Old 01-11-2012, 02:55 PM   #85
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
If the SS ends up being the entry level v-8 again they need to use the weight loss as leverage. Keep the acceleration about the same and work on improving mpg.
Old 01-11-2012, 03:35 PM   #86
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by b4z View Post
The worst part about is that the 3400lb ATS is quicker than the '10-12 Camaros.
350 lbs should knock .3-.4 off the 0-60 time.
What engine are you assuming is going to be in that 3400 lb ATS? Odds are, it will be the 200 hp 2.5L ecotec. It might be the 2.0 turbo at 270 hp. Probably won't be a V6 at that weight. And won't be a V8.
Power to weight ratio says that neither of the 4 bangers should be faster than a V6 Camaro, let alone the SS. Even a V6 ATS won't match an SS unless its a turbocharged ATS-V (if they go such a route for that car). And an ATS-V, I suspect, would start somewhere north of $50k if its a turbo6 or NA V8.
I don't think Camaro owners need to be too worried.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 01-11-2012, 05:30 PM   #87
Mr Twisty
Mr Twisty's Avatar
Or reduce drag, Corvette is 30+ mpg.
I need to watch the unveil vid again, (don't see it on youtube yet) I think he said the V6 car is slightly over 3400.
-- Benjamin Franklin
Old 01-11-2012, 06:27 PM   #88
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
The announced engines so far for the 2013 ATS are the base 2.5L I4 naturally aspirated and weighing under 3400 lbs, a 2.0 I4 Turbo, a 3.6 DOHC V6 @ 320hp and by GM's own numbers should weigh about 3,456 lbs, and an unidentified diesel has also been confirmed. BTW, the 2013 ATS has already been tested at the "Ring", so they should have handling packages worked out already.
Clyde
wildpaws is offline   Reply With Quote
Old 01-11-2012, 07:35 PM   #89
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
I'll say that a next Gen SS (with a V8) will weigh 3,600+ lbs.
Having said that I'll take a 5th Gen Z28 at 3,850 lbs (or less) and remove another 100 or so lbs myself. Just make sure it has an LS7! I love this design, and the clay model shown already turns me off.
2cnd chance is offline   Reply With Quote
Old 01-11-2012, 07:52 PM   #90
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
I have to politely disagree on the weight for a 6th gen Z/28. The numbers released by GM for the new ATS (which will share it's platform with the 6th gen Camaro) show the ATS with the same DOHC V6 @ 320hp in the 5th gen Camaro should weigh 3,456 lbs. We know in the 5th gen Camaro that the weight difference between the V6 and SS is about 70 lbs, in the ATS add those 70 lbs to the V6 weight of 3,456 lbs and you arrive at 3,516 lbs. Unless the numbers change radically later on, I cannot see how a 6th gen Z/28 would be 3,600+ lbs.
Clyde
Old 01-11-2012, 08:07 PM   #91
LOWDOWN
Downright Upright
Drives: Daily
It'll depend on the power output of the LT1. BIG power takes HD driveline/brakes/wheels 'n tires. The engine weight differential, V6 to V8, is likely to be 50 pounds+. So, getting to something close to 3600, give or take, still has you at a very handsome power-to-weight.
Again, folks, it's THREE l-o-n-g years away...there is STILL time for a right-contented Gen-5 ZEE to send this version out with a BANG!
LOWDOWN is offline   Reply With Quote
Old 01-11-2012, 08:24 PM   #92
full of days
full of days's Avatar
Drives: Camaro GT
I know we're talking power to weight ratio here but consider that the new 302S from the blue oval is 3200 lbs and 440 HP. For GM to even start playing in the same ballgame, GM needs a light weight Z-28 with chassis and suspension development equal to or better than the Ford offering. GM's got a lot of work to do and are frankly loosing the battle on the racetrack. Look at Grand AM level road racing and then look at the grassroots guys. There's a reason why there are 5 mustangs for every 1 camaro. It costs 3 times as much money to get a Camaro anywhere close to working in the corner compared to the mustangs... I'll get off my soapbox. It's late and I've frankly had a rough week coming to the realization that my SS at 3865 lbs as it sits won't ever get any lighter than a 302 5.0...
