HeadlightArmor
Old 01-11-2012, 06:30 PM   #1
harrington81
Drives: 2010 camaro 2ss red jewel
rough idle after intake install
can somebody please delete this thread!
harrington81 is offline   Reply With Quote
Old 01-11-2012, 06:39 PM   #2
molsonbrador
molsonbrador's Avatar
Drives: 2010 Camaro SS, 99 Silverado
How much better when warm? I'd check the hose clamps, maybe they loosened up in the cold weather.
molsonbrador is offline   Reply With Quote
Old 01-11-2012, 06:52 PM   #3
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
Have you run a full tank of gas through since it started running rough? Is the check engine light on?
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 01-11-2012, 06:53 PM   #4
eclipsen
Drives: 2010 Camaro 2SS/RS
I would check all the hose connections again. Also check the orientation of the MAF.
2010 Camaro 2SS/RS, 6M, ADM Race scoop, CAI intake, VMAX TB, Kooks LTs, Solo Mach X, MGW Shifter, Dynotech driveshaft, 1LE 3.91 gears with JRE updates, BMR bushings/Toe/Trailing Arms, Pedders ZL1 sways and XA Coilovers, Heritage Grill, Yenko side stripes, SS emblems, Havoc Rear Spoiler.
eclipsen is offline   Reply With Quote
Old 01-11-2012, 06:57 PM   #5
harrington81
I will check the hoses and clamps. What's the orientation of the MAF? And yes i've ran several full tanks through. No check engine light. If it had one i would've scanned it a long time ago.
Old 01-11-2012, 07:02 PM   #6
eclipsen
I seem to remember that the MAF could be installed backwards. The locking tab should be up.
I also added silicon gasket maker around the MAF for better sealing.
Old 01-11-2012, 07:05 PM   #7
harrington81
The arrow points to towards the throttle body. That's the way i did it.
I do remember sometimes when the car was cold I would let out the clutch and it would sputter and shake like crazy. Only sometimes and not for very long.
Old 01-11-2012, 07:14 PM   #8
Majic
Majic
Majic's Avatar
Drives: 2014 2SS/RS. Crystal Red.
Sounds like an air leak to me.
Rick
"MAJIC"
2014 2SS/RS.
Majic is offline   Reply With Quote
Old 01-11-2012, 07:16 PM   #9
DrkPhx
DrkPhx's Avatar
Any trouble codes? If it hasn't been tuned after the CAI install, that could be the problem, but you need to verify it with a scan tool.
Old 01-11-2012, 07:22 PM   #10
alybudhwani
alybudhwani's Avatar
Drives: 2010 Camaro 2SS Aqua Metallic Blue
http://www.camaro5.com/forums/showthread.php?t=167460
check out my build
seriously though...
alybudhwani is offline   Reply With Quote
Old 01-11-2012, 07:22 PM   #11
harrington81
Excactly. I would never do this mod again without it being tuned. But voiding the warranty ain't gonna happen.
Old 01-11-2012, 07:31 PM   #12
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
Leak
Vacume leak !
Don't need a tune.Had mine on since 2010 .No problems.Ever.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 01-11-2012, 07:37 PM   #13
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
I just had the same exact problem... When it started getting down around 20-30 degrees F.
I found two things...one the small vacuum hose running from the intake to the engine had a small crack in it. ( however I don't believe this was the issue at all) second was all the hose clamps were loose especially around the throttle body and the filter was barely on. I tightened all of them and it runs great. Mine eventually threw a codes p0174 and p0171. After tightening clamps I the codes and they haven't come back. The LS3 sucks a ton of air and from what I've read too... much an the computer can't compute the air fuel curve.
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 01-11-2012, 07:38 PM   #14
jcollins91106
Drives: 2010 2ss m6
*reset the codes* sorry for the typos.... Sending from phone
