Emblempros
Old 01-04-2012, 01:49 PM   #1
Rabamaro
Drives: 2010 ABM SS/RS
P0137
Anyone with LT's and HF cats throw this code? I never threw a P0420 or 30 in the 5-6 months I've had the headers. I've already got the extensions and O2 spacers. The CEL was intermittent at first but is now staying on. I'm due for inspection this month!
Vararam Tune CAI, Vararam Power Wedge, 160 degree stat, VMax ported throttle body, Ceramic coated ARH 1 7/8" LTs with X-pipe, Borla S-Type Axle back, MGW short throw, 3.91s, Ported stock IM, BTR Stage IV cam, Heritage Grille, Backup camera, UMI Performance trailing arms and toe rods, dyno tune
Rabamaro is offline   Reply With Quote
Old 01-04-2012, 02:24 PM   #2
13 ZL1
13 ZL1's Avatar
Drives: 2013 IOM ZL1
Get a scan tool and check your LTFTs. You may be running lean and need a tune.
13 ZL1 is offline   Reply With Quote
Old 01-04-2012, 02:54 PM   #3
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Low Circut voltage Bank 1 sensor 2.
You need a Tune to pass inspection.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 01-09-2012, 11:52 AM   #4
Rabamaro
So replacing the sensor won't fix this I assume?
Old 01-09-2012, 12:35 PM   #5
BLACK10
BLACK10's Avatar
Nope
Old 01-09-2012, 02:07 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
That's for the rear sensor on the passenger side?
If so then Ted's right. Get a tune and have those sensors turned off.
I wonder if you put back on the factory headers would the CEL still be on since it sounds like an issue with the sensor. That could be an option as well. Put the factory headers on and if CEL is still there then take it to the dealer have them fix and inspect it while it's there. If the CEL goes away then get it inspected while the headers are off. A PITA but it might work.
Build Journal
Old 01-10-2012, 08:48 AM   #7
Rabamaro
Thanks for all the input. Looks like a tune is in my near future.
