JDP Motorsports
Old 01-07-2012, 05:46 PM   #1
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
Oil cap breather?
Getting a cam swap and wondering if this rx catch can and oil cap breather will give the tuner problems? I thought I read somewhere that this breather is okay but I want to find out for sure
TSP 229/236 cam .Magnaflow Comp axleback .KOOKS LT w/ high flow cats .magnapack bullets. C.A.I. Vmax ported TB. Dyno tuned 452hp / 422tq.
ducq is offline   Reply With Quote
Old 01-07-2012, 05:58 PM   #2
MikeOD
Drives: 2010 M6 2SS
Essentially, you'll be letting unmetered air into the engine through the crankcase system that hasn't been measured by the MAF...I wouldn't do it.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 01-07-2012, 06:09 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Please research before posting on a topic.
The RX oil breather has a check valve to only allow air out of the crankcase, not in. This helps with positive crankcase ventilation and decreases oil blow by.
If you got an oil breather off of eBay per say, that didn't have a check valve. Then yes you would be letting unmetered air into the crankcase.
Click to view my build thread
Old 01-07-2012, 06:46 PM   #4
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
Thank you Stieger
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 01-07-2012, 08:03 PM   #5
MikeOD
Drives: 2010 M6 2SS
My mistake, complete missed where he listed a specific brand.
If the check valve is reliable, then yeah, shouldn't affect the tune at all.
Old 01-07-2012, 10:26 PM   #6
ducq
ducq's Avatar
Okay I don't have to go digging for that tube and stock oil cap. I'll let my tuner know what stieger posted and see what he says.
"The RX oil breather has a check valve to only allow air out of the crankcase, not in. This helps with positive crankcase ventilation and decreases oil blow by. "
Thanks !
Old 01-07-2012, 10:28 PM   #7
The Stig
The Stig's Avatar
No worries. Didn't mean to jump down your throat about it btw, it's just been a rough day.
Old 01-08-2012, 08:36 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Even if it diid suck air in, how would that affect the tune? It's not like it's going into the combustion chamber. Unmetered air is only bad for the tune if it's using up fuel.
To the OP:
Be sure to check with guys that have it to see if they are getting excessive oily residue all over their engine. I had one for a short while on my old turbo Talon and it would blow oily residue all over everything.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-08-2012, 08:56 AM   #9
The Stig
The Stig's Avatar
It will throw off the A/F ratio thus causing you to pull timing.
Old 01-08-2012, 08:59 AM   #10
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Quoted from SC2150 himself.
"These breathers have a integrated one way checkvalve that helps prevent any mist escaping from the breather into your engine compartment as well as controls the correct amount of flow into the crankcase unlike a "open" breather."
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 01-08-2012, 09:51 AM   #11
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
You really do need to follow your own advice!
2SSCAMARO is offline   Reply With Quote
Old 01-08-2012, 10:39 AM   #12
The Stig
The Stig's Avatar
Haha fair enough. That's my bad for getting it backwards. But either or, the RX oil breather does have a check valve
Old 01-08-2012, 01:16 PM   #13
jlauber588
jlauber588's Avatar
Drives: 2010 camaro
To the OP:
Had mine for 600 miles now and no oil anywhere. Now even on the breather filter.
Sent from my DROID BIONIC using Tapatalk
jlauber588 is offline   Reply With Quote
Old 01-08-2012, 03:04 PM   #14
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Since you are going to have it tuned, any potential changes to fueling can be adusted. fwiw. I put a breather on my Impala and it threw the fuel trims way off. Someone was supposed to send me the RX breather to test on my Camaro (it's not custom tuned) so I could see if it affected fuel trims, but I've not seen it yet.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 04:15 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
