JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 01-14-2012, 11:09 AM   #1
NY 2SS
Drives: 2010 Inferno Orange 2SS
Low Profile Jack
I'm looking for a low profile jack that will reach from the rear bumper to the center section of the differential, and the front bumper to the cross member. I think the AC Hydraulic DK13HLQ 2800lb High-Lift Floor Jack will work. I'm wondering if anyone is using one and what they think of it.
http://www.pelicanparts.com/catalog/...Hydraulic3.htm
NY 2SS is offline   Reply With Quote
Old 01-14-2012, 03:36 PM   #2
bthibodeaux
bthibodeaux's Avatar
Drives: Black 2011 2SS/RS M6 Vert
This will definitely work, at 940MM (37") length. It is pricey though at over $500. I have the one below from Harbor Freight that is 34.5" and it gets me to the center section just fine. Its lifting point starts at 2.625" versus 3.2" for the one you are looking at. Also it is only $130. It is made in China though. Has been very reliable for me so far.
bthibodeaux is offline   Reply With Quote
Old 01-14-2012, 04:04 PM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
I have the 2.5 ton low profile jack from HF, it's on sale now for 79.00. I've used it several times now, it works great. No problem with car clearance and lifts the car quickly.
  • Lifting range from 2-3/4" to 20"
  • Extra-wide steel casters for stability
  • Minimum saddle height: 2-3/4"
  • Maximum saddle height: 20"
  • Pumps (under max load) to max height: 5
  • Overall dimensions: 29" L x 13-1/8" W
  • Tool weight: 71.7 lbs.
Also picked up 2 set of these with a $14.99 coupon:
FSP tuned: 377/389
Old 01-17-2012, 12:14 PM   #4
NY 2SS
Thanks for the responses, I haven’t had much luck with Chinese made jacks, I have a couple of cars and do most of the maintenance myself so they get used quit often and as a result they start leaking after about a year. So I was looking to spend a little more and hopefully get a better service life.
Old 01-17-2012, 12:16 PM   #5
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
not too many jacks not made in China.
this is the only one I've seen...made in spain.
http://www.griotsgarage.com/product/2-ton+floor+jack.do
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 01-17-2012, 12:37 PM   #6
SinisterEcho
SinisterEcho's Avatar
Drives: 2010 2SS/RS M6/LS3
I have the BigRed jack that is sold at PepBoys. Its a 3ton lowpro jack with jack stands. I had the camaro up about 15" with no problem. I could have gone higher but with the pavement a little sketchy i was being cautious.
http://www.northerntool.com/shop/too...6598_200326598
I paid about 30 less at pep boys.
My Mod Journal <-- Its updated... again!
SinisterEcho is offline   Reply With Quote
Old 01-17-2012, 01:41 PM   #7
Jimbabwe
Jimbabwe's Avatar
Drives: 2010 IBM 2SS/RS
I bought this jack a few weeks ago and used it over the weekend. It was a squeeze under the front air dam (my car is stock height). Next time I do it I'll drive the car up on a 2x6 first (that you can use on top of the jack stands). It worked pretty well.
One thing that you might not think about is that in rear, the jack points (the frame points behind the wheels) are higher up. The 15" may not give you enough clearence (without using a bunch of wood. I was worried about squeezing under the 6" in the front that I didn't think about the rear. This jack reached both
Jimbabwe is offline   Reply With Quote
Old 01-17-2012, 02:07 PM   #8
jover
Drives: Victory Red SS
HF is the way to go cheap and a good low profile jack.
jover is offline   Reply With Quote
Old 02-24-2012, 01:30 AM   #9
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
Granted I have only used it a half a dozen times, but the Tirerack model that I picked up from Rudy is working well for me.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
Old 02-25-2012, 04:00 PM   #10
Boost6924
Drives: 2SS/RS
Get this: http://www.jegs.com/i/JEGS+Performan...80006/10002/-1
Cheap, very durable and light. I use it every day.
438cid IPS Twin Turbo.
Boost6924 is offline   Reply With Quote
2010 Camaro PCM Pin-out Description and Wire Colors (LS3 & L99) raptor Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 13 11-14-2015 05:07 AM
I have a question about sets of Jack stands. 94ChevyCamaroV6 Camaro DIY & HOW-TO instructions & discussions 8 11-14-2011 04:07 PM
Phony low pressure tire warnings. Ivas Wheels and Tires Talk Sponsored by The Tire Rack 16 03-28-2011 04:19 PM
Where to mount dmh low profile cutouts?? Hollywood2 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 1 03-06-2011 01:17 PM
PFYC's Low Price Guarantee "Double Credit" Challenge PFYC V8 Bolt-Ons & Tunes 0 05-05-2010 11:10 AM
