Old 01-04-2012, 09:55 AM   #1
TRABlackCamaroSS
TRABlackCamaroSS's Avatar
Drives: '10 Blk Camaro SS/'08 Blk Silverado
CEL after catch can install
Installed a new Elite catch can on my L99 and after a day got a lean code CEL. Had the GM mech clear it but a day later came back. Anyone have the same problem after installing a catch can?
Checked all install procedures again to make sure it was installed right......
Really wanted a CC on my engine but if it will carry a CEL all the time is it worth it?
Any suggestions?
TRABlackCamaroSS is offline   Reply With Quote
Old 01-04-2012, 10:25 AM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Not familiar with the Elite but the first thing that comes to mind is, are the connections correct and tight/sealed? A leak in the system will def cause probs. FWIW, I have the RX can and no probs. So you can have a CC and no CEL....
If you can't get it sorted, return it and get an RX?
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-04-2012, 10:29 AM   #3
Camaro21
Drives: SOLD - 2013 M6 ZL1
I had the Elite Engineering Catch can before my latest upgrades and didn't have a check engine light. Like hypurone said, make sure to check all of your hose connections and make sure that nothing else came off while installing it...
Good Luck.. BTW, do you know what the code # is?
Camaro21 is offline   Reply With Quote
Old 01-04-2012, 10:35 AM   #4
gelboy1015
gelboy1015's Avatar
Drives: '10 2SS/RS, MKIII Supras
As everyone has said, check your connections. This guy had a code as well that they narrowed down to the catch can having a loosened drain.
http://www.camaro5.com/forums/showthread.php?t=172698
2010 Camaro 2SS/RS
- LS3, M6. -
Build Thread/Mods List
gelboy1015 is offline   Reply With Quote
Old 01-04-2012, 11:02 AM   #5
Parag
Drives: 2010 camaro 2SS LS3
Did you connect a breather, because if you did it will be pulling outsude air into the crank and then back into the intake
Parag is offline   Reply With Quote
Old 01-04-2012, 11:33 AM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
Check the connections where it's connects up to the intake plus check the drain plug. Don't know how the drain plug is on the elite but the RX can has twist one at the bottom. If it's even slightly loose it could suck in are and cause it to be lean.
As long as the can is sealed properly and all the connections are done properly it shouldn't give you a CEL.
Build Journal
Old 01-04-2012, 11:41 AM   #7
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Yeah, just like everybody has stated, make sure all hoses are on tight, and the cup is on tight. We've never seen any problems with the Elite can and a check engine light, unless something went wrong during install.
An Elite can does not have a drain, it allows you to remove the cup and clean it out very easily, but if the cup is not installed all the way (with the seal in place), you could have problems. Ditto on the breather, if its not one with a check valve, you may have problems there.
Did you remove your throttle body, or intake pipe during installation? Check those if so.
A lean code usually indicates there is an unmetered amount of air entering the engine, so there's got to be a leak somewhere.
Feel free to call, email, or PM us anytime!
- Jeremy
JDP Tech is offline   Reply With Quote
Old 01-04-2012, 11:52 AM   #8
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
is your o-ring in place?
Old 01-04-2012, 03:03 PM   #9
SC2150
If a breather is used the OEM fresh air line needs to be removed and the barbs/fittings capped. Then, if it is just an open breather you will throw CEL light due to the unmetered excess air entering confusing the ECU as it is using the data from the MAF & the upstream O2's then it adds or subracts fuel as needed. If you add a breather that is unrestricted then this data confuses the ECU and the fuel trims will go crzy trying to compensate. The RX breather has a flow calibrated checkvalve that only allows the proper flow that the ECU can adjust to. So that may be your issue.
Old 01-04-2012, 04:50 PM   #10
TRABlackCamaroSS
Thanks everyone for the good info! will reinstall and check connections along with the CC seal.
Install Catch Can Driver Side larryt1026 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 32 02-02-2012 07:20 PM
Elite Catch Can Install Smirnoff Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 12-22-2011 03:50 PM
Catch can install and error code NateSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 03-03-2011 07:03 PM
C.A.I. install and Elite Engeneering Catch Can install Brianskeet Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 02-24-2011 02:40 AM
Catch Can Install.... Rage Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 08-03-2010 12:15 AM
