SDTW Custom Wheels & Tires
Old 01-15-2012, 10:51 AM   #1
fastlane2010
fastlane2010's Avatar
Drives: 2010 camaro with fast lane stage 2
clear intake ?
hey i was wondering if its possible to make a clear intake since its only air going thru it now i just thought it would be cool to have a see thru intake and have a cai the same way like a pipeline cold air just clear
would be a good show stopper
12.4 in 1/4 at 117mph first time
custom 2tone paint fastlane stage 2 hydroformed carbon fiber cowl and cluster kooks headers and 3" xpipe with pypes axle back
fastlane2010 is offline   Reply With Quote
Old 01-15-2012, 11:46 AM   #2
Eric Baker
Drives: Black/Black 2SS/RS 6M
I don't see why not, so long as you use a plastic that's not going to get damaged from the heat and vibration under the hood.
Eric Baker is offline   Reply With Quote
Old 01-15-2012, 12:37 PM   #3
fastlane2010
yeah but i wonder why they dont make one the 4th gens had the clear lid from slp
Old 01-15-2012, 12:58 PM   #4
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
The lid isn't going to get as hot as the section of an intake tube sitting over the radiator and especially close to the throttle body.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-15-2012, 02:06 PM   #5
fastlane2010
yeah i understand that but i would imagine that there is plastic to withstand that heat since ours are plastic now but just want it clear
Old 01-15-2012, 03:17 PM   #6
Parag
Drives: 2010 camaro 2SS LS3
There is it just is expensive to make, not only the outside has to be smooth, the inside too. How do you polish the inside of a tube?
Parag is offline   Reply With Quote
Old 01-15-2012, 03:50 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I'm sure it can be done but as has been mentioned, it will probably be quite expensive. Many of the intakes aren't just plastic, they are a composite material to keep heat out and maintain structural integrity. Underhood temps can get quite hot and finding a material that maintains it's shape and form while not heating up the air going through the tube can be a challenge.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
CAI Inc V6 Intake Systems Now IN STOCK at APEX Motorsports!!! $399 SHIPPED!!! Apex Motorsports V6 Bolt-Ons & Tunes 58 05-08-2016 02:26 PM
2012 Cold Air Inductions intake same as 2010/2011? Specs look the same! PLuche Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 32 03-31-2013 09:10 PM
2012 intake manifold usa1camaro1969 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 33 09-01-2011 10:25 PM
18.62 hp increase from just an intake?? Yellojacket Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 08-10-2010 01:45 AM
