BeckyD @ James Martin Chevy
Old 01-08-2012, 10:46 PM   #1
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Post Fast Lsxr 102 worth it for L99?
I have been thinking about getting a Fast Lsxr 102 manifold setup for my 2011 camaro SS L99. I have been reading reviews stating that you dont see much gains from this setup well at least for the L99. Does anybody have this on a automatic and tell me if it was worth it or not. Thanks in advance.
lincoln361 is offline   Reply With Quote
Old 01-08-2012, 11:01 PM   #2
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
You won't see much gain on a stock vehicle if any. If you plan on adding a big cam or a stroker motor it makes a ton of sense.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 01-08-2012, 11:07 PM   #3
siriusdish
Drives: 2010 Camaro L99
Look into Vmax ported as well.
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 01-08-2012, 11:08 PM   #4
Ivan @ Southwest Speed
No.
Once you go FI or Big Cubes yes.
Port the factory one and pick up a NW TB unit and get it on!
Ivan
Old 01-09-2012, 07:21 PM   #5
MikeOD
Drives: 2010 M6 2SS
Depends where your goal for the vehicle lies...if you just want a basic bolt-on's car...I wouldn't bother...the $$$/HP ratio isn't really there for a car like that. If you want to go for the all out leave nothing on the table version of the car you want to build (and that version of the car is not a blower that'd replace the manifold)...then you can't not buy the FAST 102...a ported FAST 102 will hands down beat a stock or ported stock LS3 manifold...not by a lot, but it will beat it.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 01-10-2012, 04:28 AM   #6
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
You will loose power. I saw a test where the FAST lost power at every RPM until like 5k where it started to finally make power but only made a total of like 7RWHP. lol
The power it lost under the curve was big. This was on a Mast heads and VVT-2 cam with all boltons. The loss would have been even worse if you were putting it on a stock L99 heads and cam car. I would only use it on stroker combos or with a turbo or centri SC pumping into it.
Old 01-10-2012, 08:16 AM   #7
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
....one test negates everything
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 01-10-2012, 10:41 AM   #8
MikeOD
Drives: 2010 M6 2SS
It's amazing what sponsorship money can do to test results.
Old 01-10-2012, 10:52 AM   #9
JohnnyComeLately
JohnnyComeLately's Avatar
Drives: 2010 SS/RS
I have it installed. There was not a decrease in power. I plan to go blown (ProCharger) and do some other mods so it fits in the master scheme. FWIW, I have lab results on multiple runs, multiple cars showing increases in HP.
Both my rides will smoke ya 2010 L99 2SS/RS - Hertz HE HSK 165 components/PPI A404 & A600/JL Audio 10W6/Audio Control EQX, FAST Intake Manifold
JohnnyComeLately is offline   Reply With Quote
Old 01-10-2012, 11:13 AM   #10
VADER SS L99
Throughout the rev range? On a mild LS3? Would like to see the results.
The FAST intake was great for 97-2000 LS1 engines even in stock form as it increased power quite a bit but our LS3 intake is much, much better than the LS1 intake.
Old 01-10-2012, 11:16 AM   #11
MikeOD
Drives: 2010 M6 2SS
They don't advertise it as making as much over stock either because you're right, the stock LS3 manifold is better than the older LS1 and LS2 manifolds were (and to some extent probably better than the LS6 was as well)...but you definitely don't lose power with it.
Old 01-10-2012, 01:22 PM   #12
brantley847
v It bites.
..you better stop making sense ASAP... we will have NONE of that.
2011 2SS/RS
Old 01-10-2012, 01:53 PM   #13
pyr0b0y
need....more....hp
pyr0b0y's Avatar
Drives: The Neighbor Hater
just cave in....you know you want one! haha
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims
pyr0b0y is offline   Reply With Quote
Old 01-10-2012, 06:04 PM   #14
Go Fast Kid
Drives: Camaro 2010 SS LS7 427ci
LSX FAST intake
I installed the FAST intake on my LS7 427 ci, fully balanced , blueprinted, forged motor. 305 cc MAST heads, B&B header and exhaust system, cold air intake, full tune.
Not only did the motor lose power, their fuel rails do not fit their intake exactly square without grinding. The idler pulley interferes with the throttle body because the FAST manifold is not dimensionally exact to the stock manifold.
They left two fasterners and the pulley shim out of the box, I called to ask if they would sell me the missing parts, answer was no.
Save your money.
Go Fast Kid is offline   Reply With Quote
FAST LSXrt (LSXr race manifold) sneak peek HaveBlue Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 09-18-2009 11:43 AM
Fast LSXr Intake Gib Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 08-10-2009 10:55 PM
Fast LSXR 102mm intake My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 08-05-2009 11:08 PM
FAST LSXR Update: manifold, throttle body, race block HaveBlue Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 06-29-2009 07:22 PM
Fast or Slow Car stovt001 General Automotive + Other Cars Discussion 8 09-14-2008 02:31 AM
