Old 01-06-2012, 02:03 PM   #1
obrut
obrut's Avatar
Drives: 2010 SIM 1SS/RS
Long tubes CAI and tune only
Has anyone done LT headers, CAI and a tune only? I have a stock 2010 SS LS3 M6 and was wondering what the HP and torque increase would be? Also anyone have video of long tubes with stock exhaust?
2010 1SS/RS SIM M6 - stock
obrut is offline   Reply With Quote
Old 01-06-2012, 02:11 PM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Lots of vids of Lts with stock exhaust. Sounds pretty good to me, you should be making over 400hp to the wheels and around 480hp at the crank.
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-06-2012, 02:21 PM   #3
Ivan @ Southwest Speed
Try this oldie out.....plenty more like in on our channel
Old 01-06-2012, 02:28 PM   #4
matt@lsrperformance.com
matt@lsrperformance.com's Avatar
Drives: 2011 Camaro SS
With the LSR CAI, Kooks long tubes and our tune you should see gains of 40+ hp. Let me know if I can help you with this. Good luck!
matt@lsrperformance.com is offline   Reply With Quote
Old 01-06-2012, 02:50 PM   #5
Anthony @ LG Motorsports
Anthony @ LG Motorsports's Avatar
Drives: 1994 1LE / 2006 Z51 Corvette
Ease of Install
We learned a long time ago to make the system work, it needs to be easy for the user to install. So like our Corvette systems we made this as simple of a bolt on as you can get. All of our kits come complete from engine to mufflers or with mufflers and tips included so all you have to do is bolt it onto the car. Fittings slip together for the smoothest connection between pipes. This also makes our cats replaceable in the event of damage or you want to swap to an off-road setup for track use. The only cutting you would have to do, would be removing the stock mufflers if you want to use them with our kit as GM welded the OE system together complete from the manifolds back.
Configurations and Options
We offer our system in one of four different setups.
1. Full system with out cats, without mufflers
2. Full system w/cats and without mufflers
3. Full system w/o cats and w/mufflers
4. Full system w/cats and with mufflers
All systems will come with off-road pipes included at no charge even for cat'd systems. All systems come with clamps, hardware, extensions, and now GM gaskets as well.
Features
  • 1 7/8" Primary size
  • 3" merge collector with fire cone
  • Full 3" mid section
  • 3" high flow Siamese X pipe design
  • Connects to OE or OE replacment mufflers with included 2.5" adapter
  • All wires, hardware, extensions and GM gaskets now included
  • High flow optional 200 cell metal matrix catalytic converters
  • Off-road pipes included no charge on cat'd systems
  • 35+ RWHP GAIN!
  • Up to 47 lbs of weight REMOVED!
  • LifeTime Warranty for original owner
Also a new feature on the Super Pro line is our merge collector with fire cone.
All LG Motorsports header kits are covered for the lifetime to the orginial owner against any defect or issue. Of course damage by accident is not covered.
MUFFLERS
Our LG designed mufflers are fully polished stainless steel. These also a full 3" throughout and end with a 4" double walled slash cut tip. Lightweight and combined with a straight through design give you little back pressure with a deep American V8 sound!
TAKE A LISTEN!
2010 A6 L99 Camaro before and after full LG System and Dyno tune STOCK AIR BOX AND FILTER!
2010 M6 LS3 Camaro before and after full LG System and Dyno Tune
As always, please feel free to ask any questions or comments.
Anthony @ LG Motorsports is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
