BeckyD @ James Martin Chevy
Old 01-15-2012, 04:17 PM   #1
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
Header Questions
So ok before you all start saying I should use the "search button" well its SUCKS... I put headers in the search and Who's interested in an ATL C5 club? comes up as the first one and so on... terrible!! Anways... What is the difference between long and short headers? Also how much of a gain in power are we talking when installing these, is it worth it for the money? I am looking at exhaust systems so I kinda wanna know what I am going to be looking at. Thanks
nebchevy is offline   Reply With Quote
Old 01-15-2012, 04:34 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
The stock header are built in sections, the shorties just replace about 8 inches replacing just the manifold, making them equal lenth. I have always said and for the most part heard shorties are just for people in cali. They see little gain, but some people swear by them, LTs are the whole section, and you will expect to see 30 hp easy with a tune with LTs
Parag is offline   Reply With Quote
Old 01-15-2012, 04:40 PM   #3
nebchevy
nebchevy's Avatar
So I was reading somewhere, that is you install short headers it wont void warrenty but longs will?? Also do you think if I install long, would I be able to slap factory on quick if I have to take it in for work? Also, do you NEED a tune with headers or can you do without untill warrenty is up?
Old 01-15-2012, 04:43 PM   #4
Parag
You will run lean, without a tune. Therefor get a tune or just wuss out and keep warranty
Old 01-15-2012, 04:46 PM   #5
nebchevy
nebchevy's Avatar
LMAO!!! You are awesome bro lol... I am a HUGE WUSS.. my first new car I have ever owned.. My older camaros I just did whatever I wanted..
Old 01-15-2012, 04:52 PM   #6
NYJETSFAN
El Hefe
NYJETSFAN's Avatar
Drives: Black Camaro 2SS/RS
Hey man, you can't be afraid to mod your car. The dealership always find ways to say it is your fault why something went wrong with your car. I have a 2010 SS/RS with 12k and it is modded out. There are so many knowledgeable people on this forum that can help you figure out whatever your problem is. Good luck and welcome.
NYJETSFAN is offline   Reply With Quote
Old 01-15-2012, 05:05 PM   #7
nebchevy
nebchevy's Avatar
Thanks! I do understand what you are saying! So ok then... Can someone please tell me if long headers with the magnaflow 16580 would be to loud?? Also What is the advantage of adding a new cam shaft...
Old 01-15-2012, 05:08 PM   #8
Louis @ LG Motorsports
Drives: 2010 SS/RS 2009 CG Z06
It wont run lean with headers only. If you change the air intake, depending on the brand, THEN IT WILL RUN LEAN.
Headers only, depending on driving style, will cause some o2 sensor codes. The headers dissipate heat much faster and along with an o2 further downstream in the exhaust, will cause some o2 sensor performance.
What does this do?
Performance wise, nothing.
Fuel economy wise? if Cruising, not much.
Why is it an issue? Because it can set a check engine light.
Louis
Louis @ LG Motorsports is offline   Reply With Quote
Old 01-15-2012, 05:08 PM   #9
NYJETSFAN
El Hefe
NYJETSFAN's Avatar
Im not sure how loud that set up would be, but you can go to Youtube and search for it. I am quite sure there should be a few clips with that sound. I am running kooks LT 1 7/8 headers with a corsa exhaust and it sounds great. Its only loud when you get on it. For normal cruising it is not too loud.
Old 01-15-2012, 05:09 PM   #10
I agree, corsas have great part throttle cruise noise suppression. If you use the stock mufflers, they will sound similar at cruise.
Old 01-15-2012, 05:11 PM   #11
nebchevy
nebchevy's Avatar
So where would I get a "tune" done... I just moved to some small town. Do dealerships do them or is that a nono?? Is there somewhere to search around a area?
Old 01-15-2012, 05:13 PM   #12
Honestly, if its JUST headers, if you bought our system, you can send me the computer out of the car, and I can put a base tune in it. Is it a dyno tune? No. However, we start ALL of our header dyno tunes with this "base tune" and tweak very little afterwards. A base tune will get you with in 3%. A dyno tune will get you with in 1%.
Louis
PS- Our system can be seen here- http://www.lgmotorsports.com/LG-Moto...er-Pro-Headers
Old 01-15-2012, 05:58 PM   #13
nebchevy
nebchevy's Avatar
So what do you "tune" when headers are put on?? I mean I guess why do you have to tune for them?
Old 01-15-2012, 06:03 PM   #14
NYJETSFAN
El Hefe
NYJETSFAN's Avatar
I got an SCT from Ted@JannettyRacing.com he can help you with whatever you need.
Here we go. Stepped headers or uniform size? Raptor626 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 43 10-27-2011 01:22 PM
Texas Speed 304 Stainless Header Kits Pics & Info! Jason 98 TA V8 Bolt-Ons & Tunes 109 07-18-2011 04:33 PM
Detailing questions answered here! Moose Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 636 06-04-2011 01:27 PM
Header install, O2 question's Bad70supreme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 04-15-2011 10:43 AM
Header Questions Missile Man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 09-27-2009 07:37 PM
