01-05-2012, 10:36 PM | #1 |
Banned
Few questions. on the oil and 2 screws im missing
well i have a few questions. today i got back on my car since i was on vacation to notice that the dealership never filled up my oil, but had put a little so i went ahead and stopped at a autzone and filled up with Mobil 1 Extended Performance..is that oil good or bad? its the 5w-30
here is a picture http://carservicetoday.com/_cache/Oi...B000SKV4P2.jpg also the screws on the tunnel brace or bracket that is under the car by the cats...well somehow they ended up getting loose and both flew out and i dropped the brace/bracket but recovered it! so i wanan know what size of screw they need? anyone know where i can find that? |
01-05-2012, 11:06 PM | #2 |
Drives: 2011 LS Join Date: Oct 2010
Good oil just confused about the problem. Did the dealer not fill it up fully? That would be odd under your circumstances. If so to what line on the dipstick was it?
01-05-2012, 11:30 PM | #3 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
+1 on the oil.
Is the bracket you're talking about the black one that is 5" wide and about 18" across and sits across the resonators? If so, that takes 4 bolts. They take a 15mm wrench and are an inch or so long. heavy bolt- should have been in pretty tight! You could check on the V8 Eng. forum. Some of those guys replaced those to install 3" pipes and needed longer ones. If you don't get a response, I could pull one of mine and check it at Home Depot tomorrow! Should be O.K. to drive a bit without it. |
01-06-2012, 06:04 AM | #4 |
Let's go Rangers!
I've heard a few people on this forum say NOT to use the extended performance oil. I'm not 100% why, just telling you what I read.
01-06-2012, 06:17 AM | #5 |
Banned
Welll I only used 2 bottles so I can run for. Bit. What oil should I use? Also yes its the long brace that goes from one side to another near the back...what bolts size does it use I need to find them
01-06-2012, 06:31 AM | #6 | |
Drives: 67 Camaro Convertible Join Date: Jun 2009
You are the one who's engine was cooked and replaced by the dealer (most likely because of low oil) You have the engine replaced by the dealer and they deliver your car with a new engine, and short the original oil fill by 2 quarts?????
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof Placed order at dealer 4/24/09 1100 - 4/28/09 2000 - 5/01/09 2500 - 5/05/09 3000 - 5/05/09 3300 - 5/30/09 3400 - 6/05/09 3800 - 6/18/09 4000 - 6/18/09 4B00 - 6/18/09 4200 - 6/22/09 5000 - 7/01/09 6000 - 7/01/09 It's Home!! 0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less |
01-06-2012, 06:33 AM | #7 | |
Winners find a way
Drives: 2010 2LT/RS M6 Join Date: Jun 2010
And they left the bolts loose on the tunnel brace, I'd march my a$$ right back to the dealer...... |
01-06-2012, 07:36 AM | #8 | |
Let's go Rangers!
01-06-2012, 07:53 AM | #9 |
Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
interesting how this kind of stuff continually happens only to some people...
Yeah, I'll get around to it...
01-06-2012, 08:03 AM | #10 |
So between panda and myself....we have an instance of improper installation of the oil filter on my car and low oil and bolts missing on the tunnel brace on panda's car.
Maybe GM needs to do some quality control on these dealer service shops?
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
01-06-2012, 08:23 AM | #11 | |
Let's go Rangers!
Your issue was not noticable till driven. His issue should have been seen the minute he picked up the car! the 1st thing he should have done was checked the oil before taking posession and raised holy hell and refuised to take the car if it were even the slightest bit low. |
01-06-2012, 08:38 AM | #12 | |
But I still don't blame him though.....the install should be the last of our worries. I mean they are certified right?
Formerly owner of:
01-06-2012, 08:51 AM | #13 |
Banned
yeah im heading to the dealer to tell them to FILL ME UP!
01-06-2012, 08:56 AM | #14 |
Let's go Rangers!
dude in all seriousness, if you are 2 qt's low you better say a lot more then "FILL ME UP"
Similar Threads | ||||
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping! | JDP Motorsports | V8 Bolt-Ons & Tunes | 137 | 08-13-2014 03:06 PM |
How to see if oil is in intake manifold? | CamaroC-17 | 5th Gen Camaro SS LS LT General Discussions | 53 | 03-23-2011 05:06 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 09:47 AM |
