Solo Performance
Old 01-15-2012, 09:10 AM   #1
pears2
Drives: 2011 Black/Silver Synergy Series
Water Wetter?
I used "Water Wetter" in the radiator of a 73 Corvette I owned a few years ago. It brought the anti-freeze temperature down about 20 degrees. Has anyone used this type of product in the 5th Gen?
pears2 is offline   Reply With Quote
Old 01-15-2012, 10:47 AM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
I run it. No problems
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 01-15-2012, 11:20 AM   #3
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
I did a ton of research on it and came to the conclusion that in anything less than a full on track car that runs water only it is a waste of time/money. Also found that some brands are complete snake oil and a small few can actually damage your cooling system.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
Old 01-15-2012, 11:25 AM   #4
SC2150
Water wetter, purple ice, etc. are excellent products and help lubricate the water pump and add to the anti corrosive properties of the anti freeze. Antifreeze does NOT do well at heat transfer so it will help for sure but works best water & additive only with just 10-20% antifreeze if you live where temps are never at a hard freeze. Up north you have no choice.
In water to air intercoolers applications we run it always and the result is dramatic.
Just remember that the more antifreeze in your coolant mix the less able the system is to remove heat but it is CRITICAL to alway have the proper mixture to avoid freezing damage if you live in a cold climate. Here in FL we use very little and watter wetter or purple ice.
Methanol Question ProudLS Tuning / Diagnostics -- engine and transmission 26 07-07-2011 05:54 PM
Neighbor's Water Running TOMS1SS Off-topic Discussions 20 03-21-2011 04:06 PM
Forced Induction Supplements radz28 Forced Induction - V8 3 11-04-2010 11:13 AM
Stubborn Water Spots crzycicada Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 35 07-26-2010 08:42 AM
