Old 01-07-2012, 10:59 AM   #1
jtfire006
jtfire006's Avatar
Drives: 2011 v-6 vert
vararam install
i will be recieving my vararam intake for my rs v-6 camaro on monday, the motor is completely stock besides the intake i will get on monday. will it work correctly on the stock motor?
anything addional i need to buy to install it? and does the ecu need to be reset after it is installed?
if so just disconnect the battery?
thanks for any help
jtfire006 is offline   Reply With Quote
Old 01-07-2012, 11:01 AM   #2
KMPrenger
KMPrenger's Avatar
You can feel free to disconnect the battery.
Other than that..you're good to go.
Drive the car easy to medium rpms for awhile after install to let the car adjust. Also, after your first several drives with it, check it to make sure it hasn't shifted and closed the air gap at all. If it does, you will likely need to grind down the brackets more...but if it doesn't move then you are golden!
You'll love this intake.
Old 01-07-2012, 11:14 AM   #3
melvinakshay
Vrooom Vrooom
Drives: Camaro 2011 black LS
thanks for any help
You dont "need" to disconnect the battery. You can if you want to, disconnecting it will not make any difference.
All you need to do is take the old air intake out, swap the sensor and install the new air intake. You don't need anything else.
Just follow the video.
melvinakshay is offline   Reply With Quote
Old 01-07-2012, 01:24 PM   #4
jtfire006
jtfire006's Avatar
thanks for the replies! just thought that the ECU needed to relearn the driving habits after the vararam install. read on here that some of the CAI systems reccomended you reset the ecu or disconnect the battery, didnt know if this was one.
agian thanks!
Old 01-07-2012, 01:29 PM   #5
2010camarolt
2010camarolt's Avatar
Drives: Victory Red 1LT
agian thanks!
i would disconnect the battery, it can only help, take like 2min. I remember reading somewhere that you should drive regularly for about 100 miles then you can do some wot runs.
i dont have the vararam but i let my computer learn for about 100 miles before i did any spirited driving
2010camarolt is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 287 08-26-2017 12:29 PM
Vararam ordered !! , ...install ? Blacktip Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 10 01-04-2012 08:19 PM
2010+ 6.2L V8 Camaro Vararam Ram Air Intake - Tune & No Tune Required Systems! AutoAgenda V8 Bolt-Ons & Tunes 20 10-29-2011 11:25 PM
Got A Vararam for $10! (Warning long read) shadow09 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 04-26-2010 11:44 PM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 05:36 PM
