Old 01-05-2012, 09:09 AM   #1
DuhKoDuh
DuhKoDuh's Avatar
Drives: 2011 Camaro 2SS/RS (Black) L99
Question Im confused.
my friend is taking his car to a car shop nearby and he said he is getting his heads milled and new gears in his l99? what is he talking about and will that get him any power? thanks!
Follow me on Instagram @C7Corvettes
DuhKoDuh is offline   Reply With Quote
Old 01-05-2012, 09:19 AM   #2
Synyster
Synyster's Avatar
Drives: 2006 F150 Lariat
Probably just porting the heads and throwing in shorter gears in the rear end. The heads should gain him some power and the gears will make the car accelerate like a bat outta Hell.
Synyster is offline   Reply With Quote
Old 01-05-2012, 09:21 AM   #3
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Milling will increase compression, so yea he'll definitely see some power.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 01-05-2012, 09:23 AM   #4
DuhKoDuh
DuhKoDuh's Avatar
how much is it? and is it worth it?
Old 01-05-2012, 09:44 AM   #5
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: 2010 SIM 2SS/RS A6 SC LPO Rallies
Send a message via AIM to hypurone Send a message via MSN to hypurone Send a message via Yahoo to hypurone
Cost depends on the shop and level of machining done. But ballpark could be in the neighborhood of 1K. As for being worth it? That is subjective. Porting won't get him all that much as these heads flow very well stock (and MUST be re-tuned if ported). It depends on how much they are going to raise the compression, if the grade of fuel available can withstand it and whether or not they plan on doing any tune work with it. If he is going to tune it and void the warranty, I can think of other things that would make a much bigger difference and cost the same roughly...
Gears will make a big diff in acceleration but don't add any HP, just amplify what's there....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 01-05-2012, 09:49 AM   #6
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Originally Posted by Synyster View Post
... the gears will make the car accelerate like a bat outta Hell.
Definitely. I was amazed how much 4.10 gears transformed the way my SS takes off and accelerates--still my favorite mod I've done, so far.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 01-05-2012, 10:52 AM   #7
DuhKoDuh
DuhKoDuh's Avatar
hes getting it done by LG. so i should look into what he is doing also?...after i get my headers and cam? he already has LG headers g6x3cam lg intake and lg tune
Old 01-05-2012, 12:16 PM   #8
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
Given he already has our cam in the car, you can mill the heads and get away with more compression on the car and still run it on 93. Big cams like the G6X3 love compression because the cam will 'bleed' off some dynamic compression.
Just milling the heads on a stock LS3 car might not be the best option as the factory cam has a lot of dynamic compression.
As with anything, the combination needs to be matched.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 01-05-2012, 05:27 PM   #9
hypurone
hypurone's Avatar
@LG's response above sums it up pretty much. I would have thrown that in my explanation but it wasn't stated that a "cam" was already done in your original post. This makes porting/milling more of a gain...
Old 01-05-2012, 10:36 PM   #10
CosmicBrut
CosmicBrut's Avatar
Drives: 2011 CGM 2SS/RS L99
I have a question anthony, it might have been answered already but I'm curious. Do you have to cut valve reliefs in the pistons when you put the g6x3 in a ls3 with stock heads? Also if you put the g6x3 in a l99 motor(of course changing the lifters and getting rid of the cam phaser) how much can you raise the compression by milling the stock heads before ptv becomes an issue?
2011 SS/RS A6
TSP 229/236, TSP ported heads, FAST 102 intake, Vmax ported throttle body, Circle D 3200 stall, CAI cold air intake, Kooks complete system, installed and tuned by ECS 11.36@121
CosmicBrut is offline   Reply With Quote
Old 01-06-2012, 12:36 AM   #11
DuhKoDuh
DuhKoDuh's Avatar
Thanks Anthony!
Old 01-06-2012, 03:03 PM   #12
If you keep the engine stock, LS3 or L99, the G6X3 fits just fine without fly cutting the pistons. If you are wanting to go to a thinner gasket, and mill the heads, yes you will have to cut the pistons for it to fit.
Camaro with a confused identity alex5252 5th Gen Camaro SS LS LT General Discussions 23 08-02-2011 01:53 PM
Confused: Amp to Sub wiring KTMracing09 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 7 07-26-2011 12:18 AM
CONFUSED About HP jatt5ab1soorma Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 14 07-25-2011 08:42 PM
Am confused!! Rashed 5th Gen Camaro SS LS LT General Discussions 50 12-03-2010 07:28 PM
Confused Bikers Big Brunsy 5th Gen Camaro SS LS LT General Discussions 11 03-16-2010 05:47 PM
