Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Audio / Visual / Electronics/ Gauges / Nav
Old 01-03-2012, 09:46 PM   #1
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
FS: JL 250/1 Amp
$170 plus shipping
Works perfectly
I just installed a JL 600/1 amp and don't need this anymore....and can't talk the wife into letting me install it in her SUV.
I used it to power my JL 12" W3v2 and JL 10" W3v3 in line. CLEAN power.
This is the 1st version of the JL 250/1 mono block amp.....VERY similar too that of the V2 amp, but the first version.
Old 01-04-2012, 10:36 PM   #2
preppykid
preppykid's Avatar
Drives: Black LT Camaro
out of curiosity, where do you get the 600/1? I'm trying to get one for my w6v2
preppykid is offline   Reply With Quote
Old 01-05-2012, 01:32 AM   #3
TAG UR IT
TAG UR IT's Avatar
Local shop.....Custom Sounds.
Old 01-05-2012, 01:22 PM   #4
TAG UR IT
TAG UR IT's Avatar
bump
Old 01-09-2012, 09:56 AM   #5
TAG UR IT
TAG UR IT's Avatar
Class D Circuitry
250W RMS @ 1.5 ohms - 4 ohms
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power
Frequency Response: 5 - 50,000 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm/50 Hz
Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
Differential-Balanced Input Topology: (1 pair of inputs)
On-board Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
Preamp Output: 2-channel (full-range, LP or HP)
Bass EQ: variable boost up to 15dB
Infrasonic Filter: defeatable 24dB/octave at 30 Hz
Signal-Sensing Turn-On: permits operation without remote lead
Dual mono speaker output connections: accept up to 8ga. wire
+12V and Ground connections: accept up to 4ga. Wire
Dimensions: 10.25"L x 9.25"W x 2.36"H
VERSUS THE SLASH V/2 JL 250/1 AMP
mono subwoofer amplifier
250 watts RMS x 1 at 1.5 to 4 ohms
Regulated, Intelligent Power Supply system
differential-balanced inputs variable low-pass filter (40-200 Hz, 12 or 24 dB/octave)
variable bass boost (0-15 dB at 48 Hz)
switchable infrasonic filter (-24 dB/octave at 30 Hz)
optional wired remote bass boost
Class-D amplifier design
MOSFET power and output stages speaker- and preamp-level inputs
preamp outputs
4-gauge power and ground leads and a 30-amp fuse recommended
10-1/4"W x 2-5/16"H x 10-3/16"D
warranty: 2 years
Old 02-01-2012, 11:44 AM   #6
TAG UR IT
TAG UR IT's Avatar
bump $150
Batmobile Fraxum Member Car Journals 51 03-16-2014 02:38 AM
Another ******** install - Phase 2 Fraxum Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 07-11-2011 10:39 PM
Changed Amp (PPI --> Polk Audio) Hicompression Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 02-23-2011 02:07 PM
Stereo GUIDE ALL READ WildBeast15 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 29 09-11-2010 02:14 AM
