| Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress. |
Thread Tools |
#1 | |||||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 45th Anniversary Edition SS Join Date: Jul 2011
The Nameless - 2SS 45th Vert NA LS3 Build Thread
I'm not huge on build threads, however this has been a very fun ride from picking the car up to the point it has become today. I'm hoping that by creating this thread I might be able to help others who are considering doing a similar build.
Backstory: I moved from Chicago to the San Francisco Bay Area in July. Living in the city we didn't have a need for 2 cars, not to mention any daily driver in Chicago would take a ton of abuse (that and parking spots started at $35k...). So when we got here I needed a car for myself, but mid Janurary thru November I travel 95% so I wanted something fun to enjoy the weekends when I'm home. Enter my 2SS 45th M6 Convertible on August 26th 2011. I won't lie, I didn't care that it was a 45th, it was all for the Carbon Flash paint~ Name: "The Nameless" is simply a result of me being unable to come up with a good name... Maybe I'll do a poll one day~ ![]() Research: After spending too much time absorbing all of the information on this site I went to visit all of the shops in the Bay Area. Ultimately I settled on Luke at Blu808 for his shop's sterling reputation and great service. I explained what I wanted to do and he steered me in the right direction for my budget. With a quick call to Anthony at LG Motorsports, Luke and Anthony began working on a solid package to begin the transformation of my car. Goals: The initial goal was to bring the car to the performance levels just before requiring a full cage on the strip/track. This equates to 11.5 ET on the strip, and so far all track events I have seen only require a roll bar. I also wanted to keep the car as reliable as possible as I want a car to have a blast in street and track. The end goal has become a strong balance of street and track so that the car can perform well in all scenarios Stock Impressions: From the dealer the car was a ton of fun, however acceleration was not anywhere close to what I was expecting from an advertised 426hp beast, and you could REALLY feel the weight of the car compared to a coupe on turns. The suspension is tighter than a coupe thanks to the additional reinforcement on the 2012 model (Undercarrage cross bracing, improved subframe bushings, strut brace), however still more of a Buick than a sports car. Since I'm a 'have your cake and eat it too' kinda guy I knew mods were in the works for this vert~ Step by Step Impressions: 1 - CAI A CAI is the first obvious step for this car. The honest truth is you will feel a difference, but the weight of the car hinders the butt dyno compared to the coupe. So all in all it is obviously a cost efficient mod, but just the start. 2 - VMAX Most people I have talked to in coupes swear they noticed throttle response. I honestly noticed no improvement at all. My personal opinion is this was a waste of money and do not advise. 3 - Borla S-Type Catback Wow the car sounded awesome after this swap, however I did pick up some drone, but manageable. If I gained any power it was negligible since I still had the stock pipes on it. The largest benefit I gained was shaving off a ton of weight ditching the stock exhaust. 4 - LG G6X3 Cam Package, Hurst Short Throw Shifter, ADM Race Scoop, LG Super Pro LTs, Tune What I picked up from Blu808 was NOT the same car I left them. Shedding even more weight and picking up a ton of power completely changed the car. Before I would tell you the car doesn't 'pull', it accelerates. Now when you go WoT you are thrown back in your seat, the exhaust roars to life, and it feels like you are on a rocket. Even handling was improved due to the weight loss. One of the things I enjoy the most is that the non cam power is sufficient enough to propel the car through the lower rpms so you get to the cam's power band quicker. I was considering a gear change prior to this, but it's solid as it is now with the stock gears. 