Gen5DIY
Old 01-06-2012, 05:51 PM   #1
spencer489
spencer489's Avatar
Drives: 2013 Pre-Production SW Camaro 1le
Unhappy Camaro problems
I was out driving for about 1 hour and as i was on the way home 5min from my house i started smelling like something was burning (i don't know if any of you play xbox and it sounds wired but if you smell the front port on the controller it smells just like that or a clutch burning but i have a automatic). i checked all of the gages (thanks to my RS package) they looked fine i rolled the window down the smell was not coming from the outside, i looked behind me no cars (or in front of me) and no smoke coming from me (i think it was dark). the smell then went away about 2min from my house so i started to relax a little then i pulled into my garage put it in park and let off the brake and i herd a loud sloshing sound coming from the middle of the car that sloshed for a few seconds so i am pretty Sher it was not just gas and i have never herd that before. i ask my dad to look at it he started it opened the hood and trunk reved it a bit (we did not drive it afraid that it would do more damage if Thar is anything wrong) and we did not smell anything and did not hear anything. i was planing to go to the dealer for maintenance so i will be asking them about it and to check it. but the point of this is i want to know you opinion and if its OK to drive to the dealer thats about 20min away.
Thank You for any help :(
spencer489 is offline   Reply With Quote
Old 01-06-2012, 05:54 PM   #2
Dasein
Dasein's Avatar
Drives: 2011 CGM 1LT
I hear the sloshing all the time and I've come to the conclusion that it is the gas in the tank, at least in my case. Maybe you just heard it now because you were paying special attention to try to hear something? I'd say you should be okay to drive to the dealer if you have no warning lights on and there isn't a smell anymore when you drive, but I'm by no means an expert.
Dasein is offline   Reply With Quote
Old 01-06-2012, 05:56 PM   #3
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
I had the same burnin smell coming but it went away. And this was after putting 20000km on it
Never found out what it was but according to the car, everythin was ok.
CAMARO
Old 01-06-2012, 05:58 PM   #4
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
Its the cloth cover in the engine compartment it gets really hot? To me cloth and a hot engine aren't a good mix i took mine off.
skipinminn is offline   Reply With Quote
Old 01-06-2012, 05:58 PM   #5
w[h]o
Drives: 2010 Camaro
I can hear the gas moving too when I park my car
w[h]o is offline   Reply With Quote
Old 01-06-2012, 06:05 PM   #6
spencer489
spencer489's Avatar
I do usaly hear somthing but it sloshed back and forth 5 or 6 (i know i used sloshing but it was more like a ball in a box thats Being shaken) and sounded a lot louder but It may just be me (I hope it is)
Old 01-06-2012, 06:09 PM   #7
spencer489
spencer489's Avatar
I have driven my car for 4 to 5 hours at a time why would
I just be smelling it now and It also went away (for now at lest I hope it dose not come back)
Old 01-06-2012, 06:23 PM   #8
RubyCamaro
Jan
RubyCamaro's Avatar
Check to see if there is a plastic bag stuck to your exhaust. That has happened to a few folks on here.
Old 01-06-2012, 06:45 PM   #9
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
I have had this happen a couple of times on my cars.
CCW polished 505a's
Front 20x10 w/275/40/20's
Rear 20x11.5 w/305/35/20's
Eibach 1" Pro Spring Kit
Factory GFX
MPD1 spoiler
painted bowties
15% tint
FEN is offline   Reply With Quote
Old 01-06-2012, 06:45 PM   #10
ffrcobra_65
im sure nothing bad happened. something got stock on the exhaust pipes and burnt off. During my first drive in my SS, smoke was literally bellowing from under the car. I thought it was on fire. Turned out, the part # stickers on the exhaust pipes were burning off. Dealt with the burning smell for maybe 100 miles than all good.
Old 01-06-2012, 09:06 PM   #11
pears2
Drives: 2011 Black/Silver Synergy Series
I have noticed the sloshing sound as well. I noticed it when the fuel tank was 1/2 full. Drove to the Shell Station, filled the tank and the sloshing disappeared. As far as the burning smell, I have notice it once. I drove about 70 miles on the interstate, parked the car in the garage and lifted the hood. I could smell something burning, assumed it was the heat shield. Have only noticed the smell once. Everything seems to be fine on the car, called the dealership and asked about the smell. Was told it was probably the vehicle breaking in. If it continues, I would take it back to the dealership.
pears2 is offline   Reply With Quote
Old 01-06-2012, 09:50 PM   #12
jmaynard
Drives: 2012 Camaro SS2
See my earlier post on exhaust fumes. Smells a little like someone is smoking a cig next to your cabin aiur intake. Dealer tells me it is not a problem. Had not considered the hood cloth, but may test that theory. I am told that it will go away after time. It's a real shame to make an investment in a new car have have it smell like I smoked in it. :(
jmaynard is offline   Reply With Quote
Old 01-06-2012, 10:24 PM   #13
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2012 2SS/RS LS3
...makes the think of nightfall....
NightOwl RGB Halo Kit V2, Kooks 1-7/8 LT Headers, Cam Motion Cam, CAI Intake, Catless Midpipes, Borla ATAK Catback, 35% Tint, Vinyl Gill Blackouts, RX Catch Can, Devil Tail Side Stripes, Front Lip Blackout, Dual Color Bowties, Ghosted Sidemarkers,
Exhaust Video (Manifolds) Exhaust Video (Headers) White Lightning
A.C.E.5.
xxx RWHP/xxx RWTQ
CamaroKid300 is offline   Reply With Quote
Old 01-08-2012, 06:25 PM   #14
Aktos
Aktos's Avatar
Drives: 45th Anniversary 2SS
I also have an automatic and the burnt smell and I am at 1265 miles. I just got it home and do not smell it now. I could smell it when car was running especially when coming to a stop at a light. It has always had kind of a burn oil type smell in garage since I bought it just figured it was new parts heating up oil coating but at this many miles I am begining to wonder.
Aktos is offline   Reply With Quote
5th Gen Suspension -- The Book JusticePete Suspension / Brakes / Chassis 151 05-07-2015 05:52 PM
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet Tran Camaro ZL1 Forum - ZL1 Specific Topics 38 02-17-2012 12:45 AM
Automobile Reviews 2011 Chevrolet Camaro Convertible 2SS Tran Camaro Convertible Forum 33 07-28-2011 07:36 PM
The DEFINITIVE EXPLANATION OF CAMARO SUSPENSION, ISSUES, AND UPGRADES Info@PeddersUSA.com Suspension / Brakes / Chassis 106 10-19-2009 06:08 PM
