BeckyD @ James Martin Chevy
Old 01-13-2012, 04:22 PM   #1
evilbeef54
tail lights for u
evilbeef54's Avatar
Drives: Bumble Bee 2010 2SS/RS
need help, stabilitrack error after long tube install
Okay guys i need help, i installed my new kooks lt's and high flow cats last night, test drove it, sounded good, no lights or anything, except a random rubbing sound, got it back in the air this morning and found that one of the o2 sensor s was making slight contact with the body, so i loosened everything rotated it so the sensor was clear, fired it up today to test drive and after a minute i an getting a check engine light and a service stabilitrack screen with the tc st and traction lights all on, also i an using the included o2 extensions
1972 Camaro 350/Muncie M22 - SOLD
1986 Camaro RS - R.I.P.
1994 Camaro Z28 - SOLD
2010 Camaro 2SS/RS RY M6- LOVIN' it
Kooks LT's & HFC's, Flowmaster Single chamber mufflers, C.A.I. Intake, ADM Scoop, Rotofab w/w relocate
Semper Paratus
You have to go out You don't have to come back!!!
evilbeef54 is offline   Reply With Quote
Old 01-13-2012, 04:30 PM   #2
evilbeef54
tail lights for u
evilbeef54's Avatar
here's a fun fact if you only have 7 spark plug wires hooked up you will get a stabili track warning
Semper Paratus
Old 01-13-2012, 04:34 PM   #3
TRIPWIRE
Chillin Like a Villain
TRIPWIRE's Avatar
Drives: 2013 2SS Blue Ray Metallic Dusk Ed.
Had the same problem it was a cracked spark plug but it could also be that one of your spark plug wires isn't in all the way
TRIPWIRE is offline   Reply With Quote
Old 01-13-2012, 05:32 PM   #4
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
Two most common reasons are loose spark plug wire or damaged plug. Did you remove the plugs?
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 01-13-2012, 05:49 PM   #5
evilbeef54
tail lights for u
evilbeef54's Avatar
yeah got it fixed, it was the loose plug wire, i had to take em off to get the oil dipstick in fully, weird that a spark plug would set off stabilitrack
Semper Paratus
Wrapped Injen long tube with Thermo Tec heat barrier zogster Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 1 09-14-2011 09:24 PM
Injen long tube oil diffuser? zogster Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 08-27-2011 05:13 PM
Injen Long Tube on 2011 vert or coupe Nutbutt Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 20 03-25-2011 12:09 PM
Smokin Deal on JBA 2010 Camaro SS Long Tube Headers Jeff@HHP V8 Bolt-Ons & Tunes 0 01-18-2010 09:54 PM
Dynatech Long Tube Headers WIth Zoomers Exhaust - $2384.99! tbyrne V8 Bolt-Ons & Tunes 1 12-08-2009 01:07 PM
