Old 01-09-2012, 04:49 PM   #1
Parag
Drives: 2010 camaro 2SS LS3
methanol injection
can someone help explain how these systems work?
http://www.alcoholinjectionsystems.c...FcEUKgoduROB_Q
do they work more like nitrous, or are they always active?
Parag is offline   Reply With Quote
Old 01-09-2012, 04:52 PM   #2
camslambam
Drives: 2010 SS, 06 SRT10 Ram
Pretty sure there different setups?
The ones I've seen work on WOT when your boost kicks in.
camslambam is offline   Reply With Quote
Old 01-09-2012, 04:57 PM   #3
SC2150
Methanol injection is to cool the Intake Air Charge and adds a slight amount more fuel (but not alot as methanol is a 3:1 ratio compared to gasoline).
Nitrous is a oxygenator power adder that allows for more fuel to be introduced to the combustion mixture thus more power released per explosive event.
Both are controlled activation where meth inj is usually boost referanced Nitrous is wide open throttle & rpm based.
Old 01-09-2012, 05:01 PM   #4
Parag
so they more just stabilize your fuel system?
can you run methanol and nitrous? on a boosted car
Old 01-09-2012, 05:02 PM   #5
camslambam
Well down here where our gas is 91 at best (probably an 89 in the US) we use 50% seco (a liquor you drink) and 50% pure alcohol 98% concentrate. Bumps the octane up to about 106~ we calculate.
Works wonders on all FI v8s here.
Old 01-09-2012, 05:05 PM   #6
Parag
do you keep that mix in a different tank and inject it in when under heavy boost, or just straight in the tank?
Old 01-09-2012, 05:09 PM   #7
camslambam
It's a seperate tank in the trunk.
Looks like this
AT WOT it injects the mixture and ups the octane level thus letting you boost safely.
There are different size tanks of course. Also depends how you drive.
Good thing about vortechs and such are they require high rpm to enter boost, unlike maggie, so you can DD it out of boost regularly and easily.
Old 01-09-2012, 09:55 PM   #8
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
I am running this kit from Snow in my Camaro and Silverado.
http://www.snowperformance.net/product.php?pk=75
They make a great product. Next month I will have a full editorial on the Snow installation on the Camaro.
MRGOODWRENCH3 is offline   Reply With Quote
Old 01-17-2012, 02:49 PM   #9
denooo11
Dean Voss
Drives: 2010 Camaro SS
Send a message via AIM to denooo11
I have a snow kit and a blower. Stage 2 or 3 I don't remember, but I set it on injector impulse. That is the best way to set the system !! deno---
denooo11 is offline   Reply With Quote
Old 01-17-2012, 06:43 PM   #10
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Installed my ALKY system a week ago. This thread has some pics and some decent info.
http://www.camaro5.com/forums/showthread.php?t=195370
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 02-12-2012, 02:38 PM   #11
Rodney@AIS
Drives: ProCharged Mustang
Systems can be triggered in a few different ways. Our boost activated systems let you adjust the activation point as to when you want it to come on. Systems can also be activated and controlled by he out put signal on your MAF. Additionally, guys can use a WOT switch.
The systems are not always active and only spray when the users defines them too. Hoe this answers your question. Let me know if you have any other questions or how i can help.
Rodney
Rodney@AIS is offline   Reply With Quote
Old 02-12-2012, 02:49 PM   #12
Man1acs
Drives: 2010 IOM Camaro SS
I Converted my wiper fluid into methanol tank.
Man1acs is offline   Reply With Quote
Old 02-12-2012, 02:52 PM   #13
Man1acs
Noss is different, if you have watched Fast and Furious then you know when you hit that button you go to 300MPH then drop down to 100MPH after a few sec
Old 02-13-2012, 10:27 AM   #14
jordi cami
Drives: camaro 2ss inferno orange
This kits need custom tune??
jordi cami is offline   Reply With Quote
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 04:56 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
Coolingmist Q & A, lets talk Methanol Injection! coolingmist Forced Induction - V8 4 06-29-2010 09:25 PM
