| 5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums. |
Thread Tools |
H1 OFCR
Drives: 2011 Camaro 2SS/RS IOM Join Date: Jun 2011
Removal of MAF Sensor help
Hey guys, sounds like a newbie question but I cannot for the life of me get the harness off of the MAF in order to get my screw driver in there to take the actual sensor out. Any tips before I snap this thing off?
Corsa
Rotofab BBK ZL1 Hood/Fascia AAC Afterburners/Sidemarkers Havoc Black Chrome 5% Tint/20% Smoked Taillights |
Tri-County Camaros Tampa
Drives: 2011 Camaro 1SS/RS VR/BLK A6 Join Date: Jan 2011
Are you just yanking on it or are you releasing the tab first? You have to release the tab to unlock it before pulling it off.
#3 | |
H1 OFCR
On the side? I pulled the white tab on the top of it out but still no go
Corsa
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
The tab is on top, even after it is released it can still be a good tug to get it off the first time or two. Just make sure the top tab is released.
Heritage Grill, Cold Air Inductions Intake, Elite Engineering Catch Can, BMR 1" Lowering Springs, Sway Bars and End Links, Clear Image Jet Hot Ceramic Coated headers and High Flow Cats, Hurst Billet 2 Shifter, LSR Billet Strut Washers, DynoMax Axle Back Exhaust, JANNETTY MAGIC! |
![]() ![]() ![]() ![]() Drives: 2010 2ss/RS 4l80. 2009 2500 HD Join Date: Mar 2009
It also helps to push in and then pull out.
D1SC-LG G6x3-SW 2" Headers-DMH Cutout-3" Flowmaster A/T-ADM Dual Fuel-ADM Boost,Air/Fuel gauges-Nitto NTO5r-SJM line lock-Modded LS3 Oil pump-BMR-Toe Bar,Trailing Arm,Sub Connectors,Cradle Bushings-Shep Tunnel brace-MSD Shift Light,2Step-CINCY SPEED Tune-DSS 9" Conversion..3.70s gear
ALKY Control-Extream Innovations Roll Bar- 4l80!! 763RWHP 629TRQ |
#6 |
H1 OFCR
Yeah still no luck. Just totally removed the white tab all together and it still wont budge.
Corsa
#7 |
Conectors can be a pain....but keep working at it. Drink a beer and next thing you know the dang thing will practicality fall out.
#8 |
Drives: Camaro Join Date: Dec 2011
#9 |
![]() Drives: 2010 1SS/RS Imperial Blue Metallic Join Date: Sep 2010
you should have plenty of room to get to the to screws to remove the MAF after you unhook the harness. Or did you get the screws out and the MAF sensor still wont come out?
#10 |
Have you tried vice grips?
#11 |
OIF Veteran
What are you doing? Installing a Cold air intake? Usually if it is stuck is because it is cold, if you can get it in a garage and let it warm up or use a hair dryer to warm it up and it will come off pretty easily. Don't break it, they aren't cheap to replace.
#12 |
OFF THE CHAIN
When you say white tabs you are trying to disconnect it in the wrong place, you need to be pulling the tab on the end at the top of the harness clip not where the wires go into the clip itself. White is what holds the actual wires into the clip so you are off by about an inch to the actual clip!
#13 |
OFF THE CHAIN
Look at the pictures it is pretty self explanatory. Sorry about the child's art work. But 2010 the clip is purple, 2011 it is white where you say you are trying to disconnect? Don't disconnect there, disconnect at the tab, wiggle it and it should come out not break at all! You are obviously doing something wrong here it just doesn't make sense?
#14 |
^What this guy posted....BTW great job posting the pictures...I was about to do the same.
#15 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 CRT ZL1 Vert M6, 2011 Equinox Join Date: Jul 2009
Imagine you have it by now, but if all else fails...
#16 |
H1 OFCR
Lmao I love this forum. And no I didn't get it last night. Partially because I was running out to the garage on commercial breaks from the State/Michigan basketball game. And no I already installed a cold air intake in June when I got it, I was trying to see if my MAF sensor is weak or strong LOL. But I will try your guys' suggestions tonight and let you know if I got it or I might be in the market for a new harness LOL
Corsa
#17 | |
The tab is on top
The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top, The tab is on top,
#18 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '112SS/RS'12CruzECO'11CruzeLTZ,Mini Join Date: Mar 2011
Hammers work. It's probably a weak sensor anyway.
![]() Seriously watch you don't strip the threads when replacing.
![]() Last edited by SSBUSDRVR; 01-18-2012 at 10:38 AM. |
#19 | |
#20 |
On top?
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '11 Camaro 2SS/RS LS3 Join Date: Jan 2012
Funny. my car is an '11 and it has the purple piece and not white.
American Racing 1 7/8" w/ HF cats
Borla ATAK axle-back C.A.I intake w/ Scoop Lethal Racing 'Night Fury' cam PFADT Trailing Arms 486rwhp/464rwtq ___________ Best 1/4 ET : 12.88@ 110mph- Headers, Intake, Tune, T Arms, Stock Tires |
#22 |
![]() ![]() Drives: 2011 Black SS M6 Join Date: Oct 2010
| Thread Tools | |
| Cold Air Intake Independent Testing Results by Jannetty Racing | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 529 | 04-15-2013 12:47 PM |
| Issue SOLVED strong MAF. | daveagogo1 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 12-23-2012 07:38 PM |
| Good MAF vs. Bad MAF..the Dyno Test @ MarylandSpeed | MarylandSpeed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 22 | 06-15-2012 10:41 AM |
| MAF Sensor Removal - | Dynabyte | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 9 | 03-31-2011 06:53 PM |
| Halltech Yellow Jacket – oil substance around MAF information | caverman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 06-29-2010 01:51 PM |
