Solo Performance
Old 01-12-2012, 12:27 PM   #1
mpyle007
mpyle007's Avatar
Drives: 2011 Camaro 2SS L99
L99 question (Headers back)
I am about to get some headers and high flow cats for my L99. I have a GMPP axle back right now that I planned on leaving along with the factory mid pipes. I was told the factory mid pipes arent restrictive but here is my question.
In the morning when I start my car and it is cold out I hear a slight rattling. What is this caused from? If this could ever be from those mid pipes I want to eliminate this problems at the same time I install my LT's. If I did this I will probably just buy a whole cat back system. I still can not find any solid video clips of Camaros with long tubes and a gmpp axle back.
Thank you for everyone's help.
I will be buying Dynatechs, Kooks, or Texas Speed headers. Havent decided yet.
Do all of these go around the steering shaft with out having to remove it?
2011 Camaro 2SS L99 A6
Rotofab CAI w/ race scoop
TSP Long tube headers w/ high flow cats and full x-pipe
GMPP axle back exhaust system
Custom Dyno tune by ARD (Advanced Racing Dynamics)
BMR 1.4" Springs all four corners
"There is no replacement for displacement"
mpyle007 is offline   Reply With Quote
Old 01-12-2012, 09:39 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
The rattling could be a mulititude of things. It's hard to diagnose what it is without looking at it. I'd start by look at the axleback clamps. When the pipes are cold, it could be causing a exhaust leak which can sound like a rattle, then it goes away when the pipes heat up and expand. There should be no problem fitting your LT's to the OEM exhaust and plenty of people do this. Personally, I don't see the need to spend $800+ on a catback when you're replacing 2.5in tubing with 2.5in tubing. Some just like having a complete system and that's fine too. Replacing the resonator/H pipe section with a X pipe is a good weight savings and gives the exhaust a little different sound.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-12-2012, 09:41 PM   #3
stso634
stso634's Avatar
Drives: 2010 Camaro 2SS/RS
My TSP 304 headers did not require touching the steering shaft. Fit was perfect and installation was a breeze.
stso634 is offline   Reply With Quote
Old 01-12-2012, 10:00 PM   #4
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
Check for pipes rubbing on the tunnel brace or could be the heat shields ratteling.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 01-12-2012, 10:28 PM   #5
mpyle007
mpyle007's Avatar
I found the video of your car. Are you happy with the sound of headers with the Gmpp catback? How much did the volume and tone change?
Old 01-12-2012, 10:30 PM   #6
mpyle007
mpyle007's Avatar
It sounds like metal rattling near the middle of the car. I just broke 6500 miles? I'll get it on a lift and look when I install the headers.
Old 01-12-2012, 10:38 PM   #7
AC
***GO HOGS GO***
AC's Avatar
Drives: 68/327 & 10 2SS SIM w/ CGM Stripes
I had a rattle that was coming from the resonator. Apparently something came lose inside the resonator. Dealer was going to replace it but I just went with the x-pipe.
ProCharger F1A, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension, CCW 10"/11.5", DBA Rotors, 3.91's, 560/570 hp/tq
ProCharger F1A, VMax TB, ID1000 Injectors, SW Headers, SW full 3" Exhaust, BMR Suspension & 4 Point Strut Tower Brace, 3.91 Gears, DBA Rotors
Heritage Grille, CCW SP16a Wheels 10"/11.5" Nitto 275/40 315/35, Painted Calipers, Blackout: Bowtie, Rear Panel, Markers & Side Vents,
SS Fender Badges, 6.2L Cowl Lettering, Pistol Grip Shifter, RPI SS Door Kick Plates, Billet Cup Holder, Fesler Shift Boot, Lloyd Floor Mats..(1/4: 12.917 @ 109.63)
AC is offline   Reply With Quote
Old 01-12-2012, 10:39 PM   #8
thesnoopster
thesnoopster's Avatar
Drives: '10 SIM SS/A6 - '12 SIM Equinox LT
That's most likely the tunnel brace vibrating against the exhaust pipe.....add some washers to the bolts and that should kill that noise. If that aint it, it could be the resonator ... I think some have experienced with something breaking off in the resonator and rattling inside. Those are the only two I could think of.
2010 SIM Camaro 1SS/A6
Mods: "93 Octane and a baby seat..." TunedByFrost/EFI Performance,LLC @ PAS "You gotta love me ... or leave me alone"
Old 01-12-2012, 11:27 PM   #9
klatterblast
You will probably find the culprit when you install the headers just bump the exhaust with your hand and try to make it rattle.
Old 01-12-2012, 11:40 PM   #10
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Yup. Like the others said it's gonna be really easy to find when it's up in the air.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 294 04-09-2018 07:41 PM
NEW GROUP BUY- Solo Performance Axle Back with J pipes & Mach XL (L99) with J Pipes GOINGSOLO2 V8 Bolt-Ons & Tunes 130 12-20-2011 07:15 PM
My review on OBX headers sfgiantsfan9 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 37 01-13-2011 03:12 PM
Question about back pressure and torque firengnred Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 02-18-2010 11:42 AM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 03:04 PM
