Cold Air Inductions
Old 01-12-2012, 10:46 PM   #1
Drago77
Treasure Coast Camaro 5
Drago77's Avatar
Drives: SW 11' 2SS/RS LS3 Vert, Blk/Blk
anyone relocate the washer bottle W/O buying the kit?
I've been meaning to do this for awhile;
I've got a K&N Typhoon intake and also the Sillen grille vents. Been planning on routing from the vents to the air filter just haven't figured out what to do with the washer bottle. Not that its A LOT of $$$, but id rather not purchase the relocating kit.
Has anyone successfully moved their washer fluid bottle without an after market kit yet?
Searches yield exactly why I'm looking for... but with the purchased kit.
Drago77 is offline   Reply With Quote
Old 01-12-2012, 10:49 PM   #2
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Im sure you can rather easy I will look at mine in the morning.
JLE58 is offline   Reply With Quote
Old 01-12-2012, 10:51 PM   #3
Drago77
Drago77's Avatar
Gotta be a way... was hoping to find some ideas before removing the bumper again... tedious
Old 01-12-2012, 11:21 PM   #4
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
Look at my build post #14. There is also a link with more info.
http://www.camaro5.com/forums/showthread.php?t=127900
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
Old 01-13-2012, 12:19 AM   #5
Drago77
Drago77's Avatar
Thanks man! You got me right where I needed to be! Modding a $20 catch can from eBay, good look, functional and opens the space- perfect! Thank you!
Old 01-13-2012, 10:40 AM   #6
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I relocated mine to the garage attic.
Old 01-13-2012, 11:55 AM   #7
caverman
caverman's Avatar
Drives: '69 SS Convertible
Here is what I did. Still working just fine.
http://www.camaro5.com/forums/showth...light=halltech
Build Journal
Old 01-13-2012, 01:39 PM   #8
Drago77
Drago77's Avatar
That definitely works too,
Some good ideas!
Old 02-03-2012, 05:04 PM   #9
Drago77
Drago77's Avatar
So I'm planning on doing the catch-can style relocate... but I'm a complete novice as far as all this stuff goes, I'm learning as I go...
Anyway- just to make sure I understand this-
I can remove the stock pump and either mount that directly into the catch can, or use an extention hose from the pump into the can... right? Moving it in a few weeks and building a custom air scoop from my Sillen grille vents to the cai.
Thanks in advance for all the help!
Old 02-04-2012, 02:12 AM   #10
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I don't have a pic on my phone but could post one when I get home. I used the OEM bottle and cut 7" out of the middle, got a peice from another bottle to adapt the top and bottom back together with epoxy. It fits perfect inside my ADM race intake with the top through the top of the intake. It allowed me to use OEM bottle and pump. Plus it still holds 3 quarts of juice. If I dont get the pic posted, send me PM to remind me.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 02-04-2012, 04:32 AM   #11
gelboy1015
gelboy1015's Avatar
Drives: '10 2SS/RS, MKIII Supras
I did the same mod that Caverman did after reading his thread. It was really easy to do. I mounted the pump with zip ties to the metal bracket there. I used 5' of clear tubing hose from lowes to run it to the fitting on the bottom of the bottle. Make sure you drill a small breather hole in the top of the cap or else it will starve the pump and create a vacuum that wont allow fluid to be pumped out. Other than that, it works great.
2010 Camaro 2SS/RS
- LS3, M6. -
Build Thread/Mods List
gelboy1015 is offline   Reply With Quote
FS: Borla S-type Catback, CAI intake, Rotofab washer bottler replacement kit. Milidin V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 11 01-11-2012 03:41 PM
Troubleshooting with ADM washer bottle joey0480 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 01-02-2012 01:07 PM
Nitrous Accessory Basics. Nitro Dave Forced Induction - V8 2 11-03-2011 12:18 PM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 02:07 AM
2010 Camaro Fog/DRL Light 5202 HID kits .... HID_Guy Exterior Parts & Accessories 1 09-07-2009 01:19 PM
