HeadlightArmor
Old 01-09-2012, 04:10 PM   #1
MJ
MJ's Avatar
Drives: 2010 Camaro SS/RS
Heat shield rattles with exhaust cutout/diverter
Love the sound of open header exhaust with my NoWeeds, but am not liking the noise coming from the heat shield vibrating at certain RPMs. Tried bending shield to cut down on the resonance... helped a bit. Vibrations are starting to stress crack the shield. Am thinking of removing it, or at least cutting sections out but don't want heat transferring to the area above. Was thinking Dynnamat extreme, but have no experience with that material. Any ideas?
MJ is offline   Reply With Quote
Old 01-09-2012, 04:35 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
paint it with rubberized undercoating paint?
Parag is offline   Reply With Quote
Old 01-09-2012, 05:02 PM   #3
MJ
MJ's Avatar
It's close to exhaust... would melt or burn.
Old 01-09-2012, 06:30 PM   #4
Cal 20112SS
Drives: 2011 2SS/RS
Had the same problem with my GTO. Drove me crazy! Ended up buying some header wrap. Cutting it to size folded and wedged it behind the heat shields. Worked like a charm.
Cal 20112SS is offline   Reply With Quote
Old 01-09-2012, 09:53 PM   #5
MJ
MJ's Avatar
Good idea... got to look into that.
Old 01-09-2012, 10:05 PM   #6
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Hmmm havent noticed on mine but i may just be deff
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 01-11-2012, 03:11 PM   #7
MJ
MJ's Avatar
Rattle was hardly noticeable till I pulled out rear seats... is much louder now without seat to dampen noise. Pulled out rear seat to see if a pair of track tires would fit.
Old 01-14-2012, 11:11 PM   #8
jsharp
jsharp's Avatar
Well i gutted cats and now i hear some drone rattlecan stuff!
Old 01-15-2012, 05:34 AM   #9
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
So that's what that noise is! I have the qtp cuttouts and I've been hearing this for a while now. It almost sounds like a loose washer on a bolt so I've been making sure all my bolts are tight in the center consol since that's where it's coming from but they were all tight. It was driving me crazy, still is, that I couldn't find where it was coming from. And it's only when the cutouts are open and at certain RPMS. I'll have to get under there and check it out. Is it one particular spot that you found where it's happening? I'd like to stuff something in there as well. Let me know what you find and maybe take a picture of the area would be great.
Chad's ZL1 is offline   Reply With Quote
Old 01-15-2012, 01:21 PM   #10
camarossrs2150
camarossrs2150's Avatar
Drives: abm2ssrs
hey mike let me know what you use so i can install it before i install mine should be here on thursday or friday .
[SIGPIC]
camarossrs2150 is offline   Reply With Quote
Old 01-15-2012, 08:46 PM   #11
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Old 01-16-2012, 10:12 AM   #12
MJ
MJ's Avatar
I used some header wrap like CAL suggested... wedged it behind heat shield. Definately helped.
Old 01-16-2012, 12:35 PM   #13
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
what part of heatshield?
Old 01-16-2012, 01:33 PM   #14
MJ
MJ's Avatar
Just ahead of tunnel cross brace.
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 05:11 PM
ZR1 Spark Plugs? shines Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 63 12-18-2011 07:55 AM
WTB hennessey heat shield GEEo V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 06-02-2010 12:54 AM
Hennessey Cold Air Intake CAI with Heat Shield barrylnv V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 3 04-01-2010 03:52 PM
