HeadlightArmor
Old 01-14-2012, 06:07 PM   #1
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Question About LT Header Installation
So, this summer I'll be getting some stainlessworks LTs installed and have a couple of questions on what to expect. Myself and my brother are fairly capable of installing bolt on parts, so we could do it ourselves if installation isn't overly complicated. I just have a couple of questions:
1.) What should I expect to pay to have a performance shop install them?
2.) What sort of work goes into installation (Ex. Welding/Allignment)?
3. If instalation methods aren't difficult, would it be a good idea to just install myself?
Any input is welcome and appreciated!
Powhusku is offline   Reply With Quote
Old 01-14-2012, 06:10 PM   #2
Rcfiddy1
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Do it yourself. Its not hard at all. Couple of bolts thats all it takes. Maybe a 2-3 hour job.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 01-14-2012, 08:32 PM   #3
evilbeef54
tail lights for u
evilbeef54's Avatar
Drives: Bumble Bee 2010 2SS/RS
Just did mine the other night, not bad at all, there are some good threads on here with tips
1972 Camaro 350/Muncie M22 - SOLD
1986 Camaro RS - R.I.P.
1994 Camaro Z28 - SOLD
2010 Camaro 2SS/RS RY M6- LOVIN' it
Kooks LT's & HFC's, Flowmaster Single chamber mufflers, C.A.I. Intake, ADM Scoop, Rotofab w/w relocate
Semper Paratus
You have to go out You don't have to come back!!!
evilbeef54 is offline   Reply With Quote
Old 01-14-2012, 09:01 PM   #4
blufin
blufin's Avatar
Drives: Fire Engine
Very simple and straight forward. It all just bolts right up into place. Save the money and do it yourself, more money for other mods.
12.618 @ 110.75 Bone Stock 1/4 mile
8.165 @ 86.52 Bone Stock 1/8 mile
11.189 @ 124.44 on a 1.73 60' TVS2300 3.4 pulley, JRE tuned, Kooks LT headers and HF cats, MBRP catback exhaust, CAI intake, ADM scoop. Stock wheels/tires.
Sold
blufin is offline   Reply With Quote
Old 01-14-2012, 09:17 PM   #5
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
Do it yourself. The new Camaro is probably the easiest car I've ever installed headers on. It's a 3 hour job at the most.
bpoirier is offline   Reply With Quote
Old 01-15-2012, 02:39 AM   #6
Powhusku
Powhusku's Avatar
Sweet, thanks for all the helpful input. I'll definitely do the installation myself and use the money saved to get a proper tune after I get a cam this summer.
Old 01-15-2012, 02:43 AM   #7
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
SOme of us slow folks gotta take it in to be done lol. Me for example. Maybe it was just that the 2001 mustang cobras were a PIA to mod with anything that makes me not wanna try and put the headers on my maro myself. But like others stated doing it yourself and saving money is the way to go. If you wanna know the price range, I'd say it would be anywhere from 100-200 around where I live. (thats bolting them up and hooking up the rest of the exhaust)
Frid is offline   Reply With Quote
Old 01-15-2012, 11:14 AM   #8
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
Definitely no welding. You just need to know what you're doing. The old manifolds come out easily and the headers bolt right up to the head and stock exhaust.
Buy some new GM gaskets. You can reuse the head bolts if they look good. Use blue lock tite on them. Torque to 18 lb. ft. from the inside out. Retorque after 4-5 heat cycles while cold. Enjoy!
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 01-15-2012, 04:24 PM   #9
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
A good set of long tube headers are easy to install on these cars. I have heard the LS3 is easier then an L99 which is what I have but mine went in really easy.
If you have an extra set of hands to help line up the headers and start the header bolts. I think this is the most critical part. I recommend starting all the bolts by hand until you KNOW they are started well into the heads. You can bugger up these aluminum head threads easily if the bolts are not started right before you put the wrench to them. Other then that, its DAMN easy.
Especially if you can get your car at least 18" off the ground in the front end. IF you can get it higher, its even easier. If you have access to a lift, piece of cake, you would be silly to waste your money having someone else putting them on for you.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 01-15-2012, 04:33 PM   #10
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
So ok... if you install these headers on your own, do you still need a tune. I was reading somewhere that if you use shorties you dont need a tune?? Also if you install headers and have to take it in for warrenty work, could you just replace them with the factory and no one would be the wiser?
nebchevy is offline   Reply With Quote
Old 01-15-2012, 04:41 PM   #11
Parag
Drives: 2010 camaro 2SS LS3
Shorties dont improve the airdlow enough to need a tune, but LTs do, some people say they dont but dont listen, LTs need tunes
Headers dont void warranty, tunes do
Parag is offline   Reply With Quote
Old 01-15-2012, 05:11 PM   #12
Louis @ LG Motorsports
Drives: 2010 SS/RS 2009 CG Z06
If you do choose to have a shop install them, you can expect 300-600 for an install, depending on what system.
We are very very good at installing headers, and charge 600$ for install AND dyno tune.
Louis @ LG Motorsports is offline   Reply With Quote
Old 01-16-2012, 12:29 PM   #13
Powhusku
Powhusku's Avatar
If only Texas wasnt so far away. I'll likely install them myself, but I really wish I could come to Texas to get it tuned by the pros.
Old 01-18-2012, 06:18 PM   #14
Ill walk you through the install! If you are handy with tools, and dont mind getting dirty, its not bad at all!
Maybe I need to take a road trip
Installation tips and measured sound levels for Lt Headers w/ cats audiomikej Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 02-19-2017 04:00 PM
LT header and O2 sensor location question gearhead440 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 06-18-2014 05:48 PM
Stock Header Weight and American Racing Header (LT) Weight? BaylorCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 5 10-06-2011 11:08 PM
Misfire after LT header install & tune update: HELP! fldrummer Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 62 03-16-2011 10:46 AM
LT header and muffler delete kbui USA - Texas 6 06-17-2010 06:39 PM
