sjm autoprod
Old 01-06-2012, 01:16 PM   #1
gobrad
Drives: 45th Anniversary SS
Cam questions..
Ok so I've heard and read some things about Cams and blower cams... From the sounds of it there must be a difference in the Cams if you plan on supercharging a motor. I suppose my question is, whats the difference? And if you're doing your car build in stages, can you install a blower cam with out a blower and have it run well? Or is it one of the things you need to install all at once? Thanks for the input everyone. My intent is to do LT headers, Intake, and Noweeds when I get home from this deployment. I would love to add a Cam with it, however I want to add a supercharger eventually. Thanks for the information everyone! I appreciate it!
gobrad is offline   Reply With Quote
Old 01-06-2012, 01:36 PM   #2
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
Yes, you can run a blower cam without the blower. Yes, you will see gains. A blower cam typically has a higher lsa than a big NA cam. A blower cam will typically also have a higher exhaust lift and duration than an NA cam.
However, your most economical bet is to save up and do it all at once. For example, if you get a blower cam and never get around to the s/c, you'll be missing out on gains. If you do eventually get the s/c you will have to tune twice and pay engine tear down labor twice.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 01-06-2012, 03:02 PM   #3
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
geaux_tigerss pretty much summed it up.
Blower cams are different in a number of ways and are generally not as radial as a max effort NA cam. Depending on how the car is setup you can play around with how the cam will effect the blower. Some of the bigger NA cams have a lot of overlap with them which 'bleeds' off cylinder pressure and you generally see lower boost pressure levels, so in many cases you can spin the blower faster with a cam like that.
As far as running a normal blower cam NA without the blower, yes you can do so, and generally they will pick up a solid 35-40 rwhp and still have a very drivable package.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 01-06-2012, 04:26 PM   #4
gobrad
Thanks for the explanation guys! I really appreciate it as I said! What would be some companies to look at for regular cams and blower cams? I'm looking to get that real rough idle sound. I know one of the guys on the forums, at least I believe he is here, has a youtube video of a white camaro in his garage with a cam and noweeds, and I'm looking for a similar sound to what he has. What would I need to look for in a cam to find that deep loping? I'm fairly new to automotive mechanics if you can't tell :-/ Thanks again for everything!
Brad
Old 01-06-2012, 06:13 PM   #5
Brad,
Here is our G6XB blower cam on the dyno before the install of his blower.
Old 01-06-2012, 10:55 PM   #6
cammed06
cammed06's Avatar
Drives: '09 G8 GXP A6
And for those of you who want n/a sounding, but FI friendly, there are options for larger blower cams. Here are two clips of mine.
2014 Silverado 2wd, rcsb, 5.3, Cam, LT's, 3600 Stall, 1/8 - 8.28 (1/4 - 12.91 @ 106, 1.80 60ft, 4700+lbs, 2700da, so far)
1989 Turbo T/A / Mint / All original / 16K miles / FOR SALE
cammed06 is offline   Reply With Quote
Old 01-06-2012, 10:58 PM   #7
cammed06
cammed06's Avatar
Oh yeah, pretty much anything can spank me on the street, cause I roast the tires in 3rd, even if I shove it 3rd in while rolling slow in 2nd....
Old 01-07-2012, 01:29 AM   #8
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
I'm completely happy with my Jannetty Racing 470 rough idle blower cam kit. Kit is complete, service is par none, and it runs like a banshee. Plenty loud with LT headers/hi flo cats and stock exhaust but zero drone or irritation cruising down the highway. No blower, but still have the option for more. And I love the rough idle/old school sound. It will almost rock you to sleep at a long light, but it keeps the adrenaline pumping too much.
Mods: JRE 470 cam kit, Dynatech long tubes/hi-flo cats, SLP underdrive pulley, CAI intake/ADM scoop, Pfadt Stage 2 suspension, Hotchkiss strut tower brace, Proven Wicked tow hook and end links, DBA rotors, Melling oil pump, Katech timing chain/LS2 damper, some bloody knuckles, still in progress...
gotroost is offline   Reply With Quote
Old 01-07-2012, 01:34 AM   #9
gotroost
gotroost's Avatar
Drives: IOM 2SS RS
Sounds AWESOME and must be a blast to drive with the Whipple. I'm working at it slowly but surely. I like track days so suspension goodies are next on the list.
Old 01-07-2012, 08:10 AM   #10
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
N/A Cam with quiet exhaust.
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 01-08-2012, 05:43 AM   #11
CosmicBrut
CosmicBrut's Avatar
Drives: 2011 CGM 2SS/RS L99
If you want to do a blower down the line then definitely go with a blower cam because if you go with an all out n/a cam you will actually be loosing power like Anthony said so choose wisely.
2011 SS/RS A6
TSP 229/236, TSP ported heads, FAST 102 intake, Vmax ported throttle body, Circle D 3200 stall, CAI cold air intake, Kooks complete system, installed and tuned by ECS 11.36@121
CosmicBrut is offline   Reply With Quote
Old 01-08-2012, 01:06 PM   #12
NYJETSFAN
El Hefe
NYJETSFAN's Avatar
Drives: Black Camaro 2SS/RS
Man that sounds good, cant wait to get mine out of the shop.
NYJETSFAN is offline   Reply With Quote
Cam swap questions. Necessary vs. Over Kill Pollock Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-01-2011 02:48 AM
Answers To Your Gears and Cam Drive Ability Questions steeleshark2 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 34 08-04-2011 05:57 PM
Livernois 2c cam kit - Review, Vid and graph marticus24 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 14 06-09-2011 04:11 PM
VVT Cam Specials! yyz28 Engine Internals 17 10-19-2010 12:29 AM
A few questions about cams, headers and exhaust. Oxtar41 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 09-15-2010 08:11 PM