Post Tenebras Lux
full of days is offline   Reply With Quote
Old 01-11-2012, 08:30 PM   #93
Mr Twisty
Mr Twisty's Avatar
LT1?
V8 may need structural enforcement also.
Still plenty of time, but they better hurry, 2016 model may be 2015 mid year production.
Old 01-11-2012, 08:56 PM   #94
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
I understand that a more powerful engine needs better driveline, etc., but that's why I used the current weight difference between the V6 manual and SS manual. Would not the 5th gen SS have better driveline components, etc. than the V6 (426hp vs 320hp)? The current weight difference between those two 5th gen versions is 70 lbs (actually 69lbs, but that's close enough).
Clyde
Old 01-11-2012, 09:02 PM   #95
DGthe3
Moderator.ca
DGthe3's Avatar
302S? Thats a striped out spec series racer. Don't even bother comparing it to real production cars.
LT1?
The LT1 is the designation for first of the new Gen V small blocks. Its not to be confused with the LT1 from the mid 90's. Which reminds me ...
GM needs to extend the length of time engine codes are retired. 15 years, give or take, simply isn't long enough.
Old 01-11-2012, 09:16 PM   #96
Mr Twisty
Mr Twisty's Avatar
It confused me THIS time.....
I'll forget.
... and be confused NEXT time too
So this will be the 3rd LT1, that's okay, the first two were great, the new one has a lot to live up to
Old 01-12-2012, 09:20 AM   #97
LOWDOWN
Downright Upright
Drives: Daily
Clyde
Whether or not we see a Gen-5 ZEE, I believe the "halo" Gen-6 Camaro WILL be a ZEE. The ZL1 simply will NOT translate beyond Gen-5...
A ZL1, currently, carries at least 100 extra pounds for the LSA...then all the coolers and gold chains which, compared to a 1SS, adds damn near 300 pounds. And some of that weight is further-reinforced drivetrain: brakes/HD diff 'n axles/HD trans etc.
To make an 8lb/hp (or better!) Gen-6 ZEE will require components well beyond the 318 hp (their figure) V6 stuff...which will add more than 50-70 lb. total.
A 450 hp LT1 (a number tossed around GM-centered discussions) with 3600 total ZEE Curb Weight = the magical 8.0! IF it comes in at 3550, great...and less would be fine, too. But festooning the car with all manner of c/f and ti to get the Curb a whole lot LOWER will simply put the price of admission a whole lot HIGHER...and I, for one, am NOT looking forward to a ZEE priced the same as a ZL1 currently is.
Old 01-12-2012, 08:21 PM   #98
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
Neither do I want to see a 6th gen Z/28 price pushed to very high numbers as a result of trying to save weight with expensive lightweight materials, but everyone needs to read GM's press release on how they focused on weight savings in the ATS. And how much heavier driveline would be needed for an LT1 powered 6th gen Z/28 compared to the driveline in the 5th gen SS which is rated @ 426hp? As I said before the total weight difference between a 5th gen V6 and SS is 70 lbs overall which includes the heavier drivetrain, brakes, etc. of the SS. GM's weight savings no are focused on grams and ounces saved everywhere throughout the car rather than a few expensive lightweight pieces. They looked at 'how can we make these inner door panels lighter", "how can we save a pound or so on this casting without sacrificing strength", etc. throughout the entire car. This is a new era of weight reduction and not simply throwing a few big, expensive pieces of CF at the problem to bring about weight reduction. This new type of weight reduction won't cost big bucks that will drive the unit price upwards.
Clyde
GM: Arguments for a Spring 2011 Z/28 release! sen10l Camaro ZL1 Forum - ZL1 Specific Topics 25 04-10-2011 02:39 PM
PWA "The Lounge" DGthe3 Off-topic Discussions 143773 11-06-2010 12:00 PM
Al Oppenheiser on Z/28..... ShnOmac Camaro ZL1 Forum - ZL1 Specific Topics 126 04-29-2010 04:26 AM
OK, I need Z/28 Therapy PLEASE HELP!!! Fandango Camaro ZL1 Forum - ZL1 Specific Topics 15 02-27-2010 02:00 PM
2011 Z/28 Camaro "Reality" IROCZJEFF 5th Gen Camaro SS LS LT General Discussions 55 09-16-2008 01:55 AM
