Jason 98 TA
Old 01-14-2012, 05:45 PM   #1
bilydean
bilydean's Avatar
Drives: One of the rare ABM camaros
CAI vs OEM air box
Can someone explain why the different cold air intakes supposedly give more power and mpg over the oem air box? When I look at the oem box, it pulls air from outside of the engine bay, so should be cooler air. If I put a different air filter in the stock housing, I would reduce the restriction, so why are they significantly different? (on the fence about getting one)
Dean
2000 5/23
3000 5/27
3400 6/20 TPW of 6/29
3800 7/3
4D00 7/8 interned at QC
4B00 7/16 Released from QC
4200 7/20
8/5 We picked up the car
bilydean is offline   Reply With Quote
Old 01-14-2012, 05:49 PM   #2
blufin
blufin's Avatar
Drives: Fire Engine
The aftermarket intakes eliminate the funky stock intake tube that is mainly to quiet the engine noise, but its also a major restriction.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 01-14-2012, 06:03 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Vehicle engineers have many factors other than maximum performance to consider when they design OEM intake systems (noise level, fuel economy, emissions, etc.) and in the process leave plenty of room for improvement. Aftermarket air intake systems replace the factory air box and tubing with more efficient components designed to create more power. The two big things that aftermarket air intakes systems strive to do are:
1) Draw in larger amounts of cool dense air from outside the hot engine compartment. The more air your engine can suck in and push out the more power it will make. One example of how this is done is the filter. A cone filter has a much larger surface area than a stock panel filter. This means more air can pass through.
2) Reduce the restriction in the intake system. This is done by increasing the diameter of the tubing, smoothing out the interior of the intake, eliminating baffles and muffling devices, and limiting the number and severity of any bends in the tubing.
The tone of your post seems to indicate that you are suspicious of claimed performance improvements, and you should be. Some manufacturers do inflate their numbers but there is plenty of evidence out there in the form of customer dyno results and even third party tests to prove which systems perform and which ones are decorative.
Here are a couple of links to posts on our blog with some good technical info about intake and filter design. If you have any questions feel free to hit me up.
What Is The Best Air Intake System For The Camaro SS?
Choosing a Dry or Oiled Media Filter for Your Vehicle
Old 01-14-2012, 06:55 PM   #4
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
Well, I tried a intake system and after the required learn time it lost maybe a 10th at the track. It felt as tho the throttle response was noticeable but I sold it upon having other quality issues and really, with no gain why have it. I now have a rotor-fab and jannetty tune for after hibernation.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 01-14-2012, 08:06 PM   #5
bilydean
bilydean's Avatar
Lets assume the funky intake tube is not there any more and replaced by a 4" tube. Are the aftermarkets getting the better performance because they replace the OEM tube?
2000 5/23
3000 5/27
3800 7/3
4200 7/20
Old 01-14-2012, 08:22 PM   #6
bilydean
bilydean's Avatar
Not suspicious, more curious. If the 3 main improvements are:
1. the intake tube - easily replaced
2. drawing cool air- the stock air box does that already
3. more surface area on the filter & less restriction - currently using a Green reusable filter. Surface area maybe smaller, but if they flow the same rate as say a K&N, then the restriction is still the 4" tube.
Just trying to get a better understanding.
2000 5/23
3000 5/27
3800 7/3
4200 7/20
Old 01-14-2012, 08:46 PM   #7
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 01-14-2012, 09:06 PM   #8
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
They do make more dyno power, but how much really translates to what you would notice on the street ? SLP has there own but also they offer a filter and just the better tube, not the whole thing, so maybe not a whole cai needed, for the street anyway
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And DSE swaybars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
2012 V6 C.A.I. Inc. | Camaro 3.6L Cold Air Inductions Intake System! | Plus Packages! AutoAgenda V6 Bolt-Ons & Tunes 87 08-25-2013 06:22 PM
Anyone cutout the mail slot? Wasp 5th Gen Camaro SS LS LT General Discussions 26 10-01-2011 08:15 PM
CEL - P1682 PSU SS Tuning / Diagnostics -- engine and transmission 4 09-29-2011 08:27 PM
