Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 01-06-2012, 02:49 PM   #1
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
STABILITRACK "update"
Over the past few weeks/months I've noticed in my DIC a message just after startup that said "service stabilitrack"(or very similar wording). I had time today and made an appointment at my dealer's service center. After a while I was told that there is an update for the stabilitrack and that updating would take about an hour. Figured I'd let everyone know what's up. I'll repost after I get some time behind the wheel and see if it's been resolved.
Also, the problem was intermittent and I thought for sure the trip would be a waste of time.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
OmniCamaro is offline   Reply With Quote
Old 03-06-2012, 07:47 PM   #2
OmniCamaro
US Veteran
OmniCamaro's Avatar
The error is back and intermittent. Ugh!!
Old 03-06-2012, 09:29 PM   #3
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Could be a bad sensor.
9/26/09 Took delivery!
Old 03-06-2012, 10:02 PM   #4
The SwiftChancelor
The SwiftChancelor's Avatar
Drives: SGM, 2011 2SS/RS, L99
Check your spark plugs. Mine did that and found out a spark plug was off.
K&N air intake, Solo w/Jpipes axleback, SP 1 7/8 LT headers
The SwiftChancelor is offline   Reply With Quote
Old 03-06-2012, 10:21 PM   #5
Cbrenthus
Drives: 2011 VR 1SS
I used to get that every now and then, usually when the car was arm and I just clicked the key real quick and let it go. Now I've started holding the key in the start position longer, and I haven't seen it in ages. I've heard similar reports from others.
Cbrenthus is offline   Reply With Quote
Old 03-07-2012, 02:47 AM   #6
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
had same problem, and did the same thing. have not seen it since.
Old 03-07-2012, 02:51 AM   #7
scott&keyla
camaro peps
scott&keyla's Avatar
Drives: 2010 ss(scott) 2011 rs(keyla)
Check all your spark plug wires!!! had the same problem and checked to wires and one was loose. put it back on and problem gone. went ahead and ordered new set of msd wires to make sure it didn't happen again.
Don't be scerd!! Run it!!
scott&keyla is offline   Reply With Quote
Old 03-09-2012, 03:32 PM   #8
Ventmaster
Ventmaster's Avatar
Drives: 2010 Camaro RS 1LT M6
The owner's manual states the "Service Stabiltrack" message is supposed to briefly appear at each start, along with all the other warning icons that we have learned to ignore...
Airaid CAI, Rx ported TB, Mace ported IM, JBA shorty headers, Richmond 3.73, Borla touring axleback, Hurst short throw, NH-SS fix, IDEALG clutch m/c, SS struts/springs, Spohn trailing arms, Pfadt Racing sways, Pedders radius arm & rear subframe bushing inserts, 2LT gauge pkg.TSW Nurburgs. IPF S/C
Service Stabilitrack Morias Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 02-03-2011 09:36 AM
Stabilitrack? acowherd 5th Gen Camaro SS LS LT General Discussions 3 12-09-2010 10:04 AM
Stabilitrack and rev delay James4086 5th Gen Camaro SS LS LT General Discussions 16 12-02-2009 09:38 AM
Stabilitrack works bilydean 5th Gen Camaro SS LS LT General Discussions 10 09-03-2009 02:45 PM
what exactly is stabilitrack? haleyd 5th Gen Camaro SS LS LT General Discussions 64 07-27-2009 08:01 PM
