Old 01-17-2012, 07:33 PM   #1
Devilfish
US Navy Chief
Devilfish's Avatar
Drives: Camaro Sold
Aftermarket fuel rails on mostly stock L99
First off I mainly want this to clean up the appearance under hood. Eventually I plan on needing more fuel but it may be a little while. I guess my question is will it hurt anything with the current mods in my sig? Will I run rich or will the extra fuel just be there in the rails? I am coming from the off road world and in the 90's had a 5.slow muffstang and parts have been very inexpensive. The after market for this car is generally expensive so I am not able to do a lot of mods at once as I have with my previous automotive endevors. Thanks in advance for your help with this.
Devilfish is offline   Reply With Quote
Old 01-17-2012, 07:37 PM   #2
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
just flip the fuel rail around and get a short line,, it cleans it up nice
Old 01-17-2012, 07:45 PM   #3
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
No, it won't hurt anything....I am doing the same to mine right now. But like camaro1 said above, if money is tight, you can simply flip the OEM fuel rail 180 degrees and get a shorter fuel line. This is what I did for several months, and it does clean up the appearance alot. I do have an extra short fuel line from Tech AFX if you're interested.
blazzin1 is offline   Reply With Quote
Old 01-17-2012, 08:46 PM   #4
MikeOD
Drives: 2010 M6 2SS
The car most likely won't perform any differently at all...and the stock rails are fine at a LOT of power too...I agree on appearance, but the stock rails, in my opinion, look pretty nice if you clean them up thoroughly and do like the guys above mentioned...remove the stickers from them, polish them...winds up looking pretty nice and clean.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 01-19-2012, 01:30 AM   #5
Buffnshine
So Cal Camaro5 Race Team
Buffnshine's Avatar
Drives: '10 SS/RS, '06 HHR, '70 El Camino
is there a DIY on this
TEAM L99 - So Cal Camaro5 Race Team #27
9/5/09 Purchased #36962 Black 1SS/RS L99 "E-TCKT" Base Dyno 328hp/341tq @BBK meet
Mods to Date: Window Tint 5% & 15%, ACC P13W Lighting, Adaptive DRL Harness, Ghost Armor, Lloyds "SS" Mats, Dash Plaque, Flowmaster Outlaw Exhaust, Drake Front Bowtie Delete, Stealth 3457 Chrome/Mirror Signal Bulbs, Grant Revolutions Steering Wheel, PFADT Sport Springs, Sway Bars, End Links, Trailing Arms, 4 Wheel Alignment, Hurst Auto Shifter and Paddle Shifter, Satin Black Rear Tail Light Bezels
Buffnshine is offline   Reply With Quote
Old 01-19-2012, 04:11 AM   #6
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
http://www.techafx.com/sites/techafx...structions.pdf
Great instructional PDF. It's not hard whatsoever. You might take a look at the tread I'm doing for more ideas.
http://www.camaro5.com/forums/showthread.php?t=188393
Moreno Motorsports is offline   Reply With Quote
JDP Motorsports' 2010+ Camaro SS Fuel Line Retrofit DIY JDP Tech Camaro DIY & HOW-TO instructions & discussions 27 08-17-2017 01:31 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
my dyno today(base for e85 tune) bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 51 06-08-2011 12:35 PM
Check engine light on Boricua Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-28-2010 02:12 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
