01-11-2012, 10:37 PM | #1 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Fans for brake cooling
So I've been researching how to install brake ducts in the Camaro to help with track days. Some interesting threads so far on the forum. So while thinking about a way of pulling air from the front facia, I came across an inline duct blower and was wondering if instead of cutting holes this would work.
Allstar Performance 3" Heavy Duty Inline Blower - 8" Long - 170 CFM Add one of these fans on both sides somewhere up towards the front facia. Feed the duct tube through the wheels well like others did and attach to a brake duct intake. The advantage would be air blowing on the brakes even after you pull off the track. Just not sure 170 CFM is enough flow. They make a 4" blower that puts out 240 CFM. I'm just not sure about running 4" ducting and attaching that to a 4" duct intake mounted on the rotor shields, whether there's enough metal to accommodate that size duct. Opinions?
03-01-2013, 08:24 AM | #2 | |
Drives: RY 2011 2SS A6 Join Date: Jul 2010
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts. |
03-01-2013, 12:16 PM | #3 |
Would be very handy as you stated to let run after you park. space might be tough to come up with.
03-01-2013, 04:03 PM | #4 |
Drives: cars Join Date: May 2011
These brake scoops look interesting too instead of taking air from the front of the car/radiator. The fog light would probably be the "right" spot to get air from but I'm working to keep my car as visually stock as humanly possible.
http://forums.rennlist.com/rennforum...-mod-pics.html Although getting it directed to the hub would be tough without some hose in conjunction with a scoop under the car. When possible I like to keep it simple and avoid motors/wiring where not necessary. It wouldn't move as much and be dependent on vehicle speed though. |
03-01-2013, 04:08 PM | #5 |
Another interesting one with pics
http://forums.pelicanparts.com/porsc...e-cooling.html |
03-01-2013, 04:13 PM | #6 |
Don't think there'd be space for this on our cars and I question the amount of air it would get entering the actual rotor vanes versus getting it on the outer wear surface
http://ultracoolbrakefans.com/main/u...ron=1362175818 Cool concept though. Watch the video on the home page. |
Thread Tools | |
Similar Threads | ||||
Cooling Fans, part 2 | RJTC11SS | 5th Gen Camaro SS LS LT General Discussions | 6 | 02-06-2011 07:02 PM |
Cooling Fans | RJTC11SS | 5th Gen Camaro SS LS LT General Discussions | 4 | 02-06-2011 11:02 AM |
WTB OEM Stock Cooling fans for LT v6 | shy68 | Exterior Parts & Accessories | 1 | 01-08-2011 08:15 AM |
fans cooling | Gr8_syder | 4th Generation Camaros | 5 | 06-23-2010 09:50 PM |
Great Read and Info on Oil Weight | Banshee | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 1 | 11-23-2009 09:03 PM |
