Old 01-08-2012, 05:23 PM   #1
shines
Drives: 2010 Camaro SS/RS
Disappointed with my Twin Turbo setup, need help!
So, about 2 months back I was tired of dealing with SC belt slip issues, I decided to switch from a Whipple SC to a Hellion Twin Turbo kit. I'm not sure I've made a worse decision in my life
After installing the kit I had serious turbo oiling issues, they smoked bad. Turbonetics said oil restrictors should not be needed while Hellion was telling me the opposite. I tried a number of different size restrictors until finally I was able to get the smoking stopped.
Now that the smoke has stopped, the oil warning light included with the Hellion kit continually blinks. They said so long as it's not on constantly, it's no problem. That's easy for them to say, they don't have a bright red light flashing in their eyes when driving after dark.
Anyway, about a month ago I started working on the tune, I was able to get it running fairly well and pulled 715rwhp on the dyno with 11lbs of boost.
Then last weekend I decided to try a top speed run (deserted country road). So, I run it up to 6K rpm in 4th gear and felt an intermittent hesitation. Same thing in 5th gear only worse. Also, during the hesitation I could hear a popping noise that sounds almost like a backfire through the intake manifold.
I thought it might be knocking from a bad tank of 93, so I hooked up HP Tuners and scanned it. No knock retard at all, in fact there's really nothing in the scan that indicates the hesitation. Although the MAF line was pretty erratic.
I removed the MAF sensor and it litterally had oil dripping from it, I presume from when the turbo's had too much oil, it not only got blown in to the exhaust (i.e., smoke) but also the intake piping, including the heat exchanger .
I cleaned the MAF but the hesitation is still there.
At this point I'm guessing it's,
1) The eBoost boost controller causing the waste gates to pop open then closed.
2) A bad wastegate
3) Turbulance within the intake tube
FYI,
The motor is a built 416 stroker built by Livernois with the Janetty "Rough Idle" blower cam running at 9.7:1 compression. I'm also running a Victor Junior intake manifold with an Edelbrock EFI "hat".
shines is offline   Reply With Quote
Old 01-08-2012, 05:35 PM   #2
Motion427
Drives: 2010 2SS/RS Red Jewel L99
When you did your WOT run,Did you also logged the AFR ?
Motion427 is offline   Reply With Quote
Old 01-08-2012, 06:49 PM   #3
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Should have kept the whipple lol!! Hope everything works out for you.
MODS:
Old 01-08-2012, 07:06 PM   #4
Bad Dad
Bad Dad's Avatar
Drives: 2010 2SS/RS , 2011 C6 Base Corvette
Exclamation Turbos
Shines I thought they were fixed
SUICIDE BY RACECAR
Bad Dad is offline   Reply With Quote
Old 01-08-2012, 08:24 PM   #5
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Do you have a catch can? What are you doing about crank case pressure? Get a 3 bar map and tune with it if you havent already. My guess is if you getting oil on the maf something isnt placed right or you have some pcv issues or turbo seals are gone.
JLE58 is offline   Reply With Quote
Old 01-08-2012, 08:56 PM   #6
grocerygetter
instigator
grocerygetter's Avatar
Turbo seals relating back to the restrictor issues
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 01-08-2012, 08:58 PM   #7
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Have you wiped the inside of your intake tubing? Was it coated in oil? If your MAF sensor was dripping, then you have oil throughout the charge side and in your intercooler. Until the oil is all cleaned out from the entire charge side of the system, you'll have this issue.
You may have comprised the MAF sensor. I've had this happen before. Clean my oil soaked MAF, but it still didn't work right. Put a new MAF in and all was good.
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 01-08-2012, 08:58 PM   #8
shines
I did, it was between 11.0 to 11.5:1, which is where I have it configured.
Old 01-08-2012, 08:59 PM   #9
shines
Says the guy with a Whipple....smart ass
Old 01-08-2012, 09:00 PM   #10
shines
Yea, I've got the RX can for turbos/remote mount SC's
Old 01-08-2012, 09:02 PM   #11
JLE58
So its not smoking anymore right?
Old 01-08-2012, 09:04 PM   #12
shines
I've only cleaned the tubes leading from the heat exchanger, a complete disassembly is required to get the others
Old 01-08-2012, 09:05 PM   #13
shines
Right, no smoke. But I guess oil could stiil be getting blown into the compressor side. The turbonetics turbos I have are ceramic ball bearing and from what I understand only the compressor side of the shaft uses the ceramic bearing, the exhaust side is the traditional oil/fluid bearing.
Old 01-08-2012, 09:13 PM   #14
JLE58
I dont know maybe... I would be check the pcv system with the catch can. Not sure how yours is set up but my guess is something isnt right right with it.
twin turbo 2010 ss xjer22x Member Car Journals 99 07-04-2013 10:17 PM
Turbo Technology / Granatelli Motor Sports Twin Turbo Kits Granatelli Forced Induction 109 09-04-2011 12:56 AM
My low-mount Twin Turbo build Pt_killa Forced Induction - V6 28 03-21-2011 03:03 PM
New Speed Inc. twin turbo project finished!!! Bryan @ Speed Inc. 4th Generation Camaros 6 01-31-2010 11:42 AM
New Speed Inc. twin turbo project finished!!! Bryan @ Speed Inc. 4th Generation Camaros 1 01-28-2010 03:16 PM
