GM Parts House
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - New England
Old 04-22-2009, 12:05 PM   #1
69Firebird
69Firebird's Avatar
Drives: 2010 Black 2SS/RS LS3
Question Headers in MA
Anyone have any experience with Long Tube Headers in MA?
I know that because you need to move the Cats a bit that they are technically not Emissions legal, but from what I can tell as long as its tuned properly the car should pass the OBDII Test they run at Inspection time.
Had anyone put Long Tubes on another car? Have you ever had any issues getting an inspection sticker?
Thanks!
Delivered 8/4/09: Black on Black 2SS/RS, LS3, CGM Stripes, Polished Upgrade
K&N Typhoon Intake, Stainless Works 3" Catback w/ S-Tube Turbo Mufflers
69Firebird is offline   Reply With Quote
Old 04-22-2009, 02:42 PM   #2
69Firebird
69Firebird's Avatar
http://massvehiclecheck.state.ma.us/about_whywhat.html
Massachusetts apparently as of October changed their Emissions testing requirements.
They used to have any car '84-'95 on a Dyno and used an exhaust sniffer, but now it looks like they only use OBDII checking on newer cars. Looks like I can get rid of the Cat on my '85 Trans Am.
I don't see anything about a visual inspection of emissions equipment, maybe just passing the OBD is good enough?
Old 04-22-2009, 03:14 PM   #3
JMM1181
Drives: '07 350z
Good luck with headers, I had them put on my last car which granted was a Hyundai Tiburon, but it led to a series of nightmarish battles with emissions testing, needless to say almost a year passed with a failed inspection sticker and I had to get rid of my car mostly because of the hassle. I did have all 02 sensors plugged in, a hi-flow cat, and was throwing no codes. I should add that I also had the ECU reflashed which would certainly cause it to not pass due to the altered A/F & timing settings, but even before I had the reflashed ECU put in it was not passing. I think it might be a gamble, MA has gotten absolutely ridiculous with their emissions testing lately.
JMM1181 is offline   Reply With Quote
Old 04-22-2009, 09:40 PM   #4
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
As long as you have no Check engine light you can pass. Just need to be friends with them a bit if the car is on the edge. So they look past things like exhaust volume or cats being moved.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 04-22-2009, 09:58 PM   #5
latemodel3
latemodel3's Avatar
Drives: 2010 camaro rs/ss
x2
2010 camaro 2ss/rs m6 inferno orange custom black stripes orange int.bmr 1.0 drop springs xs stainless 1-7/8 headers and 3" catless exhaust lsr sway bars bmr trailing arms /toe rods bmr diff bushings /craddle inserts black whipple 3.75"pulley ID injectors lpe twin pump jre rough idle blower cam rx catch can and cai intake w/ scoop sct tuner from jre 690rwhp/588rwtq on 93 octane
latemodel3 is offline   Reply With Quote
Old 04-22-2009, 11:20 PM   #6
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Yep... get friendly with a local performance shop. If they are a good performance shop I promise you they do it all the time!
If you want a good deal you can check out the Group Buy thread in the LS3/L99 forum.
ZZcamaro is offline   Reply With Quote
Old 04-23-2009, 04:13 PM   #7
tones2SS
tones2SS's Avatar
Angry
If you get long tubes in Ma, you would have to swap them out before every car inspection and throw the original ones back on and so forth.
The inspections in MA are T-O-U-G-H!!!
Old 04-23-2009, 04:30 PM   #8
JMM1181
Drives: '07 350z
exactly, I really don't care that people still believe you can be 'pals' with a guy and have him pass you, because the computer hooks now directly into the Registry and matches VIN with the actual readings , and no matter how much the guy knows or likes you, you are SOL if you can't pass the computer section (every 2 yrs for newer cars) short of putting it back to stock for inspections.
Old 04-23-2009, 04:53 PM   #9
Super83Z
Super83Z's Avatar
This is not true. The LS1 4th gen F-bodys cats were located so far from the engine that Long tubes are perfectly legal. The same may be true for the 5th.
Its not a "belief". I don't think you have much understanding of how an inspection works. When they plug-in they are just searching for codes. That is all. The rest is a safety check. As long as the headers retain any emissions connections and don't relocate the cats they are perfectly legal. The only time you would need to be "pals" is if you relocated the cats and don't want them to say anything about it.
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 04-23-2009, 08:25 PM   #10
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
In RI they plug in to the OBDII connector and stick a sensor in the exhaust while the car is on the dyno. I guess if your buddy was really willing to risk his inspection license, he could put the sensor in another car's tailpipe. I don't know if the system is smart enough to detect someone doing that.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 04-23-2009, 08:42 PM   #11
JMM1181
Drives: '07 350z
Ok, I wrote above that I spent almost a year trying to get my car to pass inspections without a single CEL (as in 'code' or check engine light), I attempted to pass on at least 5 separate occasions, I believe by now I do happen to have a pretty good understanding of how inspections work thank you very much. The emissions testing is more stringent now in MA, they will check for stock A/F ratios in addition to the normal tests they run, if anything is off it will not fail but show as 'system not ready' - as long as it's considered 'not ready' you will be rejected. Believe what you want, but like I said, good luck, you'll be dealing with it and not me.
Old 04-24-2009, 05:31 PM   #12
latemodel3
latemodel3's Avatar
Thanks!
just put them on i'm gonna and if you have trouble with inspection contact me i'll hook you up
Old 04-24-2009, 06:24 PM   #13
Super83Z
Super83Z's Avatar
That's why cars that get headers get a custom tune also. Re-flashing the ECM will not take care of it.
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 05-09-2009, 04:30 PM   #14
tones2SS
tones2SS's Avatar
Question Are you sure?
Is this from fact?
I thought long tube headers pushed the cats further back down the car and thus not making them legal? I may be wrong.
Headers for the V6? Xanthos Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 49 08-04-2011 01:51 PM
Headers Question SIK07GTSTANG Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 04-23-2009 08:14 PM
Any updates to pricing on Shorty Headers? Crowley Camaro Price | Ordering | Tracking | Dealers Discussions 1 01-23-2009 12:14 PM
Aftermarket Headers and Exhaust destroyer4 5th Gen Camaro SS LS LT General Discussions 8 11-30-2008 07:46 PM
lets talk headers TFord 4th Generation Camaros 7 04-30-2008 01:07 PM
