BORLA
Old 01-03-2012, 10:08 AM   #1
SFcamaro
SFcamaro's Avatar
Drives: 2010 Camaro SS 6M
Ideas on removing resonator to increase sound
Whats your ideas on removing the resonator on a 2010 SS camaro.
I went from running straight pipes to adding a 40 series Flowmaster original muffler and now my car is alot quieter. I was wondering if removing the resonator would be a good idea?
SFcamaro is offline   Reply With Quote
Old 01-03-2012, 11:26 AM   #2
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
On a manual car? There are two little ones on the manual car, which do quiet it down a little, but you probably wouldn't hear a ton of difference by removing those, probably wouldn't be worth the cost. In an auto, yes, removing the huge resonator would be worth it.
If you wanted to go for louder and more power, you'll have to get some long tubes and high flow cats! You could also just go with some high flow replacement cats, which might get you there for some sound and some performance.
- Jeremy
JDP Tech is offline   Reply With Quote
Old 01-03-2012, 11:35 AM   #3
SFcamaro
SFcamaro's Avatar
2 resonators?
I thought it went like this
engine > manifolds > 1st cat > 2nd cat > resonator > muffler
Old 01-03-2012, 11:44 AM   #4
JDP Tech
JDP Tech's Avatar
On each side, correct. Here is a stock manual exhaust compared to a Magnaflow Comp Series, you can see the two resonators after the stupid H-pipe, just before the two pipes split:
- Jeremy
Old 01-03-2012, 12:08 PM   #5
SFcamaro
SFcamaro's Avatar
Oh ok I see what you mean. A resonator on each pipe.
Old 01-03-2012, 12:10 PM   #6
SFcamaro
SFcamaro's Avatar
Ya so basically I had this setup
engine > manifold > 1st cat > 2nd cat > resonator > straight pipe with no muffler
I changed it to
engine > manifold > 1st cat > 2nd cat > resonator > Flowmaster 40 series original
but it became much quieter
Do you think removing the resonator would be a good idea?
Do I need to replace the resonator with an x pipe or can I just have a straight pipe to fill the gap?
Old 01-03-2012, 12:45 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I changed it to
Removing the resonator won't make a huge sound difference and probably isn't worth the $$ to do it. You need a crossover in the system to aid in scavenging. Whether you use the stock H pipe or aftermarket X pipe is purely choice as there's really not a much of a difference between the two other than a slightly different sound.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Magnaflow Exhaust Systems In Stock! | Sound Clips+Dynos | Special Offer | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 178 11-20-2010 11:02 PM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 12:57 PM
Surround sound help thejushinator Off-topic Discussions 12 11-07-2009 10:49 PM
Exhaust sound bulldog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-07-2009 03:43 PM
Surround Sound Help! T! E! X! A! S! Off-topic Discussions 3 01-24-2009 06:55 PM
