BORLA
Old 01-16-2012, 10:37 PM   #1
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 Mosaic Black Metallic ZL1
L99 vs LS3: One Person's Perspective
My intent with this post is not to start another automatic vs manual war. I'm sure that topic has been discussed ad nauseum in these forums. Instead I think I bring a unique perspestive regarding the strengths and weakness of each engine/transmission package having owned both in the past 8 months.
Let me start with a litte background, last May I purchased a brand new 2011 victory red 2SS Camaro convertible with automatic. I won't bore you the reasons why I went with the automatic, just know it ended up being my biggest regret. So yesterday I bit the bullet and traded in the '11 for a 2012 victory red 2SS Camaro convertible with manual transmission.
Here are my initial thoughts between the two packages:
Aggressiveness:
I was flabbergasted at the difference in aggressiveness between the two engine packages. I just about jumped out of my shoes yesterday when the dealer started up the '12 Camaro. In my estimation, the LS3 sounds 10 decibles louder at startup than the L99. And the engine rumble during acceleration is also significantly louder with the LS3. If I didn't know any better I'd think Chevy put a completely different exhaust package on the manual. It's that much louder than the L99.
Acceleration and Performance:
It's not a surprise, acceleration from a dead stop is where the automatic really shines. It's smooth and "pin you in your seat" powerful. I was always impressed at how quick the auto would reach 60 or above mph. I haven't owned the LS3 long enough to tell whether the 26 extra horses makes a difference. I certainly don't feel it on acceleration. I'm sure if I ran each car down a quarter mile I'd see a difference. Based on how and where I drive, I probably won't see much difference.
Drivability and Fun:
The automatic, in my opinion, is perfect for cruisin' with the top down. On a warm summer evening there's nothing better then riding around with the top down jamming to your favorite tunes. It's when the top goes up that the automatic loses much of it's excitement. On the other hand, the manual drives like what I thought a true "muscle" car would drive like. It's loud, rough and agressive. There's a connection between the car and the driver that's missing with the automatic. For me, the manual seems much harder to drive. To give an example, my driveway has a slight incline. I cringe every time I put the '12 in the garage. I just don't feel like I have the same level of control as I did with the auto. I'm afraid I'm going to give the car too much gas and end up going through the back wall. I'm sure I'll feel more comfortable as I get use to driving it, but for now I don't feel I have as much control. I'm anxious for good weather to arrive so I can compare driving with the top down. The automatic was great fun, I hope the manual matches that experience and doesn't make me regret trading in the auto.
In the end, I'm really surprised at the different driving experience produced by each engine/transmission package. I wouldn't say the difference is 180 degrees on opposite ends of the scale, but I sure thought it would be closer than it turns out to be. At this point I can't really recommend one over the other. It all depends on what you want from the car.
--Kim
hawk02 is offline   Reply With Quote
Old 01-16-2012, 11:50 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
The LS3 and L99 do have two completely different exhausts from the factory. Even the inside of the muffler is different between the two.
As far as feeling comfortable with the manual, that will just come with a little time. If you feel like the clutch is too stiff or wants to jump out at you too fast there is a spring at the top of the clutch pedal that you can remove. Do a search and you'll find the thread about removing it.
For me, I couldn't stand the stock shifter. That was one of my first mods. I got an MGW with the Race knob and it's 100% different and 100% better IMO.
Stock to stock you my not feel a difference right off the bat but trust me there is more HP from the manual. The autos usually put down about 335 rwhp where the manual is more in the 365 rwhp range. Not only does the LS3 come with more HP but there is alot more HP robbed by the big auto trans. Now, add a couple bolt ons and a torque converter to the auto and all bets are off. Actually the auto would probably win at the drag strip because it should be easier to launch.
For me (and my wife as well) there was not even a remote consideration of an auto over the manual. IMO it's makes the car alot more fun to drive.
My '69 is a convertible with a 5-speed trans. Wouldn't have it any other way. I love driving it with the manual no matter if the top is up or down (although it's down 90% of the time).
Build Journal
Old 01-17-2012, 12:08 AM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
if you really knew how to drive a stick well and got use to it. the control thing would never been a problem. people who worry about giving it to much gas are little new to manuals or are not use to driving them, but still know how to drive them.
anyways nice read. i know what you mean my DD is a auto and my camaro is a manual. they are times when i just wanna get in my car and relax and drive. that why i love my auto. but i must say getting into that manual and going through the gears with that v8 rumble is one hell of a time.
both are great, my next car will be a duel clutch tranny hopefully.