5 - Suspension This is my first car where I have modified the suspension, or even had a good one for that matter. So you can imagine how impressed I am at such a small investment in suspension changed the car. Before on hard turns I would feel heavy body roll and the rear step out even at lower speeds. Now I am taking hard turns at high speeds and it is firmly planted. Steering is pinpoint accurate and solid. I cannot wait to see the change once I get my Pedders coilovers! Mods: Power Adders - 7/9 Complete LG G6X3 Cam Package - Installed 12/2/2011 -G6X3 Cam -Katech Chain -Comp Pushrods -Cam Gear and Tensioner -GM Water Pump Gasket Kit -Comp Cams Valve Spring kit with Titanium Retainers -Spring Seats/Seals -NGK TR6 Plugs ASP Underdrive Pulley - Installed 1/2/2012 LG Super Pro Long Tube Headers - Installed 12/2/2011 Borla S-Type Catback - Installed 11/26/2011 C.A.I. Cold Air Intake - Installed 10/21/2011 ADM Race Scoop - Installed 12/2/2011 Solo High Flow Cats - Installed 12/2/2011 LG CNC Ported LS3 Heads - Pending OZMO Engineering Carbon Fiber Intake Manifold - Pending Suspension - 5/6 Complete LG 35mm Front and Rear Sways with Endlinks - Installed 1/2/2012 Pedders Front Radius Bushing Inserts - Installed 1/2/2012 Pedders Subframe Bushing Inserts - Installed 1/2/2012 Pedders xA Street Coilovers - Pending Granatelli Adjustable Toe Rods - Installed 1/2/2012 Granatelli Trailing Arms - Installed 1/2/2012 Wheels & Tires - 0/2 Complete 19x9.5 Front - 19x11 Rear Wheels - Brand TBA - Pending 275/30-19 Front - 305/30-19 Rear - Bridgestone Potenza RE-11Pending Misc Functional - 3/3 Complete ![]() Hurst Short Throw Shifter - Installed 12/2/2011 Washer Bottle Relocate Kit - Installed 12/2/2011 VMAX Ported Throttle Body - Installed 10/31/2011 Misc Cosmetic - 0/2 Complete AAC Halos w/Foglight Halos (Color TBA) - Pending AAC Side Markers - Pending Photos: Mix of shots from when she was brought home, and my first detailing. ![]() ![]() ![]() ![]() ![]() Love the paint. ![]() Videos: Casual Start of Mines Rd After Cam Install Stock Dyno Dyno as of 1/21/2011 The "Dublin Wake Up Call" - I live in an apartment complex with a concrete parking structure. Cold starts can be loud... Inside displaying "cold" start volume and choppy idle Warmed Up Idle and Rev
I have exceeded the character limitation for mods in a signature...
Main Post Change Log
01/03/2012 18:47PST - Thread created 01/03/2012 20:54PST - Pictures added. Mines Rd video added 01/03/2012 21:57PST - Near stock dyno video added 01/03/2012 22:06PST - Mod list updated 01/03/2012 22:17PST - Mod list updated (keep forgetting things...) 01/05/2012 17:16PST - Step by step impressions added 01/13/2012 19:39PST - Added two videos showing volume and rough idle for a cold start 01/19/2012 18:35PST - Added info about tires and wheel sizes/selection.
Borla S-Type prior to install - Installed by local muffler shop.
![]() C.A.I. Cold Air Intakes - Self Install ![]() Sitting in line for my first pass on a drag strip with only the CAI, Catback, and VMAX installed. ![]() Best time @ 377hp / 383tq 13.1ET
Now begins the real build by Blu808.
Unfortunately we were not documenting the progress when the cam, long tubes, scoop, washer bottle, and Hurst shifter installs were done, so we do not have any pictures. So here is a picture of a bunny with a pancake on it's head stolen from some random website... ![]() After the fact pictures! LG Super Pro Long Tubes from below ![]() Solo High Flow Cats ![]() Washer Bottle Relocate ![]() ADM Race Scoop ![]() ![]() How the scoop was sent to us from Apex. Wonder how much HP the spider's cocoon gave us... ![]() Random picture of why I love canyon carving in NorCal
Suspension and UD Pulley installs by Blu808
From this point forward I was on site 'assisting' the installs. Truth be told the shop is a great bunch of guys who are happy to have you hang around and talk shop. I have been learning modifications and the more complex parts of how all the parts fit together, so they have been a great help in educating me in what I need to know. Huge shout out to Marcus at Blu808 for putting up with me for the time it took to do these installs, and Josh for the sandwich .Pedders Subframe Bushing Inserts - One thing to note is that the Pedders inserts do not fit into the 2012 vert without very minor modification. You just need to cut the ears off and then they fit perfectly. ![]() ![]() ![]() Granatelli Adjustable Toe Rods - Check out the difference between these and stock! ![]() ![]() ![]() Granatelli Trailing Arms vs Stock ![]() LG 35mm Rear Sway Bar Stock vs LG ![]() ![]() Installed ![]() Inserts, Trailing Arms, Toe Rods, and Rear Sway Installed ![]() ![]() ![]() ![]() LG 35mm Front Sway w/ Endlinks Stock vs LG, minor difference here... ![]() ![]() ![]() The LG was so large Marcus had to raise the engine by an inch to snake it in! Endlinks and Sway installed ![]() ![]() ![]() ASP Underdrive Pulley (25%) Just a wee bit smaller than stock, and built solid. ![]() ![]() Installed sans belts
#6 |
Luke has the weights listed for what we took out stock and what went in aftermarket. I'll let him post those when he can find them.
