01-16-2012, 07:38 PM | #1 |
Never enough time
Drives: 2010 Camaro SS 6-spd Join Date: Jun 2011
Loss of power steering below 750 RPM
OK, here's a weird one...Two things happened today, one right after another:
1. PS went out while turning into a parking space. Confirmed that PS assist goes away after engine drops below 750 RPM (like when coasting to a stop sign or making a low-speed turn). Above 750 RPM, PS returns. No donuts, no high-rev maneuvers other than highway driving a couple days before. Fluid level is OK. Yes, I know to take it to the dealer, but thought I'd check here first for something I might have overlooked. 2. Clutch started to chatter on takeoff (right after the PS failed on me). It's never done that in the 5000 miles I've driven the car. Doesn't chatter in any other gear. Just at low speed, low RPM in first. Now I definitely have to rev a bit higher when releasing the clutch in first from a dead stop to make the chatter go away. Could they be related? Yes, I know to take it to the dealer, but thought I'd check here first for something I might have overlooked.
Personal mission: Killing the Dynojet vs. Mustang hype
01-26-2012, 12:07 AM | #2 |
Never enough time
Low output on the PS pump...pump replaced. 15000 miles, hopefully everything else holds together!
Thread Tools | |
Similar Threads | ||||
2010+ Camaro StopTech Drilled Rotors & Power Slot Slotted Rotors | Cyro Treated! | AutoAgenda | Suspension / Chassis / Brakes | 37 | 02-02-2013 08:12 PM |
Power steering or rubbing sound in reverse? | Mustang Killa | Suspension / Brakes / Chassis | 34 | 06-10-2011 05:21 PM |
Power steering rack leak | AlexL | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 0 | 05-14-2011 11:12 PM |
Power steering cooler leak? | Macrackie | 5th Gen Camaro SS LS LT General Discussions | 0 | 04-09-2011 10:34 PM |
