Emblempros
Old 01-16-2012, 06:36 PM   #1
Ricky11SS
Ricky11SS's Avatar
Drives: 2011 Camaro SS L99
Angry having problems uggh hate it
im having problems with my car
it feels like if it needed some new spark plugs but i already changed them all new and it still not working fine..
i ran the onstar diognostics and they told me i was having problems with the oxygen sensors with all four of them front and rear. but my tuner already turned the rear off so i dnt get it. i have some headers so all i did with the front sensors were just made them longer. also they said something the solenoid valve thats in the gas tank or near the gas tank but i dont get it either. :/
anyone having those problems ? ? ?
i really need help thanxx guys
Ricky11SS is offline   Reply With Quote
Old 01-16-2012, 07:13 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
Check you maf, maybe you are running off triggering the o2s. You cant just extend the o2s they need to be tuned for the lower operating temp with headers. If you have a tune, then talk to your tuner. Most likely a small glitch from him
Parag is offline   Reply With Quote
Old 01-16-2012, 07:20 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
Are you getting a Check Engine Light? If so what is the code.
I recently had kind of a similar issue. The car was running ok but I got a CEL about being too lean. Ended up being a vaccum leak caused from my catch can. Check your MAF connection or CAI connection or catch can if you have one.
Build Journal
Old 01-16-2012, 07:27 PM   #4
Ricky11SS
Ricky11SS's Avatar
ok wats a MAF?
i dont have a catch can.
when i had the check engine light it showed me a leak from some where
my tuner said something similar parag he said something that the extension and that the sensor needed some temp.
thanxx guys for the help
Old 01-16-2012, 08:38 PM   #5
caverman
caverman's Avatar
Do you have an aftermarket Cold Air Intake?
Build Journal
Old 01-16-2012, 09:14 PM   #6
Ricky11SS
Ricky11SS's Avatar
yea vararam.
i checked the maf sensor and its a "weak" one.
idk if thats the problem or not
Old 01-16-2012, 09:28 PM   #7
jcollins91106
jcollins91106's Avatar
Drives: 2010 2ss m6
I an willing to bet you have two issues...1- you need a strong MAF, when you add an intake it actually makes the car run like crap. At idle mine soundedlike it was missing and it didnt feel like it was all there under load. 2- the oxygen sensor issue...Check your clamps on your intake, at the throttle body and at the filter. Mine were just a little loose and it threw codes for p0171 and p0174 both banks lean. I was loosing my mind!!! 5 minute tighten job, and a strong MAF and my bet is you will think its a new car.
2010 2ss M6, TSP 1 7/8 Long Tube headers,dual electric cutouts, 3" pipes all the way back to magnaflows. elite engineering catch can, custom painted engine cover,CAI cold air intake, apex cold air racescoop, jannety racing 470 hp kit, custom JRE hot rough idle blower cam, jannety racing dyno tuned. pfadt lowering springs, lsr short throw shifter, custom sub setup,sony 7" indash nav, interior stiching dye, 20% tint all around, HAVOC spoiler, tail light black out, chevy emblem black out, seibon BBII carbon fiber hood,Front and rear bowtie blackouts. 461 rwhp and not done yet!
jcollins91106 is offline   Reply With Quote
Old 01-16-2012, 09:29 PM   #8
Black1SS
Black1SS's Avatar
Drives: 2010 Camaro 1SS/RS 6 Speed
I would definately start there and replace it. Hopefully that will fix the problem
Black1SS is offline   Reply With Quote
Old 01-16-2012, 09:34 PM   #9
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
MAF is a likely problem. Your "tuner" should have picked up on this. Also I'd look on finding a different mechanic/tuner. Friendly hint- when asking for help please list all performance mods. Helps to be able to point you in the right direction.
KEEP RT is offline   Reply With Quote
Old 01-16-2012, 09:35 PM   #10
Ricky11SS
Ricky11SS's Avatar
thanxx yea at idle it sounds like if it had a cam but it doesnt :/
sucks
Old 01-16-2012, 09:51 PM   #11
jcollins91106
Drives: 2010 2ss m6
exactlylike mine...sounded almost good but no bueno at WOT
Old 01-17-2012, 12:02 AM   #12
Ricky11SS
Ricky11SS's Avatar
Just installed the maf strong sensor and nope nothing.
Man im getting so pissed off I rather put everything back to stock and turn in the car for a new cts-v !
Old 01-17-2012, 12:33 AM   #13
caverman
caverman's Avatar
Then you need to check all of your hoses from the Vararam to the intake. Sounds like a vaccum leak to me. Double check the whole install of the intake. Worst case would be to put the stock intake back on. If problems go away then at least you've narrowed it down to the intake.
BTW: how did you get a new MAF so quick? And what is the code on the side of the MAF?
Build Journal
Old 01-17-2012, 12:36 AM   #14
Ricky11SS
Ricky11SS's Avatar
I went to O'Reilly's auto parts cost me 64$ with the sensor trade. The new sensor says k7 and the old one said the letter v only
1st and 2nd gear problems. 1SS 6M jnm2003 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 08-17-2010 02:06 PM
Long Problem(s) GM techs or someone needed here... xpanda305x Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 37 07-04-2010 03:00 PM
Problems from cutouts LS3_Man Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 06-05-2010 03:57 PM
You may hate this thread, but I'm starting to HATE my Camaro! 2Muchmark 5th Gen Camaro SS LS LT General Discussions 172 05-24-2010 11:20 PM
Flipping weather Iroczlover Off-topic Discussions 10 02-11-2009 09:46 PM