I will say that the stock pulley was 3 lbs heavier than the underdrive. Huge shout out to JusticePete at Pedders for working with me over a flurry of PMs to help me take advantage of the Pedders Christmas sale and pick up those inserts. Definitely great bang for the buck!
#7 |
Great start to your build thread.
I will find the weigh sheet for the parts. Maybe you should post up about how the car felt before and after the cam and suspension work. Luke |
#8 |
look like luke and the team did a great job one your car and i would see if you could get the ghost sidemarkers from aac. i want but dont have the money right now. but are you trying to save weight by going with 18's?
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT/RS ABM Join Date: Sep 2009
Nice!
1100 Order accepted at dealer: 9/15/2009 - NPGV41. 2000 Order accepted by GM: 9/29/2009 3000 Accepted By Production Control: 9/30/2009 - TPW 10/26/09 3100 Sequenced:10/12/09 3300 Scheduled For Production:10/13/09 3400 Broadcast:10/22/09 3800 Produced:10/27/09 4000 Available To Ship:10/28/09 4200 Shipped:10/29/09 5000 Delivered To The Dealer:11/09/09 6000 Delivered To Customer:11/12/09 |
#10 | |
I'm going 18 for a number of performance reasons. Better handling, acceleration, huge weight savings, tire cost. The difference with my build setup would be like adding another 80-100hp. Also keep in mind you effectively change your gear ratio when you go up or down in tire sizes.
#11 | |
Still loving the spiral interchanges at 80mph
#12 | |
#13 |
Needs Lowering
![]() Drives: Pedders USA Camaro Justice Join Date: Jun 2007
You have a great build going. I am now subscribed!
![]() Camaro Information | Buy Pedders Parts | Pedders Dealers | The 5th Gen Book | GMPP | SEMA Hot Wheels Camaro Brochure | EOD Fund Facebook Pedders Head Office 248.522.8021 |
#14 | |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
![]() Forgeline? Cant wait to get mine. Any ideas on what rim you want yet? Is that OZMO intake pending sale?!?!?
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
#15 | |
The next two steps are Pedders coilovers and a roll bar so I can make those track days. I'm listing the OZMO because it is of great interest. It would be my last power adder, so by the time I can afford it, we should have good numbers to determine if it is the way I want to go.
#16 | |
need....more....hp
#17 |
I'm at the beginng stage of research so I don't have my heart set on anything yet. All I know is I hear Forgeline is one of the best, if not the best.
#18 |
need....more....hp
Talk to Rick about ADV.1 and see what he has to say about dealing with them. I don't know of too many on C5 that have went with ADV.1.....just FYI.....
#19 |
Unless he has changed his opinion last I heard he was raving about them which is why they were a contender. All in all I like the designs of Forgeline so I may just go that route and call it a day. Can't wait to see yours when they come in.
#20 |
![]() ![]() Drives: 2013 ZL1 6M 2014 GT500 arrived Join Date: Nov 2011
Nice build
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert |
#21 |
It's coming along very nicely !! Can't wait to see what else you have in store !!
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
Looking and sounding great. It's amazing still how well these cars respond with even just a few modifications.
Can't see what is next for you and the car! ![]() Just yell at Luke and I. We are here for you!
#23 |
Quick note, the awesome camera I used for the Mines Rd video was on loan (the mother in law's xmas gift...) and my current camera can't capture low frequencys at all. Just did a video of the start up and since my exhaust is a deep rumble it didn't pick anything up lol... save it did get the car alarm I set off 7 stalls down
![]() Once I get a new camera I'll post some videos.
#24 |
Southwestspeed.net
![]() Drives: '10 2SS/RS, '96 Z28 Join Date: May 2009
YESYESYESYESYES!!!!
Incredible. Looks great and I KNOW it performs better with that slew of awesomeness that you've recently installed. Hope that you enjoy all of it! Ivan
#25 | |
http://www.camaro5.com/forums/showthread.php?t=193405 Many thanks, this project has come together very well thanks to everyone's help!
| Thread Tools | |
| TRI-COUNTY CAMAROS { TCC } | RedDragonSS | USA - Florida | 17668 | Today 12:39 PM |
| Zabo's '00 T/A Build Thread | CamaroSpike23 | 4th Generation Camaros | 505 | 05-06-2013 09:29 AM |
| DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 203 | 05-03-2013 09:23 AM |
| LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
| Dumbest Camaro5 Question EVER! | Beemer | 5th Gen Camaro SS LS LT General Discussions | 209 | 05-23-2010 06:11 PM |
