Old 01-05-2012, 04:38 PM   #1
Shadow Camaro
Shadow Camaro's Avatar
Drives: Rally Yellow 2010 Camaro 2SS/RS M6
P0455?
I get this code an I think it's because of my headers. I've been looking around and it looks like other people are getting different codes. Anyone else got this one? Code ready says evap system leak (large).
Does anyone know if spark plug defoulers would fix this code? Thanks.
Rotofab CAI, SW LT Headers and High Flow Cats, SW Cat-Back, Eibach Pro rear wheel spacers, SS Grill Insert, Street Scene Front Splitter, Blacked out rear emblem, blacked out bezels, plasti-dipped lower bumper, plasti-dipped rims with yellow pinstriping, dyed interior stitching yellow, 2x Kicker CVR 12's w/ 1200 watt kicker amp. MORE TO COME!
Shadow Camaro is offline   Reply With Quote
Old 01-05-2012, 06:57 PM   #2
Shadow Camaro
Anyone know?
Old 01-05-2012, 07:18 PM   #3
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Make sure you gas cap is tight or it could be bad. It is a evap code so it is emissions related.
Crime2 is offline   Reply With Quote
Old 01-05-2012, 09:23 PM   #4
caverman
caverman's Avatar
Drives: '69 SS Convertible
If it's an evap code, check on the passenger side of the motor. There is a hose that's part of the evap system. The other day when I was having CEL issues and ADM was looking over my car he saw mine was kind of pinched. Piched because of the engine cover. He said if it gets pinched enough it could throw an evap code.
Build Journal
Old 01-05-2012, 10:38 PM   #5
greenmachinedriver
greenmachinedriver's Avatar
Drives: white 2010 ss and 2011 6.2 silvy
There is a leak in your evap system. This is not directly related to your headers. How long have your headers been on? If you put them on recently you might have just bumpef somthing loose when you were working on it. First step is check and make shure your gas cap is tight. If there are no obvious leaks or bad conections you might have to take it to the dealer so they can run a smoke test on it.
2010 RS2SS, XS POWER HEADERS AND FULL EXHAUST, ROTOFAB COLD AIR AND ENGINE COVERS, MSD PLUG WIRES. PFADT DROP SPRINGS, SPORT SWAY BARS, TRAILING ARMS, TOE LINKS. HURST SHIFTER, BILLET PEDALS.
BLACKOUT TAIL PANEL, TINTED TAIL LIGHTS, MAIL SLOT BLACKOUT, WHITE BOWTIES
greenmachinedriver is offline   Reply With Quote
p0455 error after whipple install bigsquirrel Forced Induction - V8 6 12-10-2010 03:25 PM