Old 01-17-2012, 12:51 AM   #4
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Great read. I agree with the exhaust of the 12 LS3 as ive heard VR Baron's ride. When he fired her up there was more rumble. Ive driven an 11 LS3 and didnt sound like the 12's.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 01-17-2012, 02:15 AM   #5
dshep214
dshep214's Avatar
Drives: 2011 Camaro 2ssRS Ls3
Great read. Well thought out very nice
dshep214 is offline   Reply With Quote
Old 01-17-2012, 07:00 AM   #6
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
It won't take long to get used to the stick. My driveway is at an incline, I have to back in so I can get out of the car, and I need to put the passenger mirror about 4 inches from the wall so I don't tap the wife's tahoe with my door when I get out. On top of all that, I have a bike rack in the back of my garage which gives me +/- about 8 inches of breathing room between hitting the bike rack with the back of my car and closing the garage door on the front.
It used to take me 2+ tries to get it and I was nervous as a cat in a room full of rocking chairs the whole time. After a few months I hit it the first time every time without even thinking about it. Like anything else, practice makes perfect.
I'm sure I just jinxed myself with this post and today will be the day I hit the garage wall with my mirror....
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 01-17-2012, 07:06 AM   #7
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Interesting perspective and it certainly sounds completely unbiased.
I've been driving a manual, off and on, since the mid 70's, so it's second nature to me. Once you spend enough time driving your new Camaro, you won't even think about it any more. I went manual on the Camaro, despite it being my daily driver, simply for the fun factor.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 01-17-2012, 08:17 AM   #8
DuhKoDuh
DuhKoDuh's Avatar
Drives: 2011 Camaro 2SS/RS (Black) L99
i wish i would have got the ls3 :(
Follow me on Instagram @C7Corvettes
DuhKoDuh is offline   Reply With Quote
Old 01-17-2012, 02:31 PM   #9
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2012 VR 2SS RS M6
You should hear it now with the outlaw axelback. Holly Crap!!!
Good write up. Nice if we all could afford one of each depending on our mood that day, but I really dont mind the stick in any conditions unless in traffice stuck for a hour and that doesnt really happen on my normal drive
Mods: Magnaflow 3" comp catback/Rotofab CAI/Apex Scoop/VMax T/B/ G.M. Blade Spoiler/SLP Splitter/ Forgestar cf10 wheels & Michelin Super Sport tires/JBA Shorty Headers,HiFlow cats & tune/ Ridetech coilovers And DSE swaybars /BMR cradle bushings, toe links and trailing arms/Stage 1 cam-445/430 RW HP/TQ
VR Baron is offline   Reply With Quote
Old 01-17-2012, 04:46 PM   #10
SSGUNNER
SSGUNNER's Avatar
Lol me too but cali traffic is the worst. I dont regret my choice one bit but i know. Manuals are fun and pops taught me when i was 14. Who knows if i ever get another sports, muscle, pony car it will be a manual.
i bet. Have you done any sound clips? Im sure its a beast.
Old 01-17-2012, 04:50 PM   #11
VR Baron
VR Baron's Avatar
No.
Old 01-17-2012, 07:04 PM   #12
brantley847
v It bites.
brantley847's Avatar
Drives: 2011 IBM 2SS/RS
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit.
brantley847 is offline   Reply With Quote
Old 01-17-2012, 07:44 PM   #13
MikeOD
Drives: 2010 M6 2SS
The day you forget you're actually running the clutch pedal and the shifter...ie when it's coming naturally to you, just the same as how you don't think what you're doing to walk...or you don't focus on breathing and blinking...is when you're actually "good" at driving with a clutch pedal.
I don't even think about it nowadays...to the point where when I get behind the wheel of my winter car, which has an auto, I actually have to stop myself from smashing my left foot on the floorpan looking for a pedal that isn't there when I need to start the car.
For what it's worth, I know it's been mentioned above...the LS3 exhaust is completely different. GM had to put more nonsense in the L99 exhaust because DoD can make a V8 really sound strange (in a bad way) with an exhaust that lets more noise through.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 01-17-2012, 08:10 PM   #14
mikey8
mikey8's Avatar
Drives: 2017 2SS
Kim, I've driven a stick all my life, and it took me a couple of weeks to get used to where the clutch releases. After a couple of weeks, you'll get the feel. Now, you can't even feel shifts. Really smooth. As mentioned above... Eventually, you won't even think about what gear you'll need to be in. It just happens naturally. Congrats!!!!!
mikey8 is offline   Reply With Quote
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 12:30 PM
SAE HP/Torque Curves for L99 & LS3 ls2gto Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 05-16-2011 06:43 PM
Watched a 2011 5.0 GT at the track. JJ#48Racing Chevy Camaro vs... 143 07-21-2010 06:56 PM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 12:58 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
