sjm autoprod
Old 01-12-2012, 11:47 AM   #1
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
Cool MRT Exhaust Drone + X-Pipe = ?
I'm getting some drone at highway speeds with my MRT. It's not bad but at times I find it a bit annoying.
I know that it needs more time to break in. I also know that drone won't go away after the break-in period.
I'm wondering if an X-Pipe would eliminate some of that drone? If it makes the exhaust a little quieter, so be it, but I'd like to eliminate the highway speed drone and I don't want to do that curvy Helmoltz pipe thing I've seen here.
What will an X-Pipe do for me, how hard are they to install, and which should I order? I've heard a "resonated" x-pipe is the way to go, can someone tell me the visual and mechanical difference between a resonated pipe and a regular one, and maybe link me to a few that are for sale? Fill me in fellas, I'm new to the exhaust game.
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 01-12-2012, 11:56 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
Give it a couple of weeks to a month. The actual drone will not lessen but you'll become used to it and it will become almost non existent unless you listen for it. I've had my MRT 2.0 for about 5 months and would swear I have no drone, although I know there is some.
FSP tuned: 377/389
Old 01-12-2012, 12:00 PM   #3
Mach
Mach's Avatar
Drives: White M6 1LT RS
Nothing beats drone better then Helmholz pipes. Here's my and Saint Alban's research and setup with the MRT2.0....
http://www.camaro5.com/forums/showthread.php?t=182467
29 inch pipes should kill that annoying 120HZ MRT2.0 drone zone.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 01-12-2012, 12:18 PM   #4
KMPrenger
KMPrenger's Avatar
If you don't want to do the "curvy" pipes, and you find that you aren't will to just get used to it, then the next bet is going with a magnaflow resonated X pipe.
Everyone says it helps to cut drone, but you will also tame down your exhaust note as well...so it is a bit of a compromise.
Old 01-12-2012, 12:29 PM   #5
BowtieBelle
I really don't have the equipment to do that... I've got a gravel driveway, no lift, no welder, etc... it seems time-consuming, as well?
I don't mind toning it down a little, as it'll still be much louder than stock. Can one of you link me to where I can purchase it? Do I have to have the whole kit that's like $300, or just the x-pipe? How difficult is the install?
Old 01-12-2012, 12:31 PM   #6
Mach
Mach's Avatar
Saint Alban had a muffler shop make his. All you need is to buy three J pipes on Ebay and take them to a muffler shop. I think he paid less then a x-pipe would cost.
Next mod: Done!
Old 01-12-2012, 12:49 PM   #7
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM 2SS
It depends on how much the drone is bothering you....
1) J-Pipes = If the drone is really buggin you than no better option. You will have to fab up the mufflers that you bought though. The install can be a little involved, and my personal belief is that it add some of the weight back in that you lost by getting rid of the stock suit cases.
2) Resonated X-pipe = Magnaflow has a great x-pipe, few people have installed it and I think you can find their threads in the exhaust stickey. If you can stand a little bit of drone, then this is the way to do it, you will have to fab up your stock mid-pipes. You will have to remove the stock h-pipe and place the resonated x-pipe and weld it up. For me this is the least challenging install.
Link: http://www.camaro5.com/forums/showthread.php?t=81361
Good luck
Blade is offline   Reply With Quote
Old 01-12-2012, 12:57 PM   #8
Saint Alban
Saint Alban's Avatar
Drives: '14 Black 2SS RS
Yup, the drone was bothering me way too much and i couldn't get use to it. I don't remember how much an x pipe goes for but the muffler shop charged me $200. Some may charge you less. It gets rid of the drone but you keep your exhaust tone during acceleration and startup. It was such a relief when I drove out of there.
Saint Alban is offline   Reply With Quote
Old 01-12-2012, 01:01 PM   #9
Saint Alban
By the way, it was the first time my muffler guy ever did something like that before but he said he has experience in making custom exhausts. So just make sure you find an experienced guy if you do end up doing this. No pressure though, it's up to you. I just can just positively tell you this works.
Old 01-12-2012, 01:14 PM   #10
MichaelH
SOCAL HT5
MichaelH's Avatar
Drives: 2013 BRM ZL1 M6
to be honest i really dont notice any drone on mine and i have LT with mine and mines also the v1.0 just put some more miles on it and i think itll lessen
2013 ZL1 M6 - Mods-in the works
Old vehicles
2010 CGM Camaro (sold)
Other Vehicles:
2008 Kawasaki ZX6R-115 RWHP in mid summer
2006 Chevy Trailblazer SS- For Sale; Lots of extras
MichaelH is offline   Reply With Quote
Old 01-12-2012, 01:16 PM   #11
Mach
Mach's Avatar
It's all subjective. But you don't notice the BRRRRRRR while cruising on the highway?
Next mod: Done!
Old 01-12-2012, 01:18 PM   #12
MichaelH
SOCAL HT5
MichaelH's Avatar
to be honest no not really i have a rumble but thats about it, but when i go up a hill thats when i get that annoying brrrr where the whole car shakes and bad drone
Old vehicles
Other Vehicles:
Old 01-14-2012, 10:56 AM   #13
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
I agree with what others have said. On my 2ltrs A6 I had shorty headers,Ingen and mrtv2 and that combo is louder and drones a bit. Get miles on it first though. I put on a 1000 before it tamed down and the interior drone moved from the back seat to out to the back of the car and outside. Now I did have the resonated x pipe already and the stock ones, but to compare when the mrt's were put on I had the stock resonatord taken off, figured I didn't need them. WRONG! THAT THING WAS LOUDER THEN HECK INSIDE! Put them back on till the mufflers broke in, then they were not needed, Xpipe took care of most of the drone/boom on its own.
Side note I just put the flowmaster Outlaws on the SS, barks like a cannon on start up and a bit boomy inside at 1500-2300 rpm when accelerating, but same principle, need to let them break in more and ecu adjust to the setup. If not will use the res x pipe or some flowmaster resonators to tame any drone
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And Pedders 27mm/32mm sway bars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 01-14-2012, 11:59 AM   #14
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
could try downshifting on the hills... bump the RPMs up and get above the annoying zone...
scrming is offline   Reply With Quote
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 557 12-19-2017 04:31 PM
MRT Exhaust Now @ MarylandSpeed! Free Shipping and Best Prices! MarylandSpeed V6 Bolt-Ons & Tunes 17 07-13-2012 11:13 PM
WTB: BBK LT headers, BBK x pipe, or MRT 2.0 exhaust carrs_crew V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 11-30-2011 04:27 PM
I'm 16 (2010 Camaro SS) and want headers and loud exhaust, what should i get? DuhKoDuh Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 85 09-12-2011 11:04 AM
