01-13-2012, 05:12 PM | #1 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Pedders XA install question...please help!
I'm doing the front XA's and the instructions say to re-assemble the strut bearing and washers to the XA strut but when I removed the top 24mm nut the OE strut dropped out but the bearing assembly stays on the car. Do I need to remove the bearing assembly to install on the XA or can I just insert the XA into the bearing and tighten it down? This also affects how to do the pre adjustment for ride height beacuse it references the procedure assuming the strut bearing is assembled on the XA!
01-13-2012, 05:47 PM | #2 |
Drives: Camaro Justice Join Date: Jun 2007
It will be easier to assemble out of the car. This is the best part of the install.
It will come out. |
01-13-2012, 06:31 PM | #3 |
BL1ZZRD
I've been pounding on it now for 10 minutes and it won't budge. What part of it should I be hammering? I'm using a 1/2" short extension which covers the metal sleeve perfectly so I've been hammering the extension centered on the sleeve.
01-13-2012, 06:39 PM | #4 |
BL1ZZRD
Got it off! I reinstalled the strut and used it as leverage and just twisted it off! It was really stuck on! The other side came off very easily! Thanks for your help and keep near your computer tomorrow, I may have more questions about setting up the ride height! Thanks!
01-13-2012, 06:42 PM | #5 |
Call if you need me. 616.834.8100
01-13-2012, 07:13 PM | #6 |
Booooosted.
And this is why Pete rocks.
ssmike, I've done XAs in the front of mine as well. Plus drop springs before that. I'm pretty familiar with them. I'm not Pete but if you, for whatever reason, can't get ahold of Pete shoot me a PM. I'll be buzzing around the French Quarter but I'll have my phone. I'm pretty familiar with this set-up. I can help out over the phone as well. |
01-13-2012, 09:24 PM | #7 |
"Camaro Joe"
mike feel free to shoot me an email at 3jsauto@gmail.com if you need any help. it goes right to my phone so i get it all the time
01-13-2012, 10:28 PM | #8 |
BL1ZZRD
Thanks Pete and Joey!
Thread Tools | |
Similar Threads | ||||
ZL1 / CTS-V Brakes | JusticePete | Suspension / Brakes / Chassis | 584 | 10-14-2021 09:33 AM |
SS sway bars on v6? | jatt5ab1soorma | Suspension / Brakes / Chassis | 9 | 07-07-2011 08:32 PM |
L99 RX Catch Can install question | Three of Swords | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 6 | 05-08-2011 08:02 PM |
Sub Install Question (NON BA) | cpages2 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 15 | 04-13-2011 08:40 AM |
Where are Pedders coilovers made? | g-townmach | Suspension / Brakes / Chassis | 69 | 05-03-2010 12:44 PM |
