Old 01-05-2012, 09:38 PM   #1
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
Cat delete shortie headers worth it ? Turbo car
My car is an L99 with a turbonetics T 76
Was looking into a few different things and I figured id see what people on here thought
Are shorty headers worth it with a Turbo car ?
was thinking of getting ARH shortys
Is deleting the cats ( with stock manifolds ) worth it ?
Thanks in advance .
1969to2010 is offline   Reply With Quote
Old 01-05-2012, 11:29 PM   #2
HaddadMotorsports
HaddadMotorsports's Avatar
Drives: Camaro
Leave the stock manifolds alone. The cast manifolds do a great job coping with the heat. and they're not as restrictive as your turbo is. Not to mention, fitment is already tight with these systems, You'll make way more problems than its worth to change anything in that area.
Get rid of the the cats (JBA makes a catless connector that we have used in the past on turbonetics systems), make sure you have a good free flowing "turbo back" exhaust, add a boost controller, and get re tuned.
You should easily and safely get another 50rwhp out of doing this.
After this your next limit will be your fuel system and then your engine
Thanks
Mike Haddad
HaddadMotorsports is offline   Reply With Quote
Old 01-05-2012, 11:34 PM   #3
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Not to thread jack but who makes good turbo back systems?
Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it.
Crime2 is offline   Reply With Quote
Old 01-05-2012, 11:37 PM   #4
1969to2010
The Man in Black
1969to2010's Avatar
Thanks brother the whole exhaust is the turbonetics kit except the axle back I have spintech axle back now but im adding arh soon
Thanks so much
Im saving for a fuel pump and a boost controller
Sent from my DROIDX using Tapatalk
Old 01-06-2012, 12:41 AM   #5
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Thanks
Mike Haddad
Just like what Mr. Haddad said!
Z_Rocks is offline   Reply With Quote
Old 01-06-2012, 12:50 PM   #6
2010 4 DW
Drives: White 2010 RS/SS
Shorty headers will not fit with the Turbonetics kit. Get the non catted mids and you will pick up some good power.
2010 4 DW is offline   Reply With Quote
Old 01-07-2012, 08:01 PM   #7
SS420
SS420's Avatar
Drives: '10 Camaro 2SS/RS Cyber Grey 6M
I did a cat delete on my TT setup and gained 30rwhp
SS420 is offline   Reply With Quote
Old 01-07-2012, 08:04 PM   #8
1969to2010
The Man in Black
1969to2010's Avatar
Does the car have to be tuned right away or can it be driven? Id have to install cat deletes then get it tuned a few weeks later don't have the time to do it any other way
Old 01-07-2012, 08:31 PM   #9
SS420
SS420's Avatar
It depends. I had mine done at the same time. Sometimes its needed to get rid of the check engine light. Good question though. I think its fine but I don't know if the computer could think there's a problem after a long time and then change the fuel mixture. If you're going to have a lapse in time between the delete and tune then the best thing is with some spark plug antifoulers to add a void between the exhaust pipe and oxygen sensor.
Old 01-09-2012, 12:03 PM   #10
HaddadMotorsports
Drives: Camaro
You can drive the car safely without retuning, but I would not recommend driving under boost or anywhere near full throttle. The gains will be substantial getting rid of the cats, and your tune will need to reflect it.
and you will most likely pick up some bs codes until ya get it tuned.
Thanks
Mike Haddad
Old 01-09-2012, 12:08 PM   #11
HaddadMotorsports
Drives: Camaro
Any dual 3" system with straight through mufflers, or no mufflers at all, will work just fine. That covers about half the manufacturers out there.
I personally do not like any of the new "fancy" exhaust technologies. Every time, they've made it to my dyno. I've takin them off and picked up serious HP going back to a nice straight through. (I can see staight through it )
Thanks
Mike Haddad
Old 03-25-2012, 10:23 PM   #12
1969to2010
The Man in Black
1969to2010's Avatar
did a search on this and found my own thread pretty cool
Old 07-18-2012, 05:27 PM   #13
robbiegordon
Robert
robbiegordon's Avatar
Drives: 2011 Summit White SS LS3
So I currently have Jba catless mids ...when I buy my turbonetics kit will I need a custom tune or different injectors/ fuel pump to keep my motor safe ? I don't Plan on doing much else after the kit , and I'm not looking to make 600 hP or anything. Just looking to run an otherwise stock motor with a turbonetics kit
Turbonetics T76 10psi with aem truboost controller, 231/239 115 LSA Comp Cam, adm fpcm, zl1 pump, Tr7ix plugs, 3.91/1LE Gears,Melling Oil pump, custom intake, catless midpipes, powerbond 25% underdrive, PFADT Aluminum subframe bushings, 1.5 inch drop, PFADT sway bars, BMR; sub frame connectors ,Trailing arms, Toe Rods, strut tower brace and rear diff bushings, Hurst short throw shifter and line lock,dyno #s TBD, , tuned by Pat G tuning
robbiegordon is offline   Reply With Quote
Old 07-18-2012, 05:36 PM   #14
uniqueskillz
uniqueskillz's Avatar
Drives: ETMC built 700+hp Twin Turbo LS3
I had my cats gutted and have a 3 inch exhaust from the turbos back. you should be fine with the stock headers. there perfect for turbos. (I had ARH long tubes but took them off and got a set of BBK shorties.)
uniqueskillz is offline   Reply With Quote
How to Read a General Motors Invoice (2012 Camaro) The_Blur Camaro Price | Ordering | Tracking | Dealers Discussions 61 08-18-2016 12:26 PM
How to Choose the Best Car Cover for Your Camaro Junkman2008 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 27 02-27-2015 04:10 PM
Understanding Paint Correction-The Nitty-Gritty Mr CLuTcH Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 29 03-02-2012 04:51 AM
Gran Turismo 5 November 24th, 2010 Nezacant Gaming Lounge 562 04-21-2011 10:23 PM
Transmission output shaft hiller72 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 267 12-02-2009 09:39 PM
