probably whip up a couple of surpressors.
I watch way too much TV. |
#10 |
![]() Drives: 2010 2SS IBM L99 Join Date: Apr 2010
I would be interested in a set of silencers or some type of temporary sock.... just for startup at 5am... I have great neighbors, they say it doesn't bother them but they use it as a snooze to wake them up when I start now.... and I would like to get a CAM next spring. Startup is loud but settles down after a couple minutes.... some type of silencer just for the initial beast at start up would get my wallet open.
#11 |
![]() Drives: 2012 GT500 SVTPP Join Date: Nov 2009
I am thinking of going back to Germany for another rotation. I have An SLP loudmouth 1. Will there be an issue passing inspection on base?
Past rides:
2002 BMW M3 2010 Camaro V6 2010 Camaro SS L99 2011 Camaro SS Ls3 2011 Dodge Charger R/T 2012 Dodge Charger SRT8 Super Bee/ Reso Delete Current ride: 2012 GT500/ 2.3 TVS, Afco Dual pass heat exchanger, Roush Extreme Exhaust: 606 rwhp/ 611 wtq |
#12 |
Maybe the rules have changed since my last tour there... you should get by with the Loudmouth (thats with factory exhaust manifolds) ... not sure if you have headers and cats.
They measure the decibel on the exhaust and the Borla ATAK is pretty loud, I am pretty sure that the LM's are a tad quieter than the ATAK system. @PhaseV... I'm glad to found a hook up, and I hope you get it fixed fast so you can hit the 'ring one day or even hockenhiem ![]()
#13 |
Summer
they only bothered me b/c I got the one guy that hates americans and he saw the brand new piping so i was automatically failing :( the sound check only just made it illegal for paper purposes. and mine was 108db which i've seen to be louder than anyone elses exhuast so you should be fine. I've got a set of corsas coming and if they make it lower then you can always borrow the mufflers for your inspection
#14 |
As stated last time on this issue:
You will surely fail inspection (TÜV) with an ATAK Most likely fail with any sort of Corsas Even quite likely fail with an LMII, although some managed to pass... There are always exceptions to the above, and sometimes everything is possible depending on the location of the TÜV, but chances are few. So again - as suggested last time - get in touch with somebody on the German Camaro Forum and/or try to find a US-Car dealer/shop that could borrow you a set of stock mufflers just for the inspection. Other than that: there are a couple of shops that could help you with your inspection (TÜV) issue almost regardless of what exhaust system you are running, but those guys are a couple of hours away from Wiesbaden... seeminlgy you didn't want this either... ![]() I keep my fingers crossed that you eventually pass inspection/TÜV. But again, with an ATAK.... no way!
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73) CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials |
Thread Tools | |
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3463 | 04-12-2018 02:44 PM |
OK...I'm starting a better V6 exhaust examples thread!! | KMPrenger | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 607 | 03-21-2018 08:39 PM |
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
Exhaust Theory revisited | Wacker | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 3 | 11-23-2009 10:12 AM |
