BeckyD @ James Martin Chevy
Old 01-04-2012, 03:46 PM   #1
CGT
Drives: 2011 SSm6
3 bolt cam gear tensioner compatibility
I have done a couple 3 bolt conversions in the past, while also changing the tensioner 12626407 for dampener 12581276. I have mocked up the three bolt gear with the stock tensioner but the chain felt excessivily tight. I always figured there must be a very slight difference somewhere between the 1 bolt and 3 bolt gears making the dampener necessary when changing to the 3 bolt design. Recently I have seen pictures here and elswhere showing the 3 bolt gear being used with the tensioner assembly. Can anyone comment on this, Jannety, TSP, ADM, etc. What do you guys do when converting?
CGT is offline   Reply With Quote
Old 01-04-2012, 03:51 PM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
There are several 3 bolt gears, which one do you have?
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 01-04-2012, 03:55 PM   #3
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
so just to be clear,not to hyjack thread,sorry,do we absulutely have to change the tensioner on the ls3 when doing the cam swap,i heard there was problems with both tensioners failing
bcguy is offline   Reply With Quote
Old 01-04-2012, 03:56 PM   #4
JANNETTYRACING
No to each his own.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 01-04-2012, 07:19 PM   #5
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
Tensioner assembly
Teds comment is on point, to each his own. If you can take a hint from GM Powertrain division, the LS3 and LSA motors all use the same tensioner style part. Those being the most current motors released by GM you should take the hint that those are their newest and best design for the application.
Changing the stock LS3 tensioner to some other style requires removal of the oil on while the motor is in. That project will cause you far more grief than a simple tensioner. Ask anyone who has changed a pan gasket on the C5 .
Good luck.
Go Fast Kid is offline   Reply With Quote
Old 01-04-2012, 07:22 PM   #6
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
There have been several found broken on simple cam swaps and a few others broken after the single bolt cams broke. But those ones are not necessarily known to be the cause of the failure.
Old 01-04-2012, 08:09 PM   #7
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Agreed, each person can choose what they want, both configurations will work, and many will not have any problems.
We always use the 3-bolt cam sprocket, and dampener. Pulling the oil pump off in the car is not very hard to do.
Though it is true the LSA, LS3 and L99 all use the same sprocket and tensioner, the badder boy engines (LS9, LS7, and dry-sump LS3) all use the 3-bolt sprocket and the dampener. When changing the cam in these LS3/L99s, we get similar power to the LS9 and LS7, plus the three bolt design and dampener are more dependable, so why not spend the little bit extra for insurance?
The reason the LSA, LS3, L99, and almost every other V8 engine GM makes (trucks, SUVs, cars, etc) all have the exact same cam sprocket and tensioner, is because it works and is cheaper to do, and thats what they're after. If it was better, why would the premium engines (LS9, LS7, dry sump LS3) be different?
- Jeremy
JDP Tech is offline   Reply With Quote
Old 01-05-2012, 04:56 AM   #8
Stingr69
'69 Owned Since '79
Stingr69's Avatar
- Jeremy
They use the same tensioner on the LS9 as they use in the LS3. I have seen the factory assembly video.
-Mark.
Old 01-05-2012, 10:10 AM   #9
CGT
Drives: 2011 SSm6
I am using 12586481 gear. I am putting a LS7 cam in my personal car,2011 SS LS3. I have the cam, gaskets, etc. And figure, what the hell. I have more time than money right now. Which dampener or tensioner would you use Ted? Gonna try and knock this out Saturday morning. Thanks for your response.
Old 01-05-2012, 10:30 AM   #10
CGT
Drives: 2011 SSm6
- Jeremy
LS7 is the only current ls that i see using the dampener. LS9, LSA and all LS3's dry and wet sump show using #12626407 Tensioner assy. The dampener definitely has no moving parts to fail, I like that about it for sure. Just wonder why they made the switch.
Old 01-05-2012, 10:46 AM   #11
JANNETTYRACING
The Spring loaded tensioner is Preferred method for a timing chain but we have seen a few broken upon disassembly so confidence is only about 90% on them
I like them because they reduce noise that the Knock sensors can pick up and they keep the chain snug all the time which reduces what I will call Snap Tensioning on the chain or Whipping of the chain.
So Again to Each his own.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 01-05-2012, 10:54 AM   #12
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
http://www.camaro5.com/forums/showth...=ls9+tensioner
post #21
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 01-05-2012, 10:57 AM   #13
CGT
Drives: 2011 SSm6
Thank you Ted. Never considered the knock sensor thing, seems logical. I think ill give the stock tensioner a whirl. I have the dampener also, if i change my mind. So you have used that three bolt gear 12586481 with the stock tensioner i assume?
Old 01-05-2012, 11:48 AM   #14
JANNETTYRACING
That is the correct gear number.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Small cam pushrods and cam gear b20 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 12 05-14-2011 08:21 AM
Shop help please...toe arms cam bolt measurement robsls3 Suspension / Brakes / Chassis 2 03-17-2011 01:16 PM
installing hot cam logan1080 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 11-23-2008 07:12 PM
