Old 01-05-2012, 11:44 PM   #1
b20
Drives: 2013 1LE RS 1SS
thinking about putting this smalll cam in or selling it
its a used cam in good shape
comp cam
224-228 with .534-.537 lift on a 112 lsa
should be good all around cam for a ls3 and use stock springs
what power do u guys think it will make
i am at 400 whp and 390 wtq
thanks david
b20 is offline   Reply With Quote
Old 01-06-2012, 09:50 AM   #2
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
I'd go bigger. Those lift numbers aren't going to do a set of LS3 heads much justice.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 01-06-2012, 10:42 AM   #3
nycoupe11
Drives: 2011 2ss/rs Summit White
Id go a little bit bigger. Cams themselves are not expensive. the install is more of the problem. good luck!
2011 2ss/RS Summit White / Grey and Black Interior. TSP VVT-2 Cam, ARH heads and Exhaust, CAI, Ported Throttle Body, Plasti Dipped tailight bezels and rims. AAC interior lighting. Tuned by East Coast Supercharging.
nycoupe11 is offline   Reply With Quote
Old 01-06-2012, 12:07 PM   #4
Blu808
Blu808's Avatar
Drives: Hankook Formula Drift Camaro
Send a message via AIM to Blu808 Send a message via Yahoo to Blu808
I'd go bigger. I'd also recommend upgrading your valve train. Keeping stock springs and other parts such as pushrods, and your seats and retainers will be the weak link.
PM or call me and we can talk about other parts that should be upgraded when doing a cam swap.
Blu808 is offline   Reply With Quote
Old 01-06-2012, 12:15 PM   #5
Falundir
Falundir's Avatar
Drives: 2017 1SS 1LE - Hyper Blue, P85DL
Originally Posted by Blu808 View Post
I'd go bigger. I'd also recommend upgrading your valve train. Keeping stock springs and other parts such as pushrods, and your seats and retainers.
This
Talk to Blu808. They did right by me.
Falundir is offline   Reply With Quote
Old 01-06-2012, 03:09 PM   #6
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
Talk to the guys at Blu808 or give us a ring to talk about different setups. They have installed a lot of our cam packages and run them in all of their cars as well.
That is a pretty small cam, and given the work that it takes to put a cam in the car and tune it, do it once and do it right.
Also if you are going to put a cam in the car, make sure you upgrade the rest of the items in the car with it. Stock springs are ok for a stock cam, but when you start to add lift and duration to it, you need to make sure the rest of the valvetrain can hold up to the increased cam size.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 01-06-2012, 03:27 PM   #7
dshep214
dshep214's Avatar
Drives: 2011 Camaro 2ssRS Ls3
If ur going through all the Hassal of installing a cam and get a tune I would go bigger. Good chance u will be disapointed after spending the money and only minimal results.
dshep214 is offline   Reply With Quote
Old 01-06-2012, 03:50 PM   #8
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
I would run it... I bet it would make at lest 30-40 more at the wheels with a good boost in torque. The lift is on the low side ( smaller then the stock ) but hell some guys are making 450hp at the wheels with a gm hot cam( .525 lift). If you can do your own install and you already have the cam... why the hell not! I think it would be a good street cam.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-06-2012, 03:58 PM   #9
Bad70supreme
Another thing, these big cams everyone are running I dont feel are the best for a stock geared heavy car like this. How many guys are still running 12s with cams They make big power but I think a smaller cam would run harder on the track with a more usable RPM rang. Just my 02.. Put a 4.10 gear with a big cam is hole different story.
Old 01-06-2012, 04:44 PM   #10
dshep214
dshep214's Avatar
Don't try running a guy with a big cam from a roll with the stock gearing either or he will eat u alive. But I agree that's y I'm going 4.10 gears at se point.
Old 01-06-2012, 08:34 PM   #11
Falundir
Falundir's Avatar
I'm keeping stock gears. You have to take into account for other power adders. I can launch at 2200, stick, and gain hard accel with everything else before hitting the powerband of the cam. The benefit, solid accel without traction issues.
Give me sticky tires and 18s and I can run 11s all day.
Old 01-07-2012, 01:22 AM   #12
Bad70supreme
This... thats is the same way I feel. I am doing a voodoo 222/224 .565 lift in march, I feel thats a solid cam for a stock gear! Until I get the tire setup I want and a 4.10 I dont see a reason to have such a big cam! I have had a over cammed car before... it SUCKS, if you dont have the gear forget it you loose to much down low, even mid range wont be as good. These cars make plenty of top end just with boltons, I feel that adding to the mid range power of the motor will actually make the car much faster and more balanced!
Old 01-07-2012, 02:51 AM   #13
b20
i have put many cams in
i had a ls9 cam in my my other set up ran strong 435whp and 429wtq
a cam swap is only 3-4 hours without doing springs
i do my own work and tuning so its only parts cost
big cams are for sound only
my car wieghs in over 4200 with me in it so sound and tq is what i am loooking for
Old 01-07-2012, 02:52 AM   #14
b20
i could over come the lift with rockers
5th Gen Z28, Gen V Engine. thePill Camaro Z/28 Forum - Z/28 Specific Topics 58 04-04-2012 06:50 PM
thinking of selling am I crazy? ls6 zo6 5th Gen Camaro SS LS LT General Discussions 45 08-17-2009 08:56 AM
THINKING OF SELLING MY CAMARO ssarrival 5th Gen Camaro SS LS LT General Discussions 43 07-30-2009 09:52 PM
Crazy for thinking of selling my '68 and getting a 2010 ls6camaro 5th Gen Camaro SS LS LT General Discussions 54 11-06-2008 04:56 PM
Thinking of putting a deposit down Lifted07Sierra 5th Gen Camaro SS LS LT General Discussions 9 08-13-2008 07:27 AM
