Old 01-12-2012, 05:54 PM   #1
Black1SS
Black1SS's Avatar
Drives: 2010 Camaro 1SS/RS 6 Speed
Pros and cons
Hey guys,
I wanted to get the pros and cons on running LT headers with and without high flow cats. I live in SC were we dont have to get inspected so we dont have to pass emissions.
I wanted to get the opinions of the masses on what the differances would be with or without the high flows. I have a 10 LS3 Camaro 6 speed manual. I also want the gains in power and torque but I dont want the car to be over powering when it comes to the exhaust sound. I want a little louder than stock when idling and WOT.
Any help and opinions would be greatly appreciated. Start laying out the differances guys.
Thanks
Black1SS is offline   Reply With Quote
Old 01-12-2012, 06:07 PM   #2
Cpanthers85
Drives: 2011 Camaro 2SS RS
From what I've been told, the high flow cats are so advanced today that the only difference between running cats and not running cats is the exhaust smell.
I opted for no smell and healthier lungs.
2011 2SS/RS L99
2013 Cadillac ATS 2.0 AWD Replaced- 2009 Cobalt SS- SOLD!
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 01-12-2012, 06:12 PM   #3
Black1SS
Black1SS's Avatar
I guess the next question is for the extra money for the high flows then, is it really worth it to just have the smell reduced a little. Either way, there is going to be a smell. Just less with the high flows
Old 01-12-2012, 06:29 PM   #4
Big Daddy Kane
Big Daddy Kane's Avatar
Drives: Red 1SS
I just went from high flows to no cats. You do get more smell, but basically it's like smelling the exhaust from a 60's muscle car. It was a tad louder. Not much at all. As for power difference. I drove the car a mile down the road and back, so I haven't really driven it since the switch over.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces
Big Daddy Kane is offline   Reply With Quote
Old 01-12-2012, 06:33 PM   #5
ron10
Drives: 2010 2SS IOM L99
we don't have inspections here either.all my friends are deleting the cats on their cars,as will i,when i get my LTs.
Old 01-12-2012, 06:45 PM   #6
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
Sounds better without cats in my opion. I don't run them, but if you want to keep it kinda quite then just run a quite muffler. My car is pretty friken loud!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 01-12-2012, 09:43 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you have thoughts of adding a SC, you should save your $$ on the HFC's. Many of the SC guys are destroying their HFC's with the added exhaust volume and heat. Haven't heard of any NA guys having any problems though. Just something else to consider.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-12-2012, 09:51 PM   #8
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Yeah just run without them. If you not have emissions dont worry about it.
JLE58 is offline   Reply With Quote
Old 01-12-2012, 10:07 PM   #9
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
What did you just say? HFCs, NA, SC
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 01-12-2012, 10:07 PM   #10
Black1SS
Black1SS's Avatar
It doesn't make very much differance in the sound with or without them, correct. I guess since I don't have emissions here and the smell will not be that much worse, I will go without the cats to save some money for other mods. Any other advice is welcomed. Thanks for helping everyone
Old 01-12-2012, 10:24 PM   #11
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I'm thinking your lungs will be ok.
It's really not that big a difference.
Old 01-12-2012, 10:58 PM   #12
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
I deleted cats with the LT's and with no tune yet I have noticed no fuel smell.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 01-13-2012, 08:52 AM   #13
Black1SS
Black1SS's Avatar
So I guess the view on the forum is that if your state does not require a smog test for inspection then run LT's with no cats at all.
Old 01-13-2012, 09:11 AM   #14
PQ
Booooosted.
PQ's Avatar
No. The view of some in this thread to this point.
Pros & Cons of deep lip and no lip? ssmike Wheels and Tires Talk Sponsored by The Tire Rack 3 10-12-2011 12:30 PM
2 Piece Driveshaft or 1 piece? Can anyone explain pros and cons and design issues? 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 09-16-2010 07:46 PM
Nitrous Kits - Pros and Cons? attymf Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 07-10-2010 11:37 AM
What do you think the pros and cons are of these colors? Ant 5th Gen Camaro SS LS LT General Discussions 18 03-22-2009 06:33 PM
