Old 01-08-2012, 11:33 AM   #1
TheOneS13
Drives: 1998 Nissan 240SX
LS3 Water Pump Differences?
Hey all, I recently purchased an LS3 longblock from a 2010 Camaro.
I will be swapping this into my 240SX, and still need the accessory drive and coils to finish it.
Do you know if there are any differences between the Corvette and Camaro LS3 water pumps?
I am trying to keep the acc drive as close to the engine as possible since I won't have much room between the accessory drive and radiator/fans.
Also, know if the CTS-V drive has the same offset from the front of the engine as the LS3?
TheOneS13 is offline   Reply With Quote
Old 01-08-2012, 12:12 PM   #2
Milkman20
Milkman20's Avatar
Drives: Red 2010 Camaro 2SS L99
I believe there the same because the LS3 is also in the C6 non z06 corvette, and also obviously in the camaro, so depending on what corvette water pump your looking at, i think its the same but idk for sure. and also you should post a build thread that's gonna be sick I want to see videos!!! Good Luck!!
2010 Camaro 2SS/RS L99 6AT - 451 RWHP, 414 RWTQ
TSP VVT-3 Cam DOD/AFM Delete, Ported Stock Heads, Circle-D 2B Multi Disk Converter, Custom 3" Exhaust w/Burns Mufflers
Exhaust Clip: http://youtu.be/c_quv8eoVNQ
Milkman20 is offline   Reply With Quote
Old 01-08-2012, 01:37 PM   #3
TheOneS13
The plot thickens...
P/N: 19207665
Application:
2010-2011 Camaro LS3
2009-2011 Corvette LS3
P/N: 89018052
Application:
For: D 6.0-U(LS2) (2006-2007) (2007 - 2007). (07 CTS)
For: Y 6.0-U(LS2) (2005-2007) (2007 - 2007). (07 CTS-V)?
For: Y 6.2W(LS3) (2008-2008) (2008 - 2008). (07-08 Corvette)
P/N: 19180610
Application:
Cadillac CTS COUPE 2011
Cadillac CTS CTS-V 2 DR COUPE 2011
Cadillac CTS CTS-V 4 DR SEDAN 2011
Cadillac CTS CTS-V 4 DR WAGON 2011
Cadillac CTS SEDAN 2009, 2010, 2011
Cadillac CTS WAGON 2011
The balancer (crank pulley) on the Camaro LS3 and Corvette LS3/CTSV look different too.
Old 01-08-2012, 02:12 PM   #4
izaks
Drives: Chev Lumina 416
The Camaro water pump is further forward than the Corvette and is not interchangeable.
251-728 (19180610) runs closest to the engine (Corvette / G8)
251-734 (19207665) is +/- 50mm forward (Camaro)
izaks is offline   Reply With Quote
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 120 07-31-2016 06:37 PM
water pump connections .... zachi3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 09-06-2011 05:31 AM
Water Pump? MrCool 3rd Generation Camaros 0 03-11-2011 04:02 PM
Noob Here need Help define LS3 / L99 Differences? dxy2jbaby Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 11-10-2010 06:31 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
