Old 01-08-2012, 03:24 AM   #1
Milkman20
Milkman20's Avatar
Drives: Red 2010 Camaro 2SS L99
Cam Labor Price/Question
So here's the deal, i was just wondering, for all you guys who have aftermarket cams, what did you guys pay for labor? I'm thinking of buying the VVT-3 cam from texas speed, with the AFM/DOD delete kit, .675" double spring kit. Ive been quoted about $1500 - $2000 for labor from a shop where I've always took my previous cars I've had. They have always done a great job and great friends with the owner.
here's one of many cars they built just for your entertainment
http://youtu.be/URD_zq5TKGY
http://youtu.be/_fvTLzu1-WE
http://youtu.be/tclFpW6_3ac
Thanks!!
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers
Exhaust Clip: http://youtu.be/c_quv8eoVNQ
Milkman20 is offline   Reply With Quote
Old 01-08-2012, 08:47 AM   #2
Rockit_z28
www.1baddogracing.com
Rockit_z28's Avatar
Drives: 2010 IOM 2SS/RS Auto
I am confused. You stated that you are doing a VVT cam, but then also doing the AFM/DOD delete? If you are doing the AFM/DOD delete, you can go to a better cam especially with those springs and not be limited to the VVT cams. The VVT cams are designed to work with AFM/DOD.
Labor seems reasonable and more importantly it sounds like a shop you trust.
2010 Camaro 2SS/RS L99 IOM - 812RWHP 665RWTQ (9.82@139)
Built and Tuned by Heintz Racing
Go: DSS 9", RPM Level X 4L65E, Carlyle Racing 15" Conversion, ECS Paxton Novi 1500, Meth, Squash Fuel, ID850, Gall Racing Forged LS3, A.I. Ported Heads, HR Custom Cam, BMR Susp
Show: Custom Painted Stripes/Badges (Orange Pearl over White), Z/TA Spoiler, VFN Hood, Weld Wheels
http://www.HeintzRacing.com
http://www.youtube.com/user/1baddogracing
Rockit_z28 is offline   Reply With Quote
Old 01-08-2012, 08:51 AM   #3
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
I hope that includes the tune? If the tune is included I could go for that... 2k still seems a high.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 01-08-2012, 08:56 AM   #4
brantley847
v It bites.
TSP AFM/DOD delete is vastly cheaper than Ted, Mast, or others.. it seems to be just a replace for lifters/springs... I could be wrong, may want to check their website and see, but it doesn't seem like a FULL conversion kit. (again.. could be completely wrong).
I believe regardless which cam you go with, you have to replace lifters... that may be what OP means.
2011 2SS/RS
Old 01-08-2012, 09:38 AM   #5
Hulk
Hulk's Avatar
Drives: 2011 Synenergy Green 2SS/RS
AFM/DOD is the cylinder cut out designed for economy and has nothing to do with the VVT, it just so happens that both systems are used in the L99. The lifter oil pressure for 4 of the cylinders is lowered so the lifters "collapse" or do not function. The AMF/DOD lifters are known to be weak and it is suggested that they are replaced when larger cams are installed. The heads must be removed to do the lifter change out AMF/DOD delete increasing the cost over a normal cam swap that does not require cylinder head removal. The VVT variable valve timing is the advance and retard of the cam timing. The advance and retard of the cam timing gives you the best of both worlds with one cam. The advance makes more low end power and the retarding makes more top end power. Tuning by someone that understands all of this is critical.
2011 Synenergy Green 2SS/RS Automatic.Roto Fab, Bo White ported throttle body, GPI rod mod intake, VVT SS3 cam, CNC ported heads, Doug Thoutley tri-y long tube headers, Solo Mach cat back with j pipes. Yank converter, Factory Reproductions Chrome Z28 wheels ect, ect
Hulk is offline   Reply With Quote
Old 01-08-2012, 11:26 AM   #6
NYJETSFAN
El Hefe
NYJETSFAN's Avatar
Drives: Black Camaro 2SS/RS
I was also concerned about the price of labor when it relates to cam installations. I am pursuing a cam that will cost roughly 1400 and I was told the installation can take up to 10 hrs@ 100 bucks per hour.. Not sure of that is about right, but the installer comes highly recommended.
