Old 01-28-2012, 09:53 PM   #15
Les_Paul
Drives: 2012 2LT A6 Ashen Gray Metallic
The good times lasted a week. Service Stabilitrak was back...haunting me again tonight. I hate seeing my dash board light up. This is so frustrating. Anyone know anything about the Texas Lemon Law?
Also, one thing I've noticed is most of the time Service Stabilitrak comes on in cold weather. Tonight was the first night since the wheel sensor replacement that was in the 50's and boom, back on. Do you think the temperature could be causing the malfunction?
Les_Paul is offline   Reply With Quote
Old 01-28-2012, 10:14 PM   #16
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
When I changed my wheels this used to happen to me when I got speeds over 50 Mph. Mine had to be reprogrammed, took like 4 hours.
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 01-28-2012, 10:22 PM   #17
Les_Paul
I wish I could say I changed my wheels......but I haven't lol
Old 01-29-2012, 07:18 PM   #18
Les_Paul
Could the ecm be getting bad information in cold weather because of my airaid cai? Would that trigger service stabilitrak?
Old 02-05-2012, 11:06 AM   #19
Les_Paul
Ok, well the temperature finally fell again in Texas and no Service Stabilitrak. Maybe this shows the problem resolved itself?
Old 02-05-2012, 12:13 PM   #20
shaggy1
The thin blue line
shaggy1's Avatar
Drives: 2012, 2SS/RS,LS3,IOM/Beige
I havent had this problem with my Camaro but I did get that message on my new Silverado 1500 4x4 Z71 and it was the steering sensor also.
shaggy1 is offline   Reply With Quote
Old 02-14-2012, 02:22 PM   #21
thejudgemeister
Thejudgemeister
Drives: 2012 Camaro 2LT RS Summit White
I got that message on my 2012 2LT after driving it around a few turns at Lowe's Motor Speedway... Slowly :(. OnStar did a diagnostic and said that it was most likely because of the banking. It did reset after a few restarts though.
thejudgemeister is offline   Reply With Quote
Old 02-15-2012, 08:27 AM   #22
Les_Paul
Why did Chevy make a warning message that literally has hundreds of potential causes? Most of them unrelated?? It seems to negate the benefit of the message....
And thanks for the input judgemeister!
Last edited by Les_Paul; 02-15-2012 at 08:27 AM. Reason: Forgot to leave a thank you
Old 02-15-2012, 09:29 AM   #23
mat300z
Emerald Coast Camaro's
mat300z's Avatar
Drives: 2014 ZL1
I tapped into a ground wire and my service stabilitrack came on. I took out the tap and grounded directly to the frame and it went away. This could be from something not grounding right in cold weather especially from the harnesses.
mat300z is offline   Reply With Quote
Old 02-15-2012, 12:12 PM   #24
Les_Paul
Where would I look for faulty grounds? The previous owner installed the CAI so I don't know how it was installed.
Old 03-04-2012, 07:16 PM   #25
Les_Paul
Just wanted to give everyone an update...I have contacted GM about my situation and they have proactively begun assisting me. GM contacted my dealer and set up an evaluation meeting with the head of the service department. Things are happening much more quickly now, but unfortunately the problem has still not been resolved. Again, GM is now working with me on this issue and hopefully we will come to a solution soon.
Old 03-04-2012, 10:29 PM   #26
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
Only 14k miles on my car, I will be taking it in for the 4th time this week for this same issue. Maybe I should contact GM customer service first.
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
Old 03-05-2012, 06:32 AM   #27
SteveRS
SteveRS's Avatar
Drives: 2010 SIM Cobalt SS
Send a message via AIM to SteveRS
Only thing GM is going to do is just WTF the dealer and make suggestions.. i had electrical issues with my V6 and they wouldnt buy it back or let me trade.. they exhaust all avenues before they do that stuff.. dont bet on some divine intervention.. ive learned 3 times not to have high hopes..
2011 Imperial Blue 1.5SS
2010 Silver Ice Cobalt SS
SteveRS is offline   Reply With Quote
Old 03-05-2012, 06:32 PM   #28
Les_Paul
What ended up happening? Did you ever attempt to use the Lemon Law?
lights, service stabilitrak
service stabilitrak at 106mph 2revbigbore Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 11-25-2011 04:44 PM
Lets Talk About Extended Warranties for our 2010 Camaro's from the Dealership a Sec.. Black LS3 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 39 03-21-2010 11:38 AM
Laws Protecting Consumers for Aftermarket Parts strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 9 01-17-2010 08:31 AM
Piston to Valve Clearance? My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-18-2009 07:26 PM
Service Stabilitrak! Davis Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 5 07-29-2009 01:45 PM
