Old 01-08-2012, 10:12 PM   #1
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Installation question for new exhaust system
I am looking at installing Borla ATAK cat back system on my 2011 2SS. I was looking at some of the instructions on the replacement and they state to remove the stock exhaust from the hangers and you will reuse those same hangers to mount the new system. But when looking at the pictures for installation, it appears that the hangers have been welded to the stock exhaust. Can anyone confirm that they are welded to the hangers or do they slide in and out easily.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 01-08-2012, 10:15 PM   #2
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
They are talking about he rubber part of the hangar. Those are removable.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 01-08-2012, 10:45 PM   #3
Parag
Drives: 2010 camaro 2SS LS3
Have fun with those, they are tight. I removed my bumper cover to get to them
Parag is offline   Reply With Quote
Old 01-08-2012, 11:28 PM   #4
orangejuice
H1 OFCR
orangejuice's Avatar
Drives: 2013 ZL1 Blue Ray Metallic
You don't need to remove any diffuser or bumper cover. Take a tiny bit of oil and with your fingers shove it in the holes of the hanger and the stock exhaust will slide right out and the aftermarket will slide in to complete the install.
Corsa
Rotofab
BBK
ZL1 Hood/Fascia
AAC Afterburners/Sidemarkers
Havoc Black Chrome
5% Tint/20% Smoked Taillights
orangejuice is offline   Reply With Quote
Old 01-09-2012, 12:06 AM   #5
siriusdish
Drives: 2010 Camaro L99
they sell a tool for them.
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 01-09-2012, 01:47 AM   #6
rberns
rberns's Avatar
So the stock exhaust is not welded to the hangers? From the picture it appears that they are, but I could be wrong.
Old 01-09-2012, 02:03 AM   #7
siriusdish
That metal hanger pushes out of the rubber at the top on the exhaust..
2010 L99
Old 01-09-2012, 02:25 AM   #8
ss/rs-matt
ss/rs-matt's Avatar
Drives: 2011 2SS/RS LS3
take some dawn and make some really soapy water. lube'em up and they should slide right off. good luck!
ss/rs-matt is offline   Reply With Quote
Old 01-09-2012, 05:36 AM   #9
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
You will understand what we are talking about once you get under there. An exhaust should never be welded directly to the chassis. Like everyone else is saying, lube up those rubber hangars to slide the exhaust out. They can be difficult.
Old 01-09-2012, 08:48 AM   #10
caverman
caverman's Avatar
Drives: '69 SS Convertible
Shoot a little WD-40 into the holes of the rubber hangers. Let it sit for a minute or two.
No need to remove the bumper or diffuser.
Build Journal
Old 01-09-2012, 10:20 AM   #11
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
As did I. WD-40 then evaporates and restores the higher level of friction.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 01-09-2012, 10:32 AM   #12
Wild Bill NY
Wild Bill NY's Avatar
WD-40 is your friend ! I took my stock exhaust out with GFX on my car no problems . Old exhaust out new one in all in an hour ...
'10 Camaro 2SS/RS , '08 Cadillac CTS , '08 Lincoln MKZ , '05 American Ironhorse Texas Chopper , John Deere LT155 . All American !!!
Wild Bill NY is offline   Reply With Quote
Old 01-10-2012, 01:11 AM   #13
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
+4
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
______ARK Performance USA Type 1 DTS Catback Exhaust System Introductory Sale_____ ARK Performance V8 Bolt-Ons & Tunes 65 04-27-2011 09:04 PM
Exhaust installation question gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 10-18-2010 04:59 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 02:56 PM
