01-04-2012, 06:30 AM | #1 |
Drives: 2012 Camaro SS Join Date: Oct 2011
CEL after Solo HF Cats
How easy is it to damage a O2 sensor? All the plugs are connected everything is tight, no leaks and I got a CEL on the way home this morning. Only thing I can think of is I damaged a sensor but I didnt drop them bang them nothing. I'm going to swing by the parts store on the way to work and see what codes I get but I'm pretty dissapointed. I got the Solos just because they said they wouldnt trip a CEL.
01-04-2012, 07:11 AM | #2 |
Drives: 2010 Camaro SS LS3 Join Date: Sep 2010
I've ran the SOLO cats for over 20k miles. The only time I set a code was related to one of the the rear O2 extensions leaking. If your SOLOs came with the aluminum extenders, instead of steel, look real close at those. It doesn't take a very big leak to throw a code.
She is only memory now. |
01-04-2012, 07:52 AM | #3 |
should I just get a tune and forget about the rear O2's?
01-04-2012, 08:45 AM | #4 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
Your on the wrong forum is if you expect someone here to say dont get a tune. Lol
01-04-2012, 08:48 AM | #5 |
Drives: 2011 2SS/RS & 2017 1SS Join Date: Apr 2011
I just installed the Solo HF Cats not too long ago and my CEL came on, but I just pulled the neg battery cable and let it reset. It has not come back on since. Might just try that first.
2011 Chevrolet Camaro 2SS/RS L99 (1 of 782)
10.78 @125mph ALL MOTOR SBE Built/Tuned by Me 2017 Chevrolet Camaro 1SS Auto 9.29 @144.57mph ALL MOTOR SBE #TEAMGPI Gwatney Performance Innovation |
01-04-2012, 08:49 AM | #6 |
I dont care about the warranty I already cancelled the extended warranty they talked me into when I bought the car I was just hoping to not need one till the turbo. Thats why I did the solos instead of the LTs. I just want my car running right with no CEL
01-04-2012, 08:49 AM | #7 |
I'll try that for now but dyno tune is scheduled for a week from today.
01-04-2012, 09:24 AM | #8 |
Only drives on Sundays
Drives: '16 2SS A8 NPP MRC NGray Join Date: Feb 2011
First thing to check for is exhaust leaks. That will throw a code (lean).
But obviously you need to check the codes first. But don't lose hope. Padre |
01-04-2012, 09:55 AM | #9 |
I don't feel or hear any leaks and I checked the manifold to mid pipe bolts they were tight
01-05-2012, 03:56 PM | #10 |
P1153 was my CEL DTC. What gives? I read a bunch of posts and this usually happens when guys put on LTs and don't tune. Any suggestions?
01-05-2012, 04:37 PM | #11 | |
What other mods do you have and did you use any RTV silicone to seal the shorty header gaskets? Padre |
01-05-2012, 04:45 PM | #12 |
Nope used the gaskets that came with the solos, I have a roto fab cai and a x pipe, res delete and pypes pipe bomb axel back
01-05-2012, 04:54 PM | #13 |
Read over this:
http://www.ls2.com/boggs/dtcs/DTC%20P1153.htm It will give you an idea what's happening, but there's lots to do to determine if the O2 sensor is bad or if your mods have caused it to read unexpectedly. If the sensors are good and there are no leaks and the car otherwise is OK, probably the only option is to tune them out. Padre |
01-05-2012, 05:18 PM | #14 |
Read it and basically I either have a leak or need a tune which shouldn't be since solo claims no cel.
Similar Threads | ||||
GMPP Performance Exhaust + Solo High Flow Cats Sound | fedormma | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 11-11-2011 06:41 PM |
2010 Chevrolet Camaro 2SS RS L99 A6 - Solo Performance Cats & Exhaust with J-pipes | VictoryMuscleCars | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 09-10-2011 01:17 PM |
Need some help....LS3 Solo cats on L99? | AC | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 06-12-2011 09:42 PM |
Solo High Flow Cats Installed | Strokedhog | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 08-08-2010 02:42 PM |
Modern Muscle Exhaust and Intake Special | modern-muscle | V8 Bolt-Ons & Tunes | 1 | 01-20-2010 06:46 PM |