NYJETSFAN is offline   Reply With Quote
Old 01-08-2012, 11:30 AM   #7
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
850 for labor is what i paid.
Old 01-08-2012, 11:38 AM   #8
summitss/rsls3
summitss/rsls3's Avatar
Drives: summit white/IOM ss/rs ls3
Do it yourself, its free that way, took me and my brother 5 hours start to finish in my garage. They only thing we didnt do was tune it, that cost me $400.
_____________________________________
2010 Summit White w/IOM stripes SS/RS LS3, Pfadt spings, Richmond 4.11 gears, GTO clutch reservoir mod.,MGW shifter with retro handle, TSW Nurgurgring wheels, Nitto NT05R 315/35R20 on rear, Kooks 1 7/8 LT's no cats, Stainless works retro chambered catback, Cold Air Inductions CAI, Texas Speed UD pulley, LG G6x3 cam, PRC dual valvesprings w/titanium seats and retainers, Texas Speed 7.4" hardened push rods, Lethal Ported Fast LSXr 102, Ported stock TB, RX catchcan. Tuned by Dan at Dynosport in Lincoln, NE 483RWHP/442RWTQ SAE corrected.
summitss/rsls3 is offline   Reply With Quote
Old 01-08-2012, 12:03 PM   #9
Milkman20
Milkman20's Avatar
@Hulk was right, but the AFM/DOD delete Kit comes with LS3 timing chain dampener, 8 new LS7 lifters, LS3 lifter trays, GM LS3 cylinder head gaskets, GM LS3 cylinder head bolts, LS2 valley cover, PCV hose, PCV plug, and a TSP camshaft swap bolt and gasket it. and im paying an extra $70 for all 16 instead of just 8 lifters. Here this is what im getting https://www.texas-speed.com/p-260-ts...t-package.aspx
I don't mean to sound rude but i already did the research and everything on that, my initial question was about labor, i appreciate your guys concern but I really just needed your opinion about labor.
was it easy to do yourself? Me and my buddy have some experience and have did this before but not much.
Thanks guys!!
Old 01-08-2012, 12:05 PM   #10
Milkman20
Milkman20's Avatar
and yea it includes the tune
Old 01-08-2012, 12:17 PM   #11
NYJETSFAN
El Hefe
NYJETSFAN's Avatar
I would love to do it myself, But I am not mechanically inclined at all. I will attempt things that are cost efficient to repair if I make a mistake.
Old 01-08-2012, 02:28 PM   #12
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
Sounds like a fair price including the tune. You will love that cam.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 01-08-2012, 03:04 PM   #13
kaler
kaler's Avatar
I thought I was the only one on Camaro5 that understood that lol. To add to the end of your post,when you buy a TSP VVT cam they provide the cam phasing tables. As long as the person doing the tune knows how to tune a LS engine you are good to go.
Old 01-08-2012, 03:32 PM   #14
kaler
kaler's Avatar
[QUOTE=Rocket-z28 ..... I am confused. You stated that you are doing a VVT cam, but then also doing the AFM/DOD delete? If you are doing the AFM/DOD delete, you can go to a better cam especially with those springs and not be limited to the VVT cams. The VVT cams are designed to work with AFM/DOD.
Labor seems reasonable and more importantly it sounds like a shop you trust. [/QUOTE]
I'm not saying the VVT-3 cam is the end all be all, my results speak for them self. I have gained 121 rwhp with my VVT-3 set up thru a 3200 converter. If this car wasn't my wifes DD I would have most likely yanked the VVT and ran a huge cam not that the VVT-3 is a small cam. In fact it is as big or bigger than 90 percent of the cams I see on Camaro5.
Last edited by kaler; 01-08-2012 at 09:18 PM. Reason: quoted the wrong person doooo....
Any video, LS9 cam in a LS3? Bad70supreme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 67 11-30-2011 10:41 PM
Vector Motorsports Stage 2.5 cam kit installed! pics and video topgun1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 38 12-18-2010 11:28 PM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 04:09 PM
