JDP Motorsports
Old 12-19-2012, 05:16 PM   #617
TCAT
TCAT's Avatar
Drives: Has Wheels
Those pictures look amazing Pierre! You and your car must be absolutely notorious out there!
TCAT is offline   Reply With Quote
Old 12-20-2012, 12:12 AM   #618
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
Originally Posted by leonardo View Post
30 is still pretty good amount brotha and man I love the vertical doors on the bullet !!!!! didn't I tell ya that you wouldn't regret it
Man I can't thank you enough Leo , this is my first car with vertical doors and its definatly not the last
Thanks T , I had a lot of fun and the guys are cool.
Old 12-20-2012, 12:13 AM   #619
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Hallelujah today I get back bullet with da new hood
Old 12-20-2012, 02:40 AM   #620
Kartashian
SoCal HT5
Kartashian's Avatar
Drives: The Punisher
Nice pics bro!! Can't wait to see the hood.
Kartashian is offline   Reply With Quote
Old 12-20-2012, 03:48 AM   #621
Kronix
NJ/SoCal HT5 COTW 3/25/12
Kronix's Avatar
Drives: 2015 Z06/14 C7/08 Z06/07 Tahoe Z71
Originally Posted by pierre777 View Post
Here's the pic J, you can see on the hood liner the lines drawn by the seperator.
Hey P, What you're going to want to do with the Z-Force hood to get the full benefit of the true ram induction is this. It's great that you have an open air box where your filter is already, and you'll notice on the MPD1 hood that there's a hole right above the air box that leads from the wide mouth opening on top of the hood. But your box is too big to use the standard gasket Eric sends with the hood, because it was designed for use with the CAI, Inc box, but the fix is simple. You have a rubber gasket that runs around the top of your box now, but it's probably not big enough to form the seal needed when the hood is closed. So you just need get a channel gasket(just like the one on there now & the one that runs on inside of bumper at top) that will be high/large enough to form a seal once hood is closed. I doubt the gasket you have running around the box will do the trick as it was designed with the stock hood in mind. Measure your box around, including fender side and that will be the length you'll need. Your goal is to form a seal from your box to bottom of the hood. Just look how my gasket runs around the box opening, you want to do the same thing and although your opening is bigger, as long as the seal is made your good.
Who knows maybe the gasket on there now may do the trick, one way to find out is once hood is mounted, use some masking or painters tape and lay it sticky side up around your box & close hood, then open and if tape is stuck to the underneath of hood your good. But I'd recommend getting the largest channel gasket you can to ensure as much of an air tight seal as possible. Then you're good to go reaping all the benefits of the hood.
Regarding my Pfadt castor/camber plates that will also cure your alignment issue. You're having the issue because GM did not design it wiith camber/castor in mind, they drilled the holes needed where the stock shocks are but they left it as is...I know, I know, it sounds confusing, blame GM. The Pfadt plates will work with your stock suspension and also down the road when you make the switch to coilovers.
This is what you have now, except the black cap is removed.
Once you remove the stock plunger and replace with these plates, you'll be able to dial in the alignment. That's still the same nut used, so that's one of the benefits, they'll work with stock & coil overs.
Let me know if you want to buy them & a plane ticket to Lebanon.
Built by Late Model Racecraft
Fastest C7 in Tri-State 10.13 @ 134mph
7/26/14 Corvette Challenge Raceway Park, E-Town, NJ
Kronix is offline   Reply With Quote
Old 12-20-2012, 05:45 AM   #622
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Thanks for the info buddy ,just shot you a pm.
Old 12-20-2012, 05:57 AM   #623
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
thanks dawg , i can't wait too ,going there around 4 pm to pick her up.
Old 12-20-2012, 11:38 AM   #624
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Just got back from the body shop and man the hood looks real badazz , also installed the door sills and painted the taillight bezels , I hope it stops raining to take better pics .
Old 12-20-2012, 12:05 PM   #625
TCAT
TCAT's Avatar
Drives: Has Wheels
Looks absolutely amazing Pierre!! Doesn't an aftermarket hood change the entire appearance of the whole car??!
Old 12-20-2012, 12:12 PM   #626
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Damn right it does buddy , whoever saw the car since this afternoon just stood still and gazed at the hood with a look that said WTF , maaaan it's a head turner to the bone .
Old 12-20-2012, 12:15 PM   #627
TCAT
TCAT's Avatar
Drives: Has Wheels
Hahaha hell yeah. This generation Camaro has by far the meanest look out there, and with mods., ......fogedabowdit!!!
Old 12-20-2012, 12:18 PM   #628
ElektraSS
Elektra SS
ElektraSS's Avatar
Drives: 2010 Camaro SS
+1 on your comment TCAT. Looks good Cyber Bullet!
2010 Aqua Blue, K&N CAI, RK Side skirts, hood, and spoiler. Borla Exhaust/CATS, 22 TSW Wheels, Fidanza Short Shifter and Flywheel, performance chip, Halo's. Twin Turbo in progress!
ElektraSS is offline   Reply With Quote
Old 12-20-2012, 01:14 PM   #629
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Thanks guys I really dig how it turned out waaaay better than I expected.
Old 12-21-2012, 12:20 PM   #630
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Damn weather isn't getting better ,rain hasn't stopped since 3 days ,all i want is 3 hours of no rain so i can take a couple of pics of the new hood with my new DSLR .
camaro of the week
[COTW 2/26/11]: MOHAWKs 677 HP 658 LB FT TQ IOSS Build Thread!! MohawksIOSS Member Car Journals 75 04-30-2012 09:41 PM
The Nameless - 2SS 45th Vert NA LS3 Build Thread Falundir Member Car Journals 39 02-09-2012 02:33 PM
LS 68 RS Build Thread K1SSRSS 1st & 2nd Generation Camaros 1 12-31-2011 02:03 PM
Neogenix's 2011 SS/RS BLK/BLK Build Thread neogenix Member Car Journals 7 02-27-2011 11:15 PM
