SDTW Custom Wheels & Tires
Old 01-12-2012, 11:23 PM   #1
ducq
ducq's Avatar
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM
TSP 229/236 cam Dyno'd
Just got my car back after getting a tsp 229/236 112 lsa cam. Also got a tap underdrive pully kit. Dyno tuned at newtech performance. Got 452 hp / 422 tq. I told em to keep the tune safe as this is my daily driver. It's pretty loud with muffler deletes and long tubes, but I'm real happy with the sound. I don't even wanna keep it in gear anymore, I just wanna idle down the street lol. Already ordered some magnaflow bullet mufflers to help quiet it down some. I'll post better videos and before/after once I install the bullets. Thanks to camaro5 for all the help as I researched my setup.
TSP 229/236 cam .Magnaflow Comp axleback .KOOKS LT w/ high flow cats .magnapack bullets. C.A.I. Vmax ported TB. Dyno tuned 452hp / 422tq.
ducq is offline   Reply With Quote
Old 01-13-2012, 01:18 AM   #2
ducq
ducq's Avatar
-When I'm driving 40 and I let off the gas and put it in neutral, the car revs up 1,600 rpm's or so then drops to idle (900). Is this normal?
-Getting a little bucking/surging in 1st gear sometimes around 1100 rpm's in a parking lot, normal with a cam?
Old 01-13-2012, 01:41 AM   #3
Overkillphil
Tire Destroyer
Overkillphil's Avatar
Drives: 2011 Camaro 2SS/RS Hurst M6
That's a healthy cam. You'll get a bit of low speed bucking.
Overkillphil is offline   Reply With Quote
Old 01-13-2012, 02:19 AM   #4
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
'Sounds normal to me, based on my experience. It takes some getting used to but you'll love it (I can tell already).
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged LS3 (9.8:1 CR), Maggie TVS 2300 SC (11 psi), Custom Comp cam (223/244, .610/.596, 114 LSA), 90-lb. injectors, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Lashway Motorsports.
fldrummer is offline   Reply With Quote
Old 01-13-2012, 03:07 AM   #5
mikeSS
mikeSS's Avatar
Drives: 2015 c7
cam are suppose to bounce around a little. mine doesn't get that high though for most of the time. it will bounce around 1k then settle down. but not every tune and cam is the same.
Old 01-13-2012, 07:41 AM   #6
nycoupe11
Drives: 2011 2ss/rs Summit White
That's normal.. Great numbers!
2011 2ss/RS Summit White / Grey and Black Interior. TSP VVT-2 Cam, ARH heads and Exhaust, CAI, Ported Throttle Body, Plasti Dipped tailight bezels and rims. AAC interior lighting. Tuned by East Coast Supercharging.
nycoupe11 is offline   Reply With Quote
Old 01-13-2012, 02:58 PM   #7
Lonnie@Texas-Speed
Lonnie@Texas-Speed's Avatar
Drives: 2010 Camaro - BIW
give it some time & make some notes, you can give your notes to the tuner & I bet he can help that 1600 to 900rpm surges!
Lonnie@Texas-Speed is offline   Reply With Quote
Old 01-13-2012, 03:54 PM   #8
MikeOD
Drives: 2010 M6 2SS
No, needs more tuning work.
At very low RPM in first gear, a minor surge could be in the tune, and it actually could also be in your cold air intake...some intakes cause a little bit of air turbulence around the MAF sensor, which results in a buck...sometimes even with the stock cam.
It may be possible to make it a bit better with tuning, but 1100 RPM might never go away.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 01-13-2012, 04:13 PM   #9
Etherij
Etherij's Avatar
Drives: 2010 Camaro 1SS LS3
Sounds f'n awesome!
TEAM LS3!
Mods so far:
JBA Catted mid-pipes
Flowmaster AMT
Etherij is offline   Reply With Quote
Old 01-13-2012, 04:28 PM   #10
Rage
TRI-COUNTY CAMARO... FTW!
Rage's Avatar
Drives: 2010 Camaro 2SS M6 Cyber Grey
That 1600 surge is a tune issue.... get it checked out.
CAI inc. cold air intake, LG G6x3 cam, Patriot Gold Extreme Dual springs, Titanium retainers and locks, LG SuperPro 1 7/8 Long Tube headers with full 3" exhaust, DynoMax VT mufflers, SLP 4" tips, Moroso catch can, Race Ready electronic exhaust cut outs, Full painted Razzi body kit, Headlight Armor Smoke taillight and marker blackouts, T-Rex aluminum upper and lower grille, Polished aluminum front and rear bowties. Professionally installed and Dyno Tuned by HorsePower Sales, Pompano Beach FL.
Rage is offline   Reply With Quote
Old 01-13-2012, 06:03 PM   #11
fldrummer
"Black Ace"
fldrummer's Avatar
Yep. I had that exact same problem with my new era intake so I switched to a CAI --problem solved.
Old 01-13-2012, 07:58 PM   #12
maroman1138
maroman1138's Avatar
Drives: 2011 SS/RS LS3
I gotta keep mine right at 2 grand to avoid the bucking. Cams no likey the low RPM'S.
2011 1SS/RS LS3 - Stage II Ported Heads, Stage II Comp Cam, Ported T.B., Hurst Shifter - 0BX LT Headers - CAT delete, Pype Bomb Axle-Back Exhaust - Muffler delete - 4.5 Resonated tips, Spectre CAI, - 480 RWHP 442 TRQ. Dyno tuned by ARD.
maroman1138 is offline   Reply With Quote
Old 01-13-2012, 11:22 PM   #13
ducq
ducq's Avatar
Well I talked to my tuner and he said that revving up to upper 1k rpm's is something to avoid the car turning off but it's set too high or something. I dunno, gonna get it cleaned up in a few days. Is it safe to drive around with that. I assume it's not a big deal.
I'm real happy with this cam and love the sound!
Old 01-14-2012, 12:11 AM   #14
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
need to get some tuning work!!! A good tuner will be able to tune the biggest cam with little to zero surging...takes time and lots of expierence but can be done!
Whipped416 is offline   Reply With Quote
TSP 229/236 Cam newmoon Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 10-20-2012 04:09 PM
TSP Torquer V.3 cam racerfox V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 2 05-17-2011 12:26 AM
PRC 215 HEADS AND TSP TRQ3 CAM 2000$$ racerfox V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 1 05-11-2011 06:49 PM
Finally dyno'd VMS 2.5 CAM 461rwhp 437 rwtq NoMercy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 01-04-2011 10:57 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 04:09 PM
